Problema Bumblebee e Optirun
yAri
Nome Cognome: Yari Hembik
Slackware: 14.1
Kernel: 2.6
Messaggio da yAri »
Salve ragazzi. Sul mio netbook asus vx6 precisamente http://www.asus.it/Eee/Eee_PC/ASUSAUTOM ... ee_PC_VX6/,
avendo la scheda grafica integrata e nvidia ion ho deciso di provare bumblebee installando questi pacchetti: http://www.teoxonline.com/utils/Bumbleb ... are/README. e finalmente nvidia è riconosciuta (una volta avevo aperto un topic per l'installazione dei driver ma alla fine non ho più risolto: viewtopic.php?f=1&t=33754). L'output di lspci:
root@casa:~# lspci
00:00.0 Host bridge: Intel Corporation N10 Family DMI Bridge (rev 02)
00:02.0 VGA compatible controller: Intel Corporation N10 Family Integrated Graphics Controller (rev 02)
00:02.1 Display controller: Intel Corporation N10 Family Integrated Graphics Controller (rev 02)
00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 2 (rev 02)
00:1c.2 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 3 (rev 02)
00:1c.3 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 4 (rev 02)
00:1d.0 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
00:1f.0 ISA bridge: Intel Corporation NM10 Family LPC Controller (rev 02)
00:1f.2 SATA controller: Intel Corporation N10/ICH7 Family SATA AHCI Controller (rev 02)
00:1f.3 SMBus: Intel Corporation N10/ICH 7 Family SMBus Controller (rev 02)
01:00.0 USB Controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 03)
02:00.0 Ethernet controller: Atheros Communications AR8152 v2.0 Fast Ethernet (rev c1)
03:00.0 Network controller: Broadcom Corporation BCM4313 802.11b/g/n Wireless LAN Controller (rev 01)
05:00.0 VGA compatible controller: nVidia Corporation Device 0a76 (rev a2)
inoltre rc.bumblebee è eseguibile.
Il problema è questo: quando voglio lanciare qualcosa utilizzando nvidia (per esempio google chrome per vedere i video hd senza che scatti) mi da questo output:
root@casa:~# optirun google-chrome
The Bumblebee daemon has not been started. To start the daemon, run:
    sudo /etc/init.d/bumblebee start
The Bumblebee X server was not available, please check the
Bumblebee logfile at /var/log/bumblebee.log
root@casa:~#
Ho provato anche
/etc/rc.d/rc.bumblebee restart
ma nulla.
Questi invece sono i log:
[    600.74] Bumblebee log started at Mon, 20 Feb 2012 20:26:47 +0100
[    600.75] Creating fifo /var/run/bumblebee.fifo for communication...
[    600.79] Making FIFO writable for members of group bumblebee
[    600.80] Power management is disabled, not disabling card on start.
[    600.81] Waiting for orders
[    642.90] Bumblebee log started at Mon, 20 Feb 2012 20:27:29 +0100
[    642.91] Creating fifo /var/run/bumblebee.fifo for communication...
[    642.92] Making FIFO writable for members of group bumblebee
[    642.93] Power management is disabled, not disabling card on start.
[    642.94] Waiting for orders
[   1730.31] Checking for X server availability before stopping it...
[   1730.33] The X server has not started or the pidfile is invalid.
[   1730.34] X is stopped.
[   1730.35] Power management is disabled, not unloading driver
[   1730.36] Power management is disabled, card already enabled.
[   1730.40] Bumblebee log ended on Mon, 20 Feb 2012 20:45:36 +0100
Premetto che non sono esperto saprei fare solo le cose minime, sto ancora imparando, quindi chiedo la cortesia di descrivere i passaggi da fare.
Grazie mille per il vostro aiuto.
.. be the change you want to see in the world ..
teox99
Desktop: KDE - Xfce
Re: Problema Bumblebee e Optirun
Messaggio da teox99 »
ciao,
con pazienza disinstalla tutti i pacchetti di cui sopra,
ed usa quelli nuovi:
http://www.teoxonline.com/appunti.php?id=25
yAri
Slackware: 14.1
Kernel: 2.6
Messaggio da yAri »
Ok. Ho seguito la guida. Però...
root@casa:~# /etc/rc.d/rc.bumblebeed start
/etc/rc.d/rc.bumblebeed: line 46: /usr/sbin/bumblebeed: cannot execute binary file
root@casa:~#
e poi..
bash: /usr/bin/optirun: cannot execute binary file
root@casa:~#
quale sarà il problema?
Blallo
Nome Cognome: Savino Liguori
Slackware: 14.2 / 12.2
Kernel: 4.4.14-smp
Desktop: DWM
Messaggio da Blallo »
hai una slackware a 32bit?
Perché se si, i pacchetti di teox99 sono a 64 bit.
yAri
Slackware: 14.1
Kernel: 2.6
Messaggio da yAri »
si a 32 bit.. comunque questi http://www.teoxonline.com/appunti.php?id=25sembrano quelli a 32..
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
ehm..no.
Finiscono con x86_64 :D
yAri
Slackware: 14.1
Kernel: 2.6
Messaggio da yAri »
Ci sarà un modo per farli funzionare su slackware a 32?
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
no, bisogna ricompilare i sorgenti. Magari teox ha ancora gli slackbuilds...
yAri
Slackware: 14.1
Kernel: 2.6
Messaggio da yAri »
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
di quelli puoi installare solo virtualgl e i due kernel
teox99
Desktop: KDE - Xfce
non ho sistemi a 32 bit x ricompilare gli slackbuild,
dovresti farlo te da git
yAri
Slackware: 14.1
Kernel: 2.6
Messaggio da yAri »
Qualche indicazione ? magari qualche link possibilmente?
teox99
Desktop: KDE - Xfce
https://github.com/jgeboski/Bumblebee-SlackBuilds
logicamente devi sapere usare gli slackbuilds
(cerca nel wiki)
yAri
Slackware: 14.1
Kernel: 2.6
Messaggio da yAri »
Grazie mille vi farò sapere.
Gli sorgenti dove li trovo invece? (quelli tar.gz)
teox99
Desktop: KDE - Xfce
nei .info
