scheda wireless broadcom non riconosciuta
Procopio
Kernel: 4.4.14
Desktop: Awesome
Messaggio da Procopio »
Ciao a tutti!
mi trovo con un Dell Latitude e5500 nel tentativo di configurarne la connessione wireless.
I costruttori hanno avuto la bella idea su questo modello di assegnare un unico pulsante per l'attivazione del bluethoot e della scheda wireless, però, ovviamente, quando lo accendo vedo illuminarsi solamente la spia del bluethoot, e il wireless resta spento...
ho già installato il wicd che non trova alcuna rete wireless, inoltre il file /etc/rc.d/rc.inet1.conf sembra in regola
root@darkstar:/home/juliet# cat /etc/rc.d/rc.inet1.conf
# /etc/rc.d/rc.inet1.conf
# This file contains the configuration settings for network interfaces.
# If USE_DHCP[interface] is set to "yes", this overrides any other settings.
# If you don't have an interface, leave the settings null ("").
# You can configure network interfaces other than eth0,eth1... by setting
# IFNAME[interface] to the interface's name. If IFNAME[interface] is unset
# or empty, it is assumed you're configuring eth<interface>.
# Several other parameters are available, the end of this file contains a
# comprehensive set of examples.
# Config information for eth0:
IPADDR[0]=""
NETMASK[0]=""
USE_DHCP[0]="yes"
DHCP_HOSTNAME[0]=""
# Config information for eth1:
IPADDR[1]=""
NETMASK[1]=""
USE_DHCP[1]=""
DHCP_HOSTNAME[1]=""
# Config information for eth2:
IPADDR[2]=""
NETMASK[2]=""
USE_DHCP[2]=""
DHCP_HOSTNAME[2]=""
# Config information for eth3:
IPADDR[3]=""
NETMASK[3]=""
USE_DHCP[3]=""
DHCP_HOSTNAME[3]=""
# Default gateway IP address:
GATEWAY=""
# Change this to "yes" for debugging output to stdout.  Unfortunately,
# /sbin/hotplug seems to disable stdout so you'll only see debugging output
# when rc.inet1 is called directly.
DEBUG_ETH_UP="no"
## Example config information for wlan0.  Uncomment the lines you need and fill
## in your data.  (You may not need all of these for your wireless network)
#IFNAME[4]="wlan0"
#IPADDR[4]=""
#NETMASK[4]=""
#USE_DHCP[4]="yes"
#DHCP_HOSTNAME[4]="icculus-wireless"
#DHCP_KEEPRESOLV[4]="yes"
#DHCP_KEEPNTP[4]="yes"
#DHCP_KEEPGW[4]="yes"
#DHCP_IPADDR[4]=""
#WLAN_ESSID[4]=DARKSTAR
#WLAN_MODE[4]=Managed
#WLAN_RATE[4]="54M auto"
#WLAN_CHANNEL[4]="auto"
#WLAN_KEY[4]="D5A31F54ACF0487C2D0B1C10D2"
#WLAN_IWPRIV[4]="set AuthMode=WPAPSK | set EncrypType=TKIP | set WPAPSK=96389dc66eaf7e6efd5b5523ae43c7925ff4df2f8b7099495192d44a774fda16"
#WLAN_WPA[4]="wpa_supplicant"
#WLAN_WPADRIVER[4]="wext"
#WLAN_WPAWAIT[4]=30
## Some examples of additional network parameters that you can use.
## Config information for wlan0:
#IFNAME[4]="wlan0"              # Use a different interface name instead of
                                # the default 'eth4'
#IFNAME[4]="eth0:1"             # Set up an IP alias.
#HWADDR[4]="00:01:23:45:67:89"  # Overrule the card's hardware MAC address
#MTU[4]=""                      # The default MTU is 1500, but you might need
                                # 1360 when you use NAT'ed IPSec traffic.
#DHCP_TIMEOUT[4]=15             # The default timeout for the DHCP client to
                                # wait for server resonse is 10 seconds, but
                                # you might want a shorter or longer wait.
#DHCP_KEEPRESOLV[4]="yes"       # If you dont want /etc/resolv.conf overwritten
#DHCP_KEEPNTP[4]="yes"          # If you don't want ntp.conf overwritten
#DHCP_KEEPGW[4]="yes"           # If you don't want the DHCP server to change
                                # your default gateway
#DHCP_IPADDR[4]=""              # Request a specific IP address from the DHCP
                                # server
#DHCP_DEBUG[4]="yes"            # Make dhcpcd show verbose diagnostics
#DHCP_NOIPV4LL[4]="yes"         # Do not assign an ipv4ll address when a DHCP
                                # server is not found (ipv4ll link-local
                                # adresses in the IP range 169.254.0.0/16 are
                                # also known as "zeroconf" addresses)
#WLAN_ESSID[4]=DARKSTAR         # An example of how you can override _any_
                                # parameter defined in rc.wireless.conf, by
                                # prepending 'WLAN_' to the parameter's name.
                                # Useful with multiple wireless interfaces.
#WLAN_IWPRIV[4]="set AuthMode=WPAPSK | set EncrypType=TKIP | set WPAPSK=thekey"
