Problema scheda video Intel
joseph
Messaggio da joseph »
Buongiorno ragazzi, ieri ho acquistato un notebook HP 630 B815 ed ho provato subito ad installare Slackware 13.1
L'installazione va tutto a meraviglia, l'unico problema è quando avvio X.
Mi da questo errore:
(II) Loading extension XVideo
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
	compiled for 1.7.7, module version = 1.0.0
	ABI class: X.Org Server Extension, version 2.0
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "intel"
(II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
	compiled for 1.7.7, module version = 2.9.1
	ABI class: X.Org Video Driver, version 6.0
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
	i810-dc100, i810e, i815, i830M, 845G, 852GM/855GM, 865G, 915G,
	E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
	965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
	4 Series, G45/G43, Q45/Q43, G41, B43, Clarkdale, Arrandale
(II) Primary Device is: PCI 00@00:02:0
(EE) No devices detected.
Fatal server error:
no screens found
Il mio notebook monta questa scheda video:
00:02.0 VGA compatible controller: Intel Corporation Sandy Bridge Integrated Graphics Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Sandy Bridge Integrated Graphics Controller (rev 09) (prog-if 00 [VGA controller])
	Subsystem: Hewlett-Packard Company Device 3672
	Flags: bus master, fast devsel, latency 0, IRQ 7
	Memory at 90000000 (64-bit, non-prefetchable) [size=4M]
	Memory at 80000000 (64-bit, prefetchable) [size=256M]
	I/O ports at 4000 [size=64]
	Expansion ROM at <unassigned> [disabled]
	Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
	Capabilities: [d0] Power Management version 2
	Capabilities: [a4] PCI Advanced Features
facendo qualche ricerca su internet ho visto che il driver usato è "i915", che è correttamente caricato in "lsmod".
Inoltre vi posto di xorg.conf riguardante la scheda video:
Section "Monitor"
	Identifier   "Monitor0"
	VendorName   "Monitor Vendor"
	ModelName    "Monitor Model"
EndSection
Section "Device"
	Identifier  "Card0"
	Driver      "intel"
	BusID       "PCI:0:2:0"
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Card0"
	Monitor    "Monitor0"
	DefaultDepth 24
	SubSection "Display"
		Viewport   0 0
		Depth     24
		Modes     "1366x768"
	EndSubSection
EndSection
Section "DRI"
	Mode 0666
EndSection
Se nello xorg.conf carico i driver "vesa" X mi parte ma ottengo una risoluzione pessima!
Vi ringrazio tutti anticipatamente 8)
Blallo
Nome Cognome: Savino Liguori
Slackware: 14.2 / 12.2
Kernel: 4.4.14-smp
Desktop: DWM
Re: Problema scheda video Intel
Messaggio da Blallo »
Una sola domanda: perchè la 13.1 e non la 13.37?
joseph
Stesso problema. Ho provato anche la 13.17 ma il problema è analogo.
Avete qualche idea?
414N
Kernel: 5.15.19
Messaggio da 414N »
Dal listato che riporti sembra che il tuo sistema sia un core i5/i7 Sandy Bridge, ovvero con VGA integrata nel processore.
Il supporto a Sandy Bridge ha fatto passi da gigante negli ultimi kernel e mesa 8.0 (addirittura è già presente il supporto preliminare ad Ivy Bridge che non è ancora sul mercato), percui dovresti procurarti versioni aggiornate di almeno questi due pacchetti.
Per mesa, se vuoi, posso procurarti un pacchetto compilato da git qualche giorno fa su Slackware64 13.37.
joseph
Grazie a tutti per le risposte...Adesso sto provando a compilare un kernel 3.2.9, ho letto da qualche parte che dal kernel 2.6.37 in su non dovrebbe verificarsi questo problema...Provare per credere...
vi farò sapere grazie a tutti.
p.s.: 414N di che pacchetti parli ?
joseph
Niente da fare anche con il nuovo kernel 3.2.9 fa lo stesso problema...
Se cancello il file /etc/X11/xorg.conf mi parte in vesamode....
Qualche idea a riguardo? 414N che pacchetti dovrei aggiornare?
414N
Kernel: 5.15.19
Messaggio da 414N »
Dato che il problema è X, dovresti aggiornare xf86-video-intel in primis e poi mesa (che comporta anche l'aggiornamento di libdrm).
Dovresti essere in grado di pacchettizzare tutto quanto usando gli SlackBuild presenti nel ramo source/ di Slackware, modificando opportunamente le versioni.
A me sembra che hai semplicemente sbagliato driver. Probabilmente il driver 'intel' di X non è quello corretto per la tua scheda video. Potresti postare l'output di:
lspci -nnvv -s 00:02.0
Però forse è meglio l'intero Xorg.log.
