<BR>root@darkstar:~# et
<BR>ET 2.55 linux-i386 May 27 2003
<BR>----- FS_Startup -----
<BR>Current search path:
<BR>/root/.etwolf/etmain
<BR>/usr/local/games/enemy-territory/etmain/pak0.pk3 (3725 files)
<BR>/usr/local/games/enemy-territory/etmain/mp_bin.pk3 (4 files)
<BR>----------------------
<BR>3729 files in pk3 files
<BR>execing default.cfg
<BR>couldn´t exec language.cfg
<BR>couldn´t exec autoexec.cfg
<BR>Hunk_Clear: reset the hunk ok
<BR>------- Input Initialization -------
<BR>Joystick is not active.
<BR>------------------------------------
<BR>Bypassing CD checks
<BR>----- Client Initialization -----
<BR>----- Initializing Renderer ----
<BR>----- Client Initialization Complete -----
<BR>----- R_Init -----
<BR>...loading libGL.so.1: Initializing OpenGL display
<BR>...setting mode 4: 800 600
<BR>Using XFree86-VidModeExtension Version 2.2
<BR>Xlib: extension "XFree86-DGA" missing on display ":0.0".
<BR>Failed to detect XF86DGA Mouse
<BR>XFree86-VidModeExtension Activated at 800x600
<BR>Using 8/8/8 Color bits, 16 depth, 0 stencil display.
<BR>GL_RENDERER: Mesa GLX Indirect
<BR>***********************************************************
<BR>You are using software Mesa (no hardware acceleration)!
<BR>Driver DLL used: libGL.so.1
<BR>If this is intentional, add
<BR>"+set r_allowSoftwareGL 1"
<BR>to the command line when starting the game.
<BR>...WARNING: could not set the given mode (4)
<BR>Initializing OpenGL display
<BR>...setting mode 3: 640 480
<BR>XFree86-VidModeExtension Activated at 640x480
<BR>Received signal 11, exiting...
<BR>Capisco solo che ci sono problemi con la renderizzazione, ma non so come risolverli. Ovviamente con i vecchi driver ATI (usciti più di 1 anno fa, se ricordo bene) funzionava tutto alla perfezione.
<BR>Aiutatemi, vi prego!!!!