                                # Some drivers require a private ioctl to be
                                # set through the iwpriv command. If more than
                                # one is required, you can place them in the
                                # IWPRIV parameter (separated with the pipe (|)
                                # character, see the example).
#WLAN_WPA[4]="wpa_supplicant"   # Run wpa_supplicant for WPA support
#WLAN_WPADRIVER[4]="ndiswrapper"# Tell wpa_supplicant to specifically use the
                                # ndiswrapper driver (if you leave this empty
                                # the 'wext' driver is used by default)
#WLAN_WPAWAIT[4]=30             # In case it takes long for the WPA association
                                # to finish, you can increase the wait time
                                # (defaults to 10 seconds)
sinceramente non sono neanche riuscito a capire con esattezza quale sia il modello della scheda wireless perchè il comando lspci non mi è chiaro, infatti mi sembra restituire solo l'output di una scheda wired, ma giudicate voi
root@darkstar:/home/juliet# lspci -v
00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
        Subsystem: Dell Device 0263
        Flags: bus master, fast devsel, latency 0
        Capabilities: [e0] Vendor Specific Information: Len=0a <?>
        Kernel driver in use: agpgart-intel
        Kernel modules: intel-agp
00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07) (prog-if 00 [VGA controller])
        Flags: bus master, fast devsel, latency 0, IRQ 42
        Memory at f6c00000 (64-bit, non-prefetchable) [size=4M]
        Memory at e0000000 (64-bit, prefetchable) [size=256M]
        I/O ports at efe8 [size=8]
        Expansion ROM at <unassigned> [disabled]
        Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [d0] Power Management version 3
        Kernel driver in use: i915
        Kernel modules: i915
00:02.1 Display controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
        Memory at f6b00000 (64-bit, non-prefetchable) [size=1M]
00:1a.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 02) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 20
        I/O ports at 6f60 [size=32]
        Capabilities: [50] PCI Advanced Features
        Kernel driver in use: uhci_hcd
        Kernel modules: uhci-hcd
00:1a.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 02) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 21
        I/O ports at 6f80 [size=32]
00:1a.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 02) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 22
        I/O ports at 6fa0 [size=32]
00:1a.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 02) (prog-if 20 [EHCI])
        Memory at fed1c400 (32-bit, non-prefetchable) [size=1K]
        Capabilities: [50] Power Management version 2
        Capabilities: [58] Debug port: BAR=1 offset=00a0
        Capabilities: [98] PCI Advanced Features
        Kernel driver in use: ehci_hcd
        Kernel modules: ehci-hcd
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 02)
        Flags: bus master, fast devsel, latency 0, IRQ 41
        Memory at f6afc000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
        Capabilities: [100] Virtual Channel
        Capabilities: [130] Root Complex Link
        Kernel driver in use: HDA Intel
        Kernel modules: snd-hda-intel
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 02) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
        I/O behind bridge: 00002000-00002fff
        Memory behind bridge: 84000000-841fffff
        Prefetchable memory behind bridge: 0000000084200000-00000000843fffff
        Capabilities: [40] Express Root Port (Slot+), MSI 00
        Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
        Capabilities: [90] Subsystem: Dell Device 0263
        Capabilities: [a0] Power Management version 2
        Capabilities: [180] Root Complex Link
        Kernel modules: shpchp
00:1c.1 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 2 (rev 02) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=0c, subordinate=0c, sec-latency=0
        I/O behind bridge: 00003000-00003fff
        Memory behind bridge: 84400000-845fffff
        Prefetchable memory behind bridge: 0000000084600000-00000000847fffff
00:1c.4 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 5 (rev 02) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
        I/O behind bridge: 00004000-00004fff
        Memory behind bridge: f6900000-f69fffff
        Prefetchable memory behind bridge: 0000000084800000-00000000849fffff
00:1d.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 02) (prog-if 00 [UHCI])
        I/O ports at 6f00 [size=32]
00:1d.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 02) (prog-if 00 [UHCI])
        I/O ports at 6f20 [size=32]
00:1d.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 02) (prog-if 00 [UHCI])
        I/O ports at 6f40 [size=32]
00:1d.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 02) (prog-if 20 [EHCI])
        Memory at fed1c000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 92) (prog-if 01 [Subtractive decode])
        Bus: primary=00, secondary=02, subordinate=06, sec-latency=32
        I/O behind bridge: 00005000-00005fff
        Memory behind bridge: f6800000-f68fffff
        Prefetchable memory behind bridge: 0000000080000000-0000000083ffffff
        Capabilities: [50] Subsystem: Dell Device 0263
00:1f.0 ISA bridge: Intel Corporation ICH9M LPC Interface Controller (rev 02)
        Capabilities: [e0] Vendor Specific Information: Len=0c <?>
        Kernel modules: iTCO_wdt
00:1f.2 SATA controller: Intel Corporation ICH9M/M-E SATA AHCI Controller (rev 02) (prog-if 01 [AHCI 1.0])
        Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 40
