openshot 1.3.1
tornadomig
Nome Cognome: Giorgio
Slackware: Current64 multilib
Kernel: -current
Desktop: Xfce
openshot 1.3.1
Messaggio da tornadomig »
root@darkstar:~# openshot
Added /usr/share/openshot to system path
   OpenShot (version 1.3.1)
*** ERROR: MLT Python bindings failed to import ***
Exception in thread Thread-1:
Traceback (most recent call last):
  File "/usr/lib64/python2.6/threading.py", line 532, in __bootstrap_inner
    self.run()
  File "/usr/share/openshot/classes/thumbnail.py", line 170, in run
    mlt.Factory().init()
NameError: global name 'mlt' is not defined
------------------------- ERROR 1 ------------------------------
Failed to import 'from openshot import main'
Error Message: No module named mlt
------------------------- ERROR 2 ------------------------------
Failed to import 'from openshot.openshot import main'
Error Message: No module named openshot
OpenShot has failed to import some of the Python files or libraries
required for our application to run.  Here are some trouble shooting
tips:
Tip 1) Check if MLT can be successfully imported in Python.  Run the
 following commands, and see if any errors are displayed.  If you get
 an error, you need to investigate the correct way to install MLT.
 NOTE:  Do not type the $ or >> characters in the examples below.
       $ python
       >> import mlt
Tip 2) If MLT is working from the first example, then the next tip is
 to look at the above error messages very closely, and google for more
 help.  It's likely the problem is already reported, and maybe there is
 a simple work-around.  Also, you can search for bugs or report a new
 bug at https://bugs.launchpad.net/openshot.  Good luck!
root@darkstar:~# python
Python 2.6.6 (r266:84292, Nov 27 2010, 17:27:14)
[GCC 4.5.1] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import mlt
  File "<stdin>", line 1, in <module>
ImportError: No module named mlt
>>> mlt.Factory ().init()
NameError: name 'mlt' is not defined
ciao a tutti! sono bloccato qui sull'installazione di openshot.
dove ho sbagliato? solito problema di dipendenze ? eppure ho usato solo il repo di slacky. ho usato sempre gli slackbuilds eccetto 4 o 5 pacchetti dove ho preso diretamente i .txz perché non compilavano.
sono su current 64, 2.6.38-7.
grazie ancora
Ansa89
Slackware: 14.2 64bit
Kernel: 4.9.61
Desktop: XFCE 4.12
Re: openshot 1.3.1
Messaggio da Ansa89 »
1) Impara a usare i tag del forum.
2) Devi installare il modulo "mlt" per python.
tornadomig
Kernel: -current
Desktop: Xfce
Re: openshot 1.3.1
ls -a /var/log/packages | grep mlt
mlt-0.7.2-x86_64-1sl
ah! scusa ma adesso sono un pò sul cotto andante. ho cercato un pochino con google ma non trovo questo modulo mlt-python se è così che si chiama.
come si potrebbe fare?
abbi pazienza,grazie!
tornadomig
Kernel: -current
Desktop: Xfce
Re: openshot 1.3.1
ls -a /var/log/packages | grep python
compizconfig-python-0.8.4-x86_64-3_SBo_ngl
dbus-python-0.83.1-x86_64-1
notify-python-0.1.1-x86_64-1
python-2.6.6-x86_64-1
questo è tutto quello che ho di python installato.
non capisco quale sia mlt per python...
gohanz
Re: openshot 1.3.1
Messaggio da gohanz »
tornadomig ha scritto:ls -a /var/log/packages | grep python
I bindings Python per Mlt fanno parte del pacchetto Mlt stesso. Vedo però che il pacchetto i686 li contiene, mentre il pacchetto x86_64 è senza. Dovresti ricompilare il pacchetto x86_64, abilitando i bindings python, segnalando la cosa anche su pkgreports.
tornadomig
Kernel: -current
Desktop: Xfce
Re: openshot 1.3.1
# sh mlt.SlackBuild
--2011-06-13 17:55:45-- http://sourceforge.net/projects/mlt/fil ... 7.2.tar.gz
Risoluzione di sourceforge.net (sourceforge.net)... 216.34.181.60
Connessione a sourceforge.net (sourceforge.net)|216.34.181.60|:80... connesso.