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
prima di ricompilate "selvagge", prova i pacchetti del ramo testing
(sono per 64 bit)
libdrm: http://slackware.cs.utah.edu/pub/slackw ... 6_64-1.txz
mesa: http://slackware.cs.utah.edu/pub/slackw ... 6_64-1.txz
e prova a rimuovere/rinominare xorg.conf: dovrebbe riconoscere tutto in automatico.
joseph
Per spina:
Questo è il risultato di lspci
00:02.0 VGA compatible controller [0300]: Intel Corporation Sandy Bridge Integrated Graphics Controller [8086:0106] (rev 09) (prog-if 00 [VGA controller])
	Subsystem: Hewlett-Packard Company Device [103c:3672]
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 7
	Region 0: Memory at 90000000 (64-bit, non-prefetchable) [size=4M]
	Region 2: Memory at 80000000 (64-bit, prefetchable) [size=256M]
	Region 4: I/O ports at 4000 [size=64]
		Address: 00000000  Data: 0000
		Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
		Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
		AFCap: TP+ FLR+
		AFCtrl: FLR-
		AFStatus: TP-
Questo invece è il log intero di Xorg:
X.Org X Server 1.7.7
Release Date: 2010-05-04
Build Operating System: Slackware 13.1 Slackware Linux Project
Current Operating System: Linux darkstar 2.6.33.4-smp #2 SMP Wed May 12 22:47:36 CDT 2010 i686
Kernel command line: BOOT_IMAGE=Linux ro root=801 vt.default_utf8=1
Build Date: 05 May 2010  01:54:53AM
Current version of pixman: 0.16.6
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Mar  2 13:37:02 2012
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(**) Option "AllowEmptyInput" "off"
(**) Option "AutoAddDevices" "False"
(**) Not automatically adding devices
(WW) The directory "/usr/share/fonts/local" does not exist.
	Entry deleted from font path.
(WW) The directory "/usr/share/fonts/CID" does not exist.
(**) FontPath set to:
	/usr/share/fonts/TTF,
	/usr/share/fonts/OTF,
	/usr/share/fonts/Type1,
	/usr/share/fonts/misc,
	/usr/share/fonts/75dpi,
	/usr/share/fonts/100dpi,
	/usr/share/fonts/cyrillic,
(**) ModulePath set to "/usr/lib/xorg/modules"
(II) Loader magic: 0x81e4c80
(II) Module ABI versions:
	X.Org ANSI C Emulation: 0.4
	X.Org Video Driver: 6.0
	X.Org XInput driver : 7.0
	X.Org Server Extension : 2.0
(--) using VT number 7
(--) PCI:*(0:0:2:0) 8086:0106:103c:3672 rev 9, Mem @ 0x90000000/4194304, 0x80000000/268435456, I/O @ 0x00004000/64
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri2" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
	compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(==) AIGLX enabled
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
	compiled for 1.7.5, module version = 1.5.0
	Module class: X.Org XInput Driver
	ABI class: X.Org XInput driver, version 7.0
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
	compiled for 1.7.5, module version = 1.4.0
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
Per quanto riguarda jimmy, uso un sistema a 32bit e rinominando/rimuovendo xorg.conf funziona X ma con i driver vesa.
Unica risoluzione disponibile 1024x768 e si vede anche malissimo.
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
joseph
Niente da fare, nemmeno aggiornando questi due pacchetti ho risolto.
Il problema è sempre lo stesso, l'errore nello xorg è analogo e rinominando xorg.conf ottengo sempre X in vesa mode.
A questo punto mi sorge un dubbio, secondo me come dice spina il driver che carica non è quello adatto.
Hai provato altre distro?
E' piuttosto strano, perché sin da slackware 13.1 non dovresti mettere mano a nessun file di configurazione. Se la VGA è supportata, Xorg dovrebbe caricare automaticamente il driver corretto.
Prova ad eliminare/spostare il file xorg.conf e a postare il log di X una volta lanciata la sessione grafica. Anche dmesg potrebbe aiutare a capire se succede qualcosa di strano.
Invece mi sa che il driver è quello giusto!!! Sarebbe carino capire come mai non ti trova il device. Come mai hai disabilitato l'auto-detection dei device?:
Effettivamente, come già suggerito, provare a partire con un Xorg senza file di configurazione potrebbe risolvere. Inoltre, c'è questa opzione per Xorg ce potrebbe darti una mano:
-configure
  When this option is specified, the Xorg server loads all  video  driver  modules,
  probes  for  available  hardware,  and  writes  out  an  initial xorg.conf(5)  file
  based  on  what was detected.  This option currently has some problems on
  some platforms, but in most cases it is a good way to bootstrap the configuration
  process.  This option is only available when the server is run as root (i.e, with real-uid 0).
Infine, l'output completo di lspci? Cosa dice? Non è che hai due schede video?
joseph
A dire il vero appena acquistato c'era installato suse e funzionava benissimo...non sono amante di queste distro...comunque appena possibile vi posto xorg.log dopo aver cancellato xorg.conf... Ho aggiunto quelle righe perché non mi funzionava muose e tastiera...perdonatemi sto dal cell appena possibile vi posto tutto