        I/O ports at 6e70 [size=8]
        I/O ports at 6e78 [size=4]
        I/O ports at 6e80 [size=8]
        I/O ports at 6e88 [size=4]
        I/O ports at 6ea0 [size=32]
        Memory at fed1c800 (32-bit, non-prefetchable) [size=2K]
        Capabilities: [80] MSI: Enable+ Count=1/16 Maskable- 64bit-
        Capabilities: [70] Power Management version 3
        Capabilities: [a8] SATA HBA v1.0
        Capabilities: [b0] PCI Advanced Features
        Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 02)
        Flags: medium devsel, IRQ 19
        Memory at f6afbf00 (64-bit, non-prefetchable) [size=256]
        I/O ports at 1100 [size=32]
        Kernel driver in use: i801_smbus
        Kernel modules: i2c-i801
02:01.0 CardBus bridge: Ricoh Co Ltd RL5c476 II (rev ba)
        Flags: bus master, medium devsel, latency 168, IRQ 19
        Memory at f6800000 (32-bit, non-prefetchable) [size=4K]
        Bus: primary=02, secondary=03, subordinate=06, sec-latency=176
        Memory window 0: 80000000-83fff000 (prefetchable)
        Memory window 1: 88000000-8bfff000
        I/O window 0: 00005000-000050ff
        I/O window 1: 00005400-000054ff
        16-bit legacy interface ports at 0001
        Kernel driver in use: yenta_cardbus
        Kernel modules: yenta_socket
02:01.1 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller (rev 04) (prog-if 10 [OHCI])
        Flags: bus master, medium devsel, latency 64, IRQ 17
        Memory at f68ff800 (32-bit, non-prefetchable) [size=2K]
        Capabilities: [dc] Power Management version 2
        Kernel driver in use: firewire_ohci
        Kernel modules: firewire-ohci
02:01.2 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 21) (prog-if 01)
        Flags: bus master, medium devsel, latency 64, IRQ 18
        Memory at f68ff700 (32-bit, non-prefetchable) [size=256]
        Capabilities: [80] Power Management version 2
        Kernel driver in use: sdhci-pci
        Kernel modules: sdhci-pci
09:00.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5761e Gigabit Ethernet PCIe (rev 10)
        Flags: bus master, fast devsel, latency 0, IRQ 43
        Memory at f69e0000 (64-bit, non-prefetchable) [size=64K]
        Memory at f69f0000 (64-bit, non-prefetchable) [size=64K]
        Capabilities: [48] Power Management version 3
        Capabilities: [40] Vital Product Data
        Capabilities: [60] Vendor Specific Information: Len=6c <?>
        Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [cc] Express Endpoint, MSI 00
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [13c] Virtual Channel
        Capabilities: [160] Device Serial Number 00-23-ae-ff-fe-1f-ec-51
        Capabilities: [16c] Power Budgeting <?>
        Kernel driver in use: tg3
        Kernel modules: tg3
la cosa che mi spaventa di più è che non c'è alcuna traccia di schede wireless neppure da iwconfig
root@darkstar:/home/juliet# iwconfig
lo        no wireless extensions.
eth0      no wireless extensions.
Ho pensato che manchino i driver (ma correggetemi voi perchè potrò sbagliare!!) per questo tipo di scheda (che ipotizzo essere una BCM5761). Non sono sicuro di questi drivers che ho trovato sul sito (non mi fa neanche scegliere tra 32 e 64 bit [-( ), poi ipotizzando che siano quelli corretti pensavo di seguire questa guida riadattandola ovviamente al mio driver, che ne dite?? chiedetemi pure altre informazioni sull'hardware, qui ne ho messe solo alcune!!!
zoros
Nome Cognome: Fabio`Zorba`
Kernel: 5.15.19smp
Desktop: Trinity R14.0.11
Re: scheda wireless broadcom non riconosciuta
Messaggio da zoros »
su un altro forum si trova:
$ lspci -nn | grep Broadcom
09:00.0 Ethernet controller [0200]: Broadcom Corporation NetXtreme BCM5756ME Gigabit Ethernet PCI Express [14e4:1674]
0c:00.0 Network controller [0280]: Broadcom Corporation BCM4322 802.11a/b/g/n Wireless LAN Controller [14e4:432b] (rev 01)
hai messo un sacco di info in più, difficile leggere ... a me sembra non ci sia nel tuo post alcun riferimento alla wireless, che in teoria è una BCM4322 :-k ...
Procopio
Kernel: 4.4.14
Desktop: Awesome
zoros ha scritto:a me sembra non ci sia nel tuo post alcun riferimento alla wireless, che in teoria è una BCM4322 :-k ...
infatti quel comando mi restituisce solo questo:
root@darkstar:/home/juliet# lspci -nn | grep Broadcom
09:00.0 Ethernet controller [0200]: Broadcom Corporation NetXtreme BCM5761e Gigabit Ethernet PCIe [14e4:1680] (rev 10)
però con vista, che è il sistema con cui era fornito il pc, funzionava, quindi da qualche parte c'è (se non è direttamente quella)
io penso che senza il driver la scheda wireless non sia vista neanche da lspci, oltre che dall'iwconfig, se fosse così questo spiegherebbe perchè non c'è traccia di schede wireless in quei due comandi.
Oppure dato che quel grep cercava la Broadcom magari la scheda wireless non è broadcom...ma è possibile che ci siano due schede di rete per giunta di due marche differenti?? non penso proprio.....
ad ogni modo se nessuno mi sa dire che fare o fornire informazioni più certe tento di installare quel driver di cui sopra, ma mi sembra un operazione molto aleatoria....
zoros
Kernel: 5.15.19smp
allora,
è molto improbabile che lspci non veda la scheda per mancanza del driver ... per prima cosa dovresti togliere la batteria, riattaccandola dopo alcuni minuti ;) ...poi rimuovi:
# rm /etc/udev/rules.d/70-persistent-net.rules
e riavvia il pc
Anche a me sembra una scheda Gigabit.
A giudicare anche dal link ai driver: è il modulo tg3, già incluso nel kernel (anche se sembra più recente).
Se poi è il kernel che "canna" il device, ne so meno di voi.
zoros
Kernel: 5.15.19smp
sì,
vede la sola scheda ethernet, la wireless è sicuramente un'altra, probabilmente "inceppata", seguendo il "consigli" dovrebbe "riapparire" :D ...
