ho 2 dischi fissi , su uno di questi c'è arch, sul secondo una partizione dati ( ext4 ) e le 4 di slackware .
quando ho installato slackware il disco di arch non era presente , se ora cerco di avviare slackware con il disco di arch inserito lilo lo avvia , carica il kernel ma si blocca al mounting dei dischi , non è che slackware li indetifica in fstab come /dev/xxx e non in UUUID ? se così me lo spiego, altrimenti no
X.Org X Server 1.6.3
Release Date: 2009-7-31
Build Operating System: Slackware 13.0 Slackware Linux Project
Current Operating System: Linux siderium 2.6.29.6-smp #2 SMP Mon Aug 17 00:52:54 CDT 2009 i686
Build Date: 03 August 2009 06:51:50PM
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Jun 24 16:12:02 2011
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(WW) The directory "/usr/share/fonts/local" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/share/fonts/CID" does not exist.
(**) FontPath set to:
/usr/share/fonts/TTF,
/usr/share/fonts/OTF,
/usr/share/fonts/Type1,
/usr/share/fonts/misc,
/usr/share/fonts/75dpi,
/usr/share/fonts/100dpi,
/usr/share/fonts/cyrillic,
built-ins
(**) ModulePath set to "/usr/lib/xorg/modules"
(WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
(WW) Disabling Mouse0
(WW) Disabling Keyboard0
(II) Loader magic: 0x1de0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 5.0
X.Org XInput driver : 4.0
X.Org Server Extension : 2.0
(II) Loader running on linux
(--) using VT number 7
(--) PCI:*(0:1:5:0) 1002:9610:1849:9610 rev 0, Mem @ 0xd0000000/268435456, 0xfeaf0000/65536, 0xfe900000/1048576, I/O @ 0x0000d000/256
(II) System resource ranges:
[0] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[5] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[6] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[7] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[8] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[9] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[10] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[11] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[12] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[13] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[14] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[15] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[16] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[17] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[18] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[19] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[20] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[21] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[22] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[23] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[24] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[25] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[26] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[27] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[28] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[29] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[30] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[31] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[32] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[33] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[34] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[35] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri2" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions//libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.6.3, module version = 1.1.0
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension DRI2
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
compiled for 1.6.3, module version = 1.0.0
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "radeonhd"
(II) Loading /usr/lib/xorg/modules/drivers//radeonhd_drv.so
(II) Module radeonhd: vendor="AMD GPG"
compiled for 1.6.1, module version = 1.2.5
ABI class: X.Org Video Driver, version 5.0
(II) RADEONHD: X driver for the following AMD GPG (ATI) graphics devices:
RV505 : Radeon X1550, X1550 64bit.
RV515 : Radeon X1300, X1550, X1600; FireGL V3300, V3350.
RV516 : Radeon X1300, X1550, X1550 64-bit, X1600; FireMV 2250.
R520 : Radeon X1800; FireGL V5300, V7200, V7300, V7350.
RV530 : Radeon X1300 XT, X1600, X1600 Pro, X1650; FireGL V3400, V5200.
RV535 : Radeon X1300, X1650.
RV550 : Radeon X2300 HD.
RV560 : Radeon X1650.
RV570 : Radeon X1950, X1950 GT; FireGL V7400.
R580 : Radeon X1900, X1950; AMD Stream Processor.
R600 : Radeon HD 2900 GT/Pro/XT; FireGL V7600/V8600/V8650.
RV610 : Radeon HD 2350, HD 2400 Pro/XT, HD 2400 Pro AGP; FireGL V4000.
RV620 : Radeon HD 3450, HD 3470.
RV630 : Radeon HD 2600 LE/Pro/XT, HD 2600 Pro/XT AGP; Gemini RV630;
FireGL V3600/V5600.
RV635 : Radeon HD 3650, HD 3670.
RV670 : Radeon HD 3690, 3850, HD 3870, FireGL V7700, FireStream 9170.
R680 : Radeon HD 3870 X2.
M52 : Mobility Radeon X1300.
M54 : Mobility Radeon X1400; M54-GL.
M56 : Mobility Radeon X1600; Mobility FireGL V5200.
M58 : Mobility Radeon X1800, X1800 XT; Mobility FireGL V7100, V7200.
M62 : Mobility Radeon X1350.
M64 : Mobility Radeon X1450, X2300.