HTTP richiesta inviata, in attesa di risposta... 200 OK
Lunghezza: non specificato [text/html]
Salvataggio in: "mlt-0.7.2.tar.gz"
[ <=> ] 415 --.-K/s in 0s
2011-06-13 17:55:45 (77,5 MB/s) - "mlt-0.7.2.tar.gz" salvato [415]
tar: Questo non sembra un archivio tar
gzip: stdin: not in gzip format
tar: Child returned status 1
tar: Error is not recoverable: exiting now
grazie dell'aiuto!!!
questo è il responso quando cerco di ricompilare mlt con lo slackbuild. stessa cosa con il repo di slacky che con quello di slack.isper.sk. non riuscendo a compilare ho installato il pacchetto .txz.
sarebbe giusto? che ti devo dire...non so come devo abilitare questi bindings che ignoro cosa siano 8-)
Blallo
Nome Cognome: Savino Liguori
Slackware: 14.2 / 12.2
Kernel: 4.4.14-smp
Desktop: DWM
Re: openshot 1.3.1
Messaggio da Blallo »
mlt l'ho fatto io e l'ho già ricompilato aggiungendo i bindings python e Ruby.
Bisogna solo aspettare che Loris aggiorni il repo :)
EDIT: se non puoi aspettare, eccoti lo SB modificato
mlt.tar.gz
(3.76 KiB) Scaricato 220 volte
tornadomig
Kernel: -current
Desktop: Xfce
Re: openshot 1.3.1
in pratica si tratta di aspettare e poi riprovare a ricompilare, giusto? incrociando le dita 8-)
tornadomig
Kernel: -current
Desktop: Xfce
Re: openshot 1.3.1
@jimmy_page_89: grazie per l'allegato ma ignorando come utilizzarlo (spero di non aver bestemmiato, chiedo venia), lascio stare 8-)
lablinux
Desktop: Gnome
Distribuzione: Debian testing
Re: openshot 1.3.1
Messaggio da lablinux »
Lo devi installare, ti ha fornito il pacchetto.
Prima rimuovi il pacchetto mlt con
pkgtool
vai su Remove e selezioni mlt
Poi installi quello che ti ha passato jimmy_page_89
installpkg mlt.tar.gz
che, come ti ha già detto jimmy_page_89, diventerà il pacchetto ufficiale in slacky quando Loris darà l'ok
P.S. magari questo può esserti utile http://www.slackware.com/config/packages.php
Ciao Michele
tornadomig
Kernel: -current
Desktop: Xfce
Re: openshot 1.3.1
oh grazie
completo l'opera poi faccio sapere se mettere "risolto"
414N
Kernel: 5.15.19
Re: openshot 1.3.1
Messaggio da 414N »
lablinux ha scritto:Lo devi installare, ti ha fornito il pacchetto.
:-k
Veramente, a me quello sembra solo un archivio contenente lo SlackBuild...
tornadomig
Kernel: -current
Desktop: Xfce
Re: openshot 1.3.1
giorgio@darkstar:~$ ls -a /var/log/packages | grep mlt
mlt-0.7.2-x86_64-3sl
ciao a tutti,
ho provato di tutto...ho trovato anche dipendenze che non avevo incluso tra l'altro. il pacchetto di jimmy_page l'ho installato. qualche volta ho visto aprirsi la finestra di openshot ma mi compare questo:
giorgio@darkstar:~$ openshot
Process no longer exists: 9600.  Creating new pid lock file.
Failed to import VimeoClient.  Removed Vimeo from upload screen, to allow OpenShot to continue working.
No formats or codecs were found.  Please check the OpenShot preferences and configure the 'melt' command name.
Errore di segmentazione
come potrei risolvere? grazie sempre della pazienza
nyquist
Nome Cognome: Cristiano Urban
Slackware: 15.0 multilib
Kernel: 5.15.161
Re: openshot 1.3.1
Messaggio da nyquist »
Anche a me fa una cosa simile...
Lanciando openshot da linea di comando:
Error Message: cannot import name main
Process no longer exists: 14985.  Creating new pid lock file.
A me non compare neppure l'interfaccia grafica...
N.B. Ho la seguente mlt: mlt-0.7.2-i686-1sl
gohanz
Re: openshot 1.3.1
Ho il sospetto che l'aggiornamento di FFmpeg alla 0.7.1 dia problemi a Mlt. Mlt è il motore sia di Openshot che di Kdenlive ad esempio.
Ora fino a FFmpeg 0.6.3 tutto funziona bene. Ora anche sul mio pc ci sono problemi. Tra l'altro la ricompilazione di Mlt con il nuovo FFmpeg 0.7.1 sembra non risolvere.