Procopio
Kernel: 4.4.14
Desktop: Awesome
ho tolto la batteria e aspettato anche più di qualche minuto, dopo di che ho acceso e rimosso /etc/udev/rules.d/70-persistent-net.rules ma al riavvio lspci continua a non vedermi la scheda wireless:
o anche con l'altro lspci più completo:
        Kernel modules: tg3
(questa volta ho riportato solo la parte riguardante la scheda di rete, se vuoi anche altri dettagli te li posto!)
SIV
Messaggio da SIV »
Offtopic: Scusa zoros ma i consigli cosa fanno tecnicamente?
zoros
Kernel: 5.15.19smp
SIV ha scritto:Offtopic: Scusa zoros ma i consigli cosa fanno tecnicamente?
in genere il driver carica un firmware sulla scheda wireless, comunque driver e firmware non sono necessari al riconoscimento della scheda ... si è visto però in alcuni casi che il microprogramma "firmware" può inceppare la scheda rendendola non più visibile già all'avvio (da bios?)... anche con pc spento una parte dei componenti rimane alimentata mantenendo la condizione di blocco ... evidentemente non è questo il caso :-k ...
in un altro caso simile la rimozione di 70-persistent-net.rules ha fatto (misteriosamente) riapparire la scheda al comando lspci (problema sw?) ... evidentemente non è neanche questo il caso :-k ...
@Procopio: il pc avrà un bios? se entri nel bios ritrovi in qualche modo dei riferimenti alla scheda wireless? (ciò che vedi da lspci è solo la ethernet)
Bene, questo sembra un problema interessante. Sul mio vecchio PC lspci non mi mostrava il lettore di schede SD e neanche del bluetooth, poi scopri scopri, l'avevo disabilitato io da BIOS. Quindi potrebbe essere lo stesso problema.
Altra idea. Non è che c'è un pulsante che fisicamente disabilità la scheda?
In ogni caso, postaci un 'dmesg'.
Procopio
Kernel: 4.4.14
Desktop: Awesome
Eh no, c'è un pulsante unico con il sombolo dell'antenna wireless stampigliato sopra che serve ad attivare sia la ricezione wireless che quella bluethoot...quel pulsante ha due posizioni, (che credo siano on e off, perchè una delle due scopre uno spazio rosso sotto il pulsante, mentre l'altra posizione lascia scoperto uno spazietto nero...quindi non c'è una posizione per il bluethoot e una per il wireless, ma l'on accende tutte e due le ricezioni e l'off le spegne...) Il fatto è che quando lo posiziono su on mi si accende solo la spia del bluethoot mentre quella wireless resta spenta... Ora sull'altro mio computer (il vaio), quando non ho impostato la connessione automatica al wireless, anche se metto il pulsante della ricezione in posizione on la spia del wireless non si accende, ma quando apro il wicd allora la spia si accende e mi rileva la rete...in questo caso (cioè sul dell) invece no...stasera appena arrivo a casa faccio il tentativo sul bios e vi faccio sapere
fAu
Slackware: slackware64 current
Kernel: 4.19.82
Desktop: kde 4.14.38
Messaggio da fAu »
sono nella tua stessa situazione con un asus 1225b siv055m ma nel mio caso la scheda e' una bcm4313
da quel che ho letto l'unica soluzione e' il driver propietario
http://www.broadcom.com/support/802.11/linux_sta.php
se hai una current con kernel 3.2 sembra vadano patchati i sorgenti
http://www.linuxquestions.org/questions ... -a-930546/
http://www.linuxquestions.org/questions ... rt-927384/
prova a fare un lsmod e probabilmente vedrai i moduli che dicono vadano blacklistati
p.s. io non ci ho ancora messo mano...
Meskalamdug
Messaggio da Meskalamdug »
La soluzione è semplice.
Aggiornate all'ultimo kernel inclusi i firmware
o provate ad aggiornare solo i firmware.
Procopio
Kernel: 4.4.14
Desktop: Awesome
ho controllato: dal bios la scheda audio risulta abilitata, quindi purtroppo non era quello....
ad ogni modo il dmesg è questo:
root@darkstar:/home/juliet# dmesg
-0x849fffff 64bit pref]
[    0.510148] pci_bus 0000:02: resource 0 [io  0x5000-0x5fff]
[    0.510151] pci_bus 0000:02: resource 1 [mem 0xf6800000-0xf68fffff]
[    0.510153] pci_bus 0000:02: resource 2 [mem 0x80000000-0x83ffffff pref]
[    0.510155] pci_bus 0000:02: resource 4 [io  0x0000-0x0cf7]
[    0.510158] pci_bus 0000:02: resource 5 [io  0x0d00-0xffff]
[    0.510160] pci_bus 0000:02: resource 6 [mem 0x000a0000-0x000bffff]
[    0.510162] pci_bus 0000:02: resource 7 [mem 0x000d0000-0x000dffff]
[    0.510164] pci_bus 0000:02: resource 8 [mem 0x80000000-0xf7ffffff]
[    0.510167] pci_bus 0000:02: resource 9 [mem 0xfc000000-0xfebfffff]
[    0.510169] pci_bus 0000:02: resource 10 [mem 0xfec10000-0xfecfffff]
[    0.510171] pci_bus 0000:02: resource 11 [mem 0xfed1c000-0xfed1ffff]
[    0.510174] pci_bus 0000:02: resource 12 [mem 0xfed90000-0xfed9ffff]
[    0.510176] pci_bus 0000:02: resource 13 [mem 0xfed40000-0xfed44fff]
[    0.510178] pci_bus 0000:02: resource 14 [mem 0xfeda7000-0xfedfffff]
[    0.510180] pci_bus 0000:02: resource 15 [mem 0xfee10000-0xffa7ffff]
[    0.510183] pci_bus 0000:02: resource 16 [mem 0xffc00000-0xffe7ffff]
[    0.510185] pci_bus 0000:03: resource 0 [io  0x5000-0x50ff]
[    0.510188] pci_bus 0000:03: resource 1 [io  0x5400-0x54ff]
[    0.510191] pci_bus 0000:03: resource 2 [mem 0x80000000-0x83ffffff pref]
[    0.510194] pci_bus 0000:03: resource 3 [mem 0x88000000-0x8bffffff]
[    0.510223] NET: Registered protocol family 2
[    0.510342] IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.510695] TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
[    0.512598] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.513166] TCP: Hash tables configured (established 262144 bind 65536)
[    0.513250] TCP reno registered
[    0.513330] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.513428] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.513632] NET: Registered protocol family 1
[    0.513824] RPC: Registered udp transport module.