M66 : Mobility Radeon X1700, X1700 XT; FireGL V5250.
M68 : Mobility Radeon X1900.
M71 : Mobility Radeon HD 2300.
M72 : Mobility Radeon HD 2400; Radeon E2400.
M74 : Mobility Radeon HD 2400 XT.
M76 : Mobility Radeon HD 2600;
(Gemini ATI) Mobility Radeon HD 2600 XT.
M82 : Mobility Radeon HD 3400.
M86 : Mobility Radeon HD 3650, HD 3670, Mobility FireGL V5700.
M88 : Mobility Radeon HD 3850, HD 3850 X2, HD 3870, HD3870 X2.
RS600 : Radeon Xpress 1200, Xpress 1250.
RS690 : Radeon X1200, X1250, X1270.
RS740 : RS740, RS740M.
RS780 : Radeon HD 3100/3200/3300 Series.
RV770 : Radeon HD 4800 Series; Everest, K2, Denali ATI FirePro.
R700 : Radeon R700.
M98 : Radeon M98 Mobility.
RV730 : Radeon HD4670, HD4650.
M96 : Radeon M96 Mobility.
RV710 : Radeon HD4570, HD4350.
(II) RADEONHD: version 1.2.5, built from dist of git branch master, commit cb54f48b
(II) Primary Device is: PCI 01@00:05:0
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[24] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[25] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[26] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[27] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[28] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[29] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[30] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[31] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[32] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[33] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[34] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[35] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[36] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[37] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[38] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[39] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[40] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) RADEONHD(0): Depth 24, (--) framebuffer bpp 32
(**) RADEONHD(0): Option "DRI" "true"
(**) RADEONHD(0): Selected ShadowFB.
(II) RADEONHD(0): Unknown card detected: 0x9610:0x1849:0x9610.
If - and only if - your card does not work or does not work optimally
please contact radeonhd@opensuse.org to help rectify this.
Use the subject: 0x9610:0x1849:0x9610: <name of board>
and *please* describe the problems you are seeing
in your message.
(--) RADEONHD(0): Detected an RS780 on an unidentified card
(II) RADEONHD(0): Mapped IO @ 0xfeaf0000 to 0xb79ca000 (size 0x00010000)
(II) RADEONHD(0): Getting BIOS copy from legacy VBIOS location
(II) RADEONHD(0): ATOM BIOS Rom:
SubsystemVendorID: 0x1002 SubsystemID: 0x1002
IOBaseAddress: 0xd000
Filename: K10DX10DP_D_
BIOS Bootup Message:
ASROCK RS780 VBIOS 082
(II) RADEONHD(0): Analog TV Default Mode: 135466609
(II) RADEONHD(0): The detected amount of videoram exceeds the PCI BAR aperture.
(II) RADEONHD(0): Using only 262144kB of the total 393216kB.
(--) RADEONHD(0): VideoRAM: 262144 kByte
(II) RADEONHD(0): Framebuffer space used by Firmware (kb): 16
(II) RADEONHD(0): Start of VRAM area used by Firmware: 0x17ffc000
(II) RADEONHD(0): AtomBIOS requests 16kB of VRAM scratch space
(II) RADEONHD(0): AtomBIOS VRAM scratch base: 0x17ffc000
(WW) RADEONHD(0): rhdAtomAllocateFbScratch: FW FB scratch area 402636800 (size: 16384) extends beyond available framebuffer size 268435456
(II) RADEONHD(0): Cannot get VRAM scratch space. Allocating in main memory instead
(II) RADEONHD(0): Default Engine Clock: 500000
(II) RADEONHD(0): Default Memory Clock: 266000
(II) RADEONHD(0): Maximum Pixel ClockPLL Frequency Output: 1200000
(II) RADEONHD(0): Minimum Pixel ClockPLL Frequency Output: 0
(II) RADEONHD(0): Maximum Pixel ClockPLL Frequency Input: 13500
(II) RADEONHD(0): Minimum Pixel ClockPLL Frequency Input: 1000
(II) RADEONHD(0): Maximum Pixel Clock: 400000
(II) RADEONHD(0): Reference Clock: 14320
(WW) RADEONHD(0): Direct rendering for R600 and up forced on - This is NOT officially supported yet and may cause instability or lockups
(II) RADEONHD(0): Found libdri 5.4.0.
