ottimizzare disco
ottimizzare disco
Il mio nuovo portatile me lo hanno dato con una tabella delle partizioni che a fdisk non piace molto:
root@matteo:/home/matteo/DELL# echo -e "p\nx\np"|fdisk /dev/sda
The device presents a logical sector size that is smaller than
the physical sector size. Aligning to a physical sector (or optimal
I/O) size boundary is recommended, or performance may be impacted.
Command (m for help):
Disk /dev/sda: 750.2 GB, 750156374016 bytes
255 heads, 63 sectors/track, 91201 cylinders, total 1465149168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x07f2837e
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1              63      208844      104391   de  Dell Utility
Partition 1 does not start on physical sector boundary.
/dev/sda2   *      212992    41172991    20480000    7  HPFS/NTFS/exFAT
/dev/sda3        41172992   850747119   404787064    7  HPFS/NTFS/exFAT
/dev/sda4       850747392  1465145343   307198976    f  W95 Ext'd (LBA)
/dev/sda5       850749440   877373439    13312000   82  Linux swap
/dev/sda6       877375488  1465145343   293884928   83  Linux
Expert command (m for help):
Disk /dev/sda: 255 heads, 63 sectors, 91201 cylinders
Nr AF  Hd Sec  Cyl  Hd Sec  Cyl     Start      Size ID
 1 00   1   1    0 254  63   12         63     208782 de
 2 80  65  53   13 254  63 1023     212992   40960000 07
 3 00 254  63 1023 254  63 1023   41172992  809574128 07
 4 00 254  63 1023 254  63 1023  850747392  614397952 0f
 5 00 254  63 1023 254  63 1023       2048   26624000 82
 6 00 254  63 1023 254  63 1023       2048  587769856 83
(quelle linux le ho aggiunte io)
Sto per rimuovere le prime due partizioni (sda1 e sda2). Poi che ottimizzazioni posso fare?