[    0.513910] RPC: Registered tcp transport module.
[    0.513990] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.514087] pci 0000:00:02.0: Boot video device
[    0.514445] PCI: CLS 64 bytes, default 64
[    0.515228] Intel AES-NI instructions are not detected.
[    0.515513] audit: initializing netlink socket (disabled)
[    0.515603] type=2000 audit(1336506225.513:1): initialized
[    0.519023] VFS: Disk quotas dquot_6.5.2
[    0.519171] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.519510] DLM (built Apr  9 2011 22:44:24) installed
[    0.520548] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.520930] NTFS driver 2.1.29 [Flags: R/W].
[    0.521131] ROMFS MTD (C) 2007 Red Hat, Inc.
[    0.521401] JFS: nTxBlock = 8192, nTxLock = 65536
[    0.524411] SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled
[    0.525261] SGI XFS Quota Management subsystem
[    0.525346] OCFS2 1.5.0
[    0.525586] ocfs2: Registered cluster interface o2cb
[    0.525744] ocfs2: Registered cluster interface user
[    0.525826] OCFS2 DLMFS 1.5.0
[    0.525975] OCFS2 User DLM kernel interface loaded
[    0.526057] OCFS2 Node Manager 1.5.0
[    0.526277] OCFS2 DLM 1.5.0
[    0.527306] Btrfs loaded
[    0.527779] GFS2 (built Apr  9 2011 22:45:04) installed
[    0.527883] msgmni has been set to 3905
[    0.528724] async_tx: api initialized (async)
[    0.528930] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[    0.529062] io scheduler noop registered
[    0.529142] io scheduler deadline registered
[    0.529288] io scheduler cfq registered (default)
[    0.529639] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.529939] intel_idle: MWAIT substates: 0x22220
[    0.529942] intel_idle: does not run on family 6 model 15
[    0.529998] ERST: Table is not found!
[    0.533362] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.798084] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.850790] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.859125] Floppy drive(s): fd0 is 1.44M
[    3.869118] floppy0: no floppy controllers found
[    3.871234] brd: module loaded
[    3.872264] loop: module loaded
[    3.872342] Compaq SMART2 Driver (v 2.6.0)
[    3.872489] HP CISS Driver (v 3.6.26)
[    3.873147] Loading iSCSI transport class v2.0-870.
[    3.873628] fnic: Cisco FCoE HBA Driver, ver 1.4.0.145
[    3.874138] Adaptec aacraid driver 1.1-5[26400]-ms
[    3.874359] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded
[    3.874674] scsi: <fdomain> Detection failed (no card)
[    3.874802] QLogic Fibre Channel HBA Driver: 8.03.05-k0
[    3.874973] iscsi: registered transport (qla4xxx)
[    3.875093] QLogic iSCSI HBA Driver
[    3.875172] Emulex LightPulse Fibre Channel SCSI driver 8.3.18
[    3.875253] Copyright(c) 2004-2009 Emulex.  All rights reserved.
[    3.875382] Brocade BFA FC/FCOE SCSI driver - version: 2.3.2.0
[    3.875643] DC390: clustering now enabled by default. If you get problems load
[    3.875755]        with "disable_clustering=1" and report to maintainers
[    3.875914] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
[    3.876199] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[    3.876318] megasas: 00.00.04.31-rc1 Mon. May 3, 11:41:51 PST 2010
[    3.876441] mpt2sas version 06.100.00.00 loaded
[    3.876640] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[    3.876821] 3ware Storage Controller device driver for Linux v1.26.02.003.