drmOpenDevice: node name is /dev/dri/card0
drmOpenByBusid: Searching for BusID pci:0000:01:05.0
drmOpenByBusid: drmOpenMinor returns -1
drmOpenDevice: node name is /dev/dri/card1
drmOpenDevice: node name is /dev/dri/card2
drmOpenDevice: node name is /dev/dri/card3
drmOpenDevice: node name is /dev/dri/card4
drmOpenDevice: node name is /dev/dri/card5
drmOpenDevice: node name is /dev/dri/card6
drmOpenDevice: node name is /dev/dri/card7
drmOpenDevice: node name is /dev/dri/card8
drmOpenDevice: node name is /dev/dri/card9
drmOpenDevice: node name is /dev/dri/card10
drmOpenDevice: node name is /dev/dri/card11
drmOpenDevice: node name is /dev/dri/card12
drmOpenDevice: node name is /dev/dri/card13
drmOpenDevice: node name is /dev/dri/card14
(EE) RADEONHD(0): RHDDRIVersionCheck: drmOpen("radeon", "pci:0000:01:05.0") failed.
(WW) RADEONHD(0): RHDDRIPreInit: Version check failed. Disabling DRI.
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Module "i2c" already built-in
(II) RADEONHD(0): GPIO_I2C_Clk_Mask: 0x1f90
(II) RADEONHD(0): GPIO_I2C_Clk_Mask_Shift: 0x0
(II) RADEONHD(0): GPIO_I2C_Data_Mask: 0x1f90
(II) RADEONHD(0): GPIO_I2C_Data_Mask_Shift: 0x8
(II) RADEONHD(0): I2C bus "RHD I2C line 0" initialized.
(II) RADEONHD(0): GPIO_I2C_Clk_Mask: 0x1f94
(II) RADEONHD(0): GPIO_I2C_Data_Mask: 0x1f94
(II) RADEONHD(0): I2C bus "RHD I2C line 1" initialized.
(II) RADEONHD(0): GPIO_I2C_Clk_Mask: 0x1f98
(II) RADEONHD(0): GPIO_I2C_Data_Mask: 0x1f98
(II) RADEONHD(0): I2C bus "RHD I2C line 2" initialized.
(II) RADEONHD(0): GPIO_I2C_Clk_Mask: 0x1f88
(II) RADEONHD(0): GPIO_I2C_Data_Mask: 0x1f88
(II) RADEONHD(0): I2C bus "RHD I2C line 3" initialized.
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Module "ddc" already built-in
(II) RADEONHD(0): Detected VGA mode.
(II) RADEONHD(0): FB: Allocated Cursor Image at offset 0x00000000 (size = 0x00004000)
(II) RADEONHD(0): FB: Allocated Cursor Image at offset 0x00004000 (size = 0x00004000)
(II) RADEONHD(0): Connector[0] {RHD_CONNECTOR_VGA, "VGA CRT1", RHD_DDC_0, RHD_HPD_NONE, { RHD_OUTPUT_DACA, RHD_OUTPUT_NONE } }
(II) RADEONHD(0): Connector[1] {RHD_CONNECTOR_DVI, "DUAL_LINK_DVI_D DFP3", RHD_DDC_1, RHD_HPD_2, { RHD_OUTPUT_KLDSKP_LVTMA, RHD_OUTPUT_NONE } }
(--) RADEONHD(0): Attaching Output DAC A to Connector VGA 1
(--) RADEONHD(0): Attaching Output UNIPHY_KLDSKP_LVTMA to Connector DVI-D 1
(II) RADEONHD(0): RandR: Adding RRoutput VGA_1 for Output DAC A
(II) RADEONHD(0): RandR: Adding RRoutput DVI-D_1 for Output UNIPHY_KLDSKP_LVTMA
(II) RADEONHD(0): Output VGA_1 using monitor section Monitor0
(II) RADEONHD(0): Output VGA_1 has no monitor section
(II) RADEONHD(0): Output DVI-D_1 has no monitor section
(II) RADEONHD(0): DAC A: Sensed Output: VGA
(II) RADEONHD(0): I2C device "RHD I2C line 0:E-EDID segment register" registered at address 0x60.
(II) RADEONHD(0): I2C device "RHD I2C line 0:ddc2" registered at address 0xA0.