[    3.876937] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[    3.877118] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[    3.877268] ipr: IBM Power RAID SCSI Device Driver version: 2.5.1 (August 10, 2010)
[    3.877421] RocketRAID 3xxx/4xxx Controller driver v1.6 (090910)
[    3.877536] stex: Promise SuperTrak EX Driver version: 4.6.0000.4
[    3.877754] st: Version 20100829, fixed bufsize 32768, s/g segs 256
[    3.878014] ahci 0000:00:1f.2: version 3.0
[    3.878030] ahci 0000:00:1f.2: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[    3.878167] ahci 0000:00:1f.2: irq 40 for MSI/MSI-X
[    3.878218] ahci: SSS flag set, parallel bus scan disabled
[    3.878338] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 4 ports 3 Gbps 0x33 impl SATA mode
[    3.878454] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio slum part ccc ems
[    3.878572] ahci 0000:00:1f.2: setting latency timer to 64
[    3.885073] scsi0 : ahci
[    3.885306] scsi1 : ahci
[    3.885494] scsi2 : ahci
[    3.885686] scsi3 : ahci
[    3.885871] scsi4 : ahci
[    3.886065] scsi5 : ahci
[    3.886419] ata1: SATA max UDMA/133 abar m2048@0xfed1c800 port 0xfed1c900 irq 40
[    3.886534] ata2: SATA max UDMA/133 abar m2048@0xfed1c800 port 0xfed1c980 irq 40
[    3.886647] ata3: DUMMY
[    3.886724] ata4: DUMMY
[    3.886802] ata5: SATA max UDMA/133 abar m2048@0xfed1c800 port 0xfed1cb00 irq 40
[    3.886916] ata6: SATA max UDMA/133 abar m2048@0xfed1c800 port 0xfed1cb80 irq 40
[    3.889681] scsi6 : pata_legacy
[    3.889858] ata7: PATA max PIO4 cmd 0x1f0 ctl 0x3f6 irq 14
[    4.192021] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    4.237930] ata1.00: ATA-8: WDC WD800BEVT-75ZCT2, 11.01A11, max UDMA/133
[    4.238018] ata1.00: 156301488 sectors, multi 8: LBA48 NCQ (depth 31/32), AA
[    4.239116] ata1.00: configured for UDMA/133
[    4.239312] scsi 0:0:0:0: Direct-Access     ATA      WDC WD800BEVT-75 11.0 PQ: 0 ANSI: 5
[    4.239643] sd 0:0:0:0: [sda] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[    4.239898] sd 0:0:0:0: [sda] Write Protect is off
[    4.239979] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    4.240016] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.276578]  sda: sda1 sda2 < sda5 >
[    4.277006] sd 0:0:0:0: [sda] Attached SCSI disk
[    4.963024] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    4.980013] ata2.00: ATAPI: TSSTcorp DVD+/-RW TS-L633B, D200, max UDMA/100
[    4.980098] ata2.00: applying bridge limits
[    4.997371] ata2.00: configured for UDMA/100
[    5.000657] scsi 1:0:0:0: CD-ROM            TSSTcorp DVD+-RW TS-L633B D200 PQ: 0 ANSI: 5
[    5.006710] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[    5.006825] cdrom: Uniform CD-ROM driver Revision: 3.20
[    5.007057] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    5.312019] ata5: SATA link down (SStatus 0 SControl 300)
[    5.617018] ata6: SATA link down (SStatus 0 SControl 300)
[    5.617784] scsi7 : pata_legacy
[    5.617959] ata8: PATA max PIO4 cmd 0x170 ctl 0x376 irq 15
[    5.769410] I2O subsystem v1.325
[    5.769488] i2o: max drivers = 8
[    5.769698] I2O Configuration OSM v1.323
[    5.769804] I2O Bus Adapter OSM v1.317
[    5.769910] I2O Block Device OSM v1.325
[    5.770130] I2O SCSI Peripheral OSM v1.316
[    5.770237] I2O ProcFS OSM v1.316
[    5.770349] Fusion MPT base driver 3.04.17
[    5.770428] Copyright (c) 1999-2008 LSI Corporation
[    5.770512] Fusion MPT SPI Host driver 3.04.17
[    5.770630] Fusion MPT FC Host driver 3.04.17
[    5.770751] Fusion MPT SAS Host driver 3.04.17
[    5.770871] Fusion MPT misc device (ioctl) driver 3.04.17
[    5.771028] mptctl: Registered with Fusion MPT base driver
[    5.771110] mptctl: /dev/mptctl @ (major,minor=10,220)
[    5.771191] Fusion MPT LAN driver 3.04.17
[    5.771359] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    5.771471] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 22 (level, low) -> IRQ 22
[    5.771572] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[    5.771577] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[    5.771728] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[    5.774050] ehci_hcd 0000:00:1a.7: debug port 1
[    5.778013] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[    5.778031] ehci_hcd 0000:00:1a.7: irq 22, io mem 0xfed1c400
[    5.788007] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    5.788127] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    5.788211] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.788325] usb usb1: Product: EHCI Host Controller
[    5.788406] usb usb1: Manufacturer: Linux 2.6.37.6 ehci_hcd
[    5.788487] usb usb1: SerialNumber: 0000:00:1a.7
[    5.788713] hub 1-0:1.0: USB hub found
[    5.788795] hub 1-0:1.0: 6 ports detected
[    5.789011] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[    5.789105] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[    5.789109] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[    5.789256] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[    5.797038] ehci_hcd 0000:00:1d.7: debug port 1
[    5.800990] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[    5.801010] ehci_hcd 0000:00:1d.7: irq 20, io mem 0xfed1c000
[    5.810007] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    5.810102] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    5.810192] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.810305] usb usb2: Product: EHCI Host Controller
[    5.810385] usb usb2: Manufacturer: Linux 2.6.37.6 ehci_hcd
[    5.810467] usb usb2: SerialNumber: 0000:00:1d.7
[    5.810684] hub 2-0:1.0: USB hub found
[    5.810765] hub 2-0:1.0: 6 ports detected
[    5.811035] 116x: driver isp116x-hcd, 03 Nov 2005
[    5.811145] driver isp1362-hcd, 2005-04-04
[    5.811252] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    5.811372] uhci_hcd: USB Universal Host Controller Interface driver
[    5.811536] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[    5.811626] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[    5.811630] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[    5.811772] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[    5.817048] uhci_hcd 0000:00:1a.0: irq 20, io base 0x00006f60
[    5.817165] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    5.817249] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.817363] usb usb3: Product: UHCI Host Controller
[    5.817443] usb usb3: Manufacturer: Linux 2.6.37.6 uhci_hcd
[    5.817524] usb usb3: SerialNumber: 0000:00:1a.0
[    5.817738] hub 3-0:1.0: USB hub found
[    5.817820] hub 3-0:1.0: 2 ports detected
[    5.818029] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[    5.818118] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[    5.818122] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[    5.818260] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[    5.825052] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00006f80
[    5.825168] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    5.825252] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.825365] usb usb4: Product: UHCI Host Controller
[    5.825446] usb usb4: Manufacturer: Linux 2.6.37.6 uhci_hcd
[    5.825527] usb usb4: SerialNumber: 0000:00:1a.1
[    5.825741] hub 4-0:1.0: USB hub found
[    5.825822] hub 4-0:1.0: 2 ports detected
[    5.826022] uhci_hcd 0000:00:1a.2: PCI INT C -> GSI 22 (level, low) -> IRQ 22
[    5.826111] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[    5.826115] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[    5.826258] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[    5.833041] uhci_hcd 0000:00:1a.2: irq 22, io base 0x00006fa0
[    5.833159] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    5.833243] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.833356] usb usb5: Product: UHCI Host Controller
[    5.833437] usb usb5: Manufacturer: Linux 2.6.37.6 uhci_hcd
[    5.833518] usb usb5: SerialNumber: 0000:00:1a.2
[    5.833734] hub 5-0:1.0: USB hub found
[    5.833816] hub 5-0:1.0: 2 ports detected
[    5.834024] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[    5.834113] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[    5.834117] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    5.834257] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[    5.841040] uhci_hcd 0000:00:1d.0: irq 20, io base 0x00006f00
[    5.841158] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    5.841242] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.841355] usb usb6: Product: UHCI Host Controller
[    5.841436] usb usb6: Manufacturer: Linux 2.6.37.6 uhci_hcd
[    5.841517] usb usb6: SerialNumber: 0000:00:1d.0
[    5.841738] hub 6-0:1.0: USB hub found
[    5.841820] hub 6-0:1.0: 2 ports detected
[    5.842021] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[    5.842110] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[    5.842114] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    5.842254] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[    5.849039] uhci_hcd 0000:00:1d.1: irq 21, io base 0x00006f20
[    5.849156] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    5.849240] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.849354] usb usb7: Product: UHCI Host Controller
[    5.849434] usb usb7: Manufacturer: Linux 2.6.37.6 uhci_hcd
[    5.849516] usb usb7: SerialNumber: 0000:00:1d.1
[    5.849731] hub 7-0:1.0: USB hub found
[    5.849813] hub 7-0:1.0: 2 ports detected
[    5.850022] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 22 (level, low) -> IRQ 22
[    5.850110] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[    5.850114] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    5.850255] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[    5.857039] uhci_hcd 0000:00:1d.2: irq 22, io base 0x00006f40
[    5.857157] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[    5.857241] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.857355] usb usb8: Product: UHCI Host Controller
[    5.857435] usb usb8: Manufacturer: Linux 2.6.37.6 uhci_hcd
[    5.857516] usb usb8: SerialNumber: 0000:00:1d.2
[    5.857728] hub 8-0:1.0: USB hub found
[    5.857810] hub 8-0:1.0: 2 ports detected
[    5.858083] sl811: driver sl811-hcd, 19 May 2005
[    5.858194] r8a66597_hcd: driver r8a66597_hcd, 2009-05-26
[    5.858474] Initializing USB Mass Storage driver...
[    5.858616] usbcore: registered new interface driver usb-storage
[    5.858697] USB Mass Storage support registered.
[    5.858812] usbcore: registered new interface driver ums-alauda
[    5.858926] usbcore: registered new interface driver ums-cypress
[    5.859046] usbcore: registered new interface driver ums-datafab
[    5.859159] usbcore: registered new interface driver ums-freecom
[    5.859274] usbcore: registered new interface driver ums-isd200
[    5.859388] usbcore: registered new interface driver ums-jumpshot
[    5.859504] usbcore: registered new interface driver ums-karma
[    5.859618] usbcore: registered new interface driver ums-onetouch
[    5.859732] usbcore: registered new interface driver ums-sddr09
[    5.859849] usbcore: registered new interface driver ums-sddr55
[    5.859962] usbcore: registered new interface driver ums-usbat
[    5.860150] PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    5.860913] i8042.c: Warning: Keylock active.
[    5.864073] serio: i8042 KBD port at 0x60,0x64 irq 1
[    5.864158] serio: i8042 AUX port at 0x60,0x64 irq 12
[    5.864401] mice: PS/2 mouse device common for all mice
[    5.864516] md: linear personality registered for level -1
[    5.864602] md: raid0 personality registered for level 0
[    5.864683] md: raid1 personality registered for level 1
[    5.864764] md: raid10 personality registered for level 10
[    5.864853] md: raid6 personality registered for level 6
[    5.864934] md: raid5 personality registered for level 5
[    5.865055] md: raid4 personality registered for level 4
[    5.865136] md: multipath personality registered for level -4
[    5.865341] device-mapper: uevent: version 1.0.3
[    5.865573] device-mapper: ioctl: 4.18.0-ioctl (2010-06-29) initialised: dm-devel@redhat.com
[    5.865819] cpuidle: using governor ladder
[    5.865898] cpuidle: using governor menu
[    5.866042] input: Speakup as /devices/virtual/input/input0
[    5.866160] speakup 3.1.6: initialized
[    5.866243] synth name on entry is: (null)
[    5.866376] initialized device: /dev/synth, node (MAJOR 10, MINOR 25)
[    5.866536] TCP cubic registered
[    5.866622] Initializing XFRM netlink socket
[    5.866710] NET: Registered protocol family 17
[    5.866810] Registering the dns_resolver key type
[    5.866974] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[    5.871298] registered taskstats version 1
[    5.871939] md: Waiting for all devices to be available before autodetect
[    5.872028] md: If you don't use raid, use raid=noautodetect
[    5.872290] md: Autodetecting RAID arrays.