(II) RADEONHD(0): EDID data for
(II) RADEONHD(0): Manufacturer: GSM Model: 5774 Serial#: 16843009
(II) RADEONHD(0): Year: 2009 Week: 1
(II) RADEONHD(0): EDID Version: 1.3
(II) RADEONHD(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
(II) RADEONHD(0): Sync: Separate
(II) RADEONHD(0): Max Image Size [cm]: horiz.: 48 vert.: 27
(II) RADEONHD(0): Gamma: 2.20
(II) RADEONHD(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) RADEONHD(0): First detailed timing is preferred mode
(II) RADEONHD(0): redX: 0.646 redY: 0.334 greenX: 0.303 greenY: 0.616
(II) RADEONHD(0): blueX: 0.147 blueY: 0.067 whiteX: 0.313 whiteY: 0.329
(II) RADEONHD(0): Supported established timings:
(II) RADEONHD(0): 720x400@70Hz
(II) RADEONHD(0): 640x480@60Hz
(II) RADEONHD(0): 640x480@75Hz
(II) RADEONHD(0): 800x600@60Hz
(II) RADEONHD(0): 800x600@75Hz
(II) RADEONHD(0): 832x624@75Hz
(II) RADEONHD(0): 1024x768@60Hz
(II) RADEONHD(0): 1024x768@75Hz
(II) RADEONHD(0): 1280x1024@75Hz
(II) RADEONHD(0): 1152x870@75Hz
(II) RADEONHD(0): Manufacturer's mask: 0
(II) RADEONHD(0): Supported standard timings:
(II) RADEONHD(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) RADEONHD(0): #1: hsize: 1280 vsize 1024 refresh: 75 vid: 36737
(II) RADEONHD(0): #2: hsize: 1152 vsize 864 refresh: 60 vid: 16497
(II) RADEONHD(0): #3: hsize: 1680 vsize 1050 refresh: 60 vid: 179
(II) RADEONHD(0): #4: hsize: 1280 vsize 960 refresh: 75 vid: 20353
(II) RADEONHD(0): #5: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) RADEONHD(0): Supported detailed timing:
(II) RADEONHD(0): clock: 138.5 MHz Image Size: 598 x 336 mm
(II) RADEONHD(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
(II) RADEONHD(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1111 v_border: 0
(II) RADEONHD(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 83 kHz, PixClock max 170 MHz
(II) RADEONHD(0): Monitor name: M227WDP
(II) RADEONHD(0): EDID (in hex):
(II) RADEONHD(0): 00ffffffffffff001e6d745701010101
(II) RADEONHD(0): 0113010368301b78eaabd5a5554d9d25
(II) RADEONHD(0): 115054a56b808180818f7140b300814f
(II) RADEONHD(0): 714f010101011a3680a070381f403020
(II) RADEONHD(0): 350056502100001a000000fd00384b1e
(II) RADEONHD(0): 5311000a202020202020000000fc004d
(II) RADEONHD(0): 3232375744500a2020202020000000fc
(II) RADEONHD(0): 000a2020202020202020202020200000
(II) RADEONHD(0): EDID vendor "GSM", prod id 22388
(II) RADEONHD(0): Using EDID range info for horizontal sync
(II) RADEONHD(0): Using EDID range info for vertical refresh
(II) RADEONHD(0): Printing DDC gathered Modelines:
(II) RADEONHD(0): Modeline "1920x1080"x0.0 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz)
(II) RADEONHD(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) RADEONHD(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) RADEONHD(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) RADEONHD(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
(II) RADEONHD(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(II) RADEONHD(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(II) RADEONHD(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) RADEONHD(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(II) RADEONHD(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) RADEONHD(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
(II) RADEONHD(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(II) RADEONHD(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz)
(II) RADEONHD(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz)
(II) RADEONHD(0): Modeline "1280x960"x75.0 129.86 1280 1368 1504 1728 960 961 964 1002 -hsync +vsync (75.2 kHz)
(II) RADEONHD(0): Output VGA_1 connected
(II) RADEONHD(0): Output DVI-D_1 disconnected
(II) RADEONHD(0): Using exact sizes for initial modes
(II) RADEONHD(0): Output VGA_1 using initial mode 1920x1080
(II) RADEONHD(0): RandR 1.2 support enabled
(==) RADEONHD(0): RGB weight 888
(==) RADEONHD(0): Default visual is TrueColor
(==) RADEONHD(0): Using gamma correction (1.0, 1.0, 1.0)
(II) RADEONHD(0): Using 1920x1920 Framebuffer with 1920 pitch
(II) RADEONHD(0): FB: Allocated ScanoutBuffer at offset 0x00008000 (size = 0x00E10000)
(**) RADEONHD(0): Display dimensions: (480, 270) mm
(**) RADEONHD(0): DPI set to (101, 180)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
(II) Loading sub module "shadow"
(II) LoadModule: "shadow"
(II) Loading /usr/lib/xorg/modules//libshadow.so
(II) Module shadow: vendor="X.Org Foundation"
(II) RADEONHD(0): Using ShadowFB
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
(II) RADEONHD(0): Mapped FB @ 0xd0000000 to 0xa79a6000 (size 0x10000000)
(WW) RADEONHD(0): RHDCSInit: No CS for R600 and up yet.
(==) RADEONHD(0): Backing store disabled
(==) RADEONHD(0): Silken mouse enabled
(II) RADEONHD(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(II) RADEONHD(0): On Crtc 0 Setting 59.9 Hz Mode: Modeline "1920x1080" 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync
None
(II) RADEONHD(0): RHDAudioSetSupported: config 0x60040 codec 0x1
(II) RADEONHD(0): DPMS enabled
(--) RandR disabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) AIGLX: Screen 0 is not DRI2 capable
(II) AIGLX: Screen 0 is not DRI capable
(II) AIGLX: Loaded and initialized /usr/lib/xorg/modules/dri/swrast_dri.so
(II) GLX: Initialized DRISWRAST GL provider for screen 0
(II) RADEONHD(0): Setting screen physical size to 598 x 336
(II) config/hal: Adding input device Macintosh mouse button emulation
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input//evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.6.3, module version = 2.2.5
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 4.0
(**) Macintosh mouse button emulation: always reports core events
(**) Macintosh mouse button emulation: Device: "/dev/input/event0"
(II) Macintosh mouse button emulation: Found 3 mouse buttons
(II) Macintosh mouse button emulation: Found x and y relative axes
(II) Macintosh mouse button emulation: Configuring as mouse
(**) Macintosh mouse button emulation: YAxisMapping: buttons 4 and 5
(**) Macintosh mouse button emulation: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "Macintosh mouse button emulation" (type: MOUSE)
(**) Macintosh mouse button emulation: (accel) keeping acceleration scheme 1
(**) Macintosh mouse button emulation: (accel) filter chain progression: 2.00
(**) Macintosh mouse button emulation: (accel) filter stage 0: 20.00 ms
(**) Macintosh mouse button emulation: (accel) set acceleration profile 0
(II) Macintosh mouse button emulation: initialized for relative axes.
(II) config/hal: Adding input device Logitech USB Receiver
(**) Logitech USB Receiver: always reports core events
(**) Logitech USB Receiver: Device: "/dev/input/event2"
(II) Logitech USB Receiver: Found 12 mouse buttons
(II) Logitech USB Receiver: Found x and y relative axes
(II) Logitech USB Receiver: Found scroll wheel(s)
(II) Logitech USB Receiver: Found keys
(II) Logitech USB Receiver: Configuring as mouse
(II) Logitech USB Receiver: Configuring as keyboard
(**) Logitech USB Receiver: YAxisMapping: buttons 4 and 5
(**) Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "evdev"
(**) Option "xkb_layout" "us"
(**) Option "xkb_options" "terminate:ctrl_alt_bksp"
(**) Logitech USB Receiver: (accel) keeping acceleration scheme 1
(**) Logitech USB Receiver: (accel) filter chain progression: 2.00
(**) Logitech USB Receiver: (accel) filter stage 0: 20.00 ms
(**) Logitech USB Receiver: (accel) set acceleration profile 0
(II) Logitech USB Receiver: initialized for relative axes.
(**) Logitech USB Receiver: Device: "/dev/input/event1"
(II) RADEONHD(0): RHDHdmiUpdateAudioSettings: stoped with 1 channels, 48000 Hz sampling rate, 8 bits per sample,
(II) RADEONHD(0): RHDHdmiUpdateAudioSettings: 0x00 IEC60958 status bits and 0x00 category code
(II) RADEONHD(0): Using hsync ranges from config file
(II) RADEONHD(0): Using vrefresh ranges from config file
(II) Macintosh mouse button emulation: Close
(II) UnloadModule: "evdev"
(II) Logitech USB Receiver: Close
questo dopo la configurazione manuale , adesso ho rimosso xorg.conf , al prossimo riavvio vediamo che dice