[    5.872371] md: Scanned 0 and added 0 devices.
[    5.872450] md: autorun ...
[    5.872527] md: ... autorun DONE.
[    5.919400] EXT3-fs (sda1): error: couldn't mount because of unsupported optional features (240)
[    5.919768] EXT2-fs (sda1): error: couldn't mount because of unsupported optional features (240)
[    5.947357] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    5.947566] VFS: Mounted root (ext4 filesystem) readonly on device 8:1.
[    5.989175] devtmpfs: mounted
[    5.989278] Freeing unused kernel memory: 772k freed
[    5.989616] Write protecting the kernel read-only data: 16384k
[    5.989936] Freeing unused kernel memory: 1360k freed
[    5.990585] Freeing unused kernel memory: 1140k freed
[    6.192012] usb 2-3: new high speed USB device using ehci_hcd and address 2
[    6.306891] usb 2-3: New USB device found, idVendor=0781, idProduct=5567
[    6.306978] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.307067] usb 2-3: Product: Cruzer Blade
[    6.307147] usb 2-3: Manufacturer: SanDisk
[    6.307227] usb 2-3: SerialNumber: 200522433207730254AE
[    6.307627] scsi8 : usb-storage 2-3:1.0
[    6.660017] usb 8-2: new full speed USB device using uhci_hcd and address 2
[    6.825148] usb 8-2: New USB device found, idVendor=0a5c, idProduct=4500
[    6.825237] usb 8-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.825322] usb 8-2: Product: BCM2046B1
[    6.825401] usb 8-2: Manufacturer: Broadcom
[    6.828201] hub 8-2:1.0: USB hub found
[    6.830147] hub 8-2:1.0: 3 ports detected
[    7.106146] usb 8-2.1: new full speed USB device using uhci_hcd and address 3
[    7.216143] usb 8-2.1: New USB device found, idVendor=413c, idProduct=8157
[    7.216230] usb 8-2.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    7.286141] usb 8-2.2: new full speed USB device using uhci_hcd and address 4
[    7.307521] scsi 8:0:0:0: Direct-Access     SanDisk  Cruzer Blade     1.26 PQ: 0 ANSI: 5
[    7.308386] sd 8:0:0:0: [sdb] 15633408 512-byte logical blocks: (8.00 GB/7.45 GiB)
[    7.309256] sd 8:0:0:0: [sdb] Write Protect is off
[    7.309339] sd 8:0:0:0: [sdb] Mode Sense: 43 00 00 00
[    7.309342] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[    7.312631] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[    7.313387]  sdb: sdb1
[    7.314880] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[    7.314964] sd 8:0:0:0: [sdb] Attached SCSI removable disk
[    7.393743] udev[1297]: starting version 165
[    7.400155] usb 8-2.2: New USB device found, idVendor=413c, idProduct=8158
[    7.400244] usb 8-2.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    8.026065] ACPI: AC Adapter [AC] (on-line)
[    8.030006] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input2
[    8.032512] ACPI: Lid Switch [LID]
[    8.032654] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input3
[    8.032774] ACPI: Power Button [PBTN]
[    8.032900] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input4
[    8.033201] ACPI: Sleep Button [SBTN]
[    8.110427] ACPI: Battery Slot [BAT0] (battery present)
[    8.110678] wmi: Mapper loaded
[    8.148136] usb 8-2.3: new full speed USB device using uhci_hcd and address 5
[    8.167350] input: Dell WMI hotkeys as /devices/virtual/input/input5
[    8.243338] firewire_ohci 0000:02:01.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[    8.253545] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    8.261388] rtc_cmos 00:03: RTC can wake from S4
[    8.264089] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[    8.264220] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    8.271124] usb 8-2.3: New USB device found, idVendor=413c, idProduct=8156
[    8.271210] usb 8-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.271324] usb 8-2.3: Product: Dell Wireless 370 Bluetooth Mini-card
[    8.271408] usb 8-2.3: Manufacturer: Dell Computer Corp
[    8.296071] firewire_ohci: Added fw-ohci device 0000:02:01.1, OHCI v1.10, 4 IR + 4 IT contexts, quirks 0x1
[    8.307603] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[    8.308596] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    8.309363] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    8.309487] sd 8:0:0:0: Attached scsi generic sg2 type 0
[    8.338121] tg3.c:v3.115 (October 14, 2010)
[    8.338381] tg3 0000:09:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    8.338474] tg3 0000:09:00.0: setting latency timer to 64
[    8.367419] tg3 0000:09:00.0: eth0: Tigon3 [partno(BCM95761e) rev 5761100] (PCI Express) MAC address 00:23:ae:1f:ec:51
[    8.367543] tg3 0000:09:00.0: eth0: attached PHY is 5761 (10/100/1000Base-T Ethernet) (WireSpeed[1])
[    8.367660] tg3 0000:09:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[    8.367777] tg3 0000:09:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[    8.409154] Linux agpgart interface v0.103
[    8.450710] input: PS/2 Mouse as /devices/platform/i8042/serio1/input/input6
[    8.466820] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input7
[    8.509012] sdhci: Secure Digital Host Controller Interface driver
[    8.509103] sdhci: Copyright(c) Pierre Ossman
[    8.589267] thermal LNXTHERM:00: registered as thermal_zone0
[    8.589361] ACPI: Thermal Zone [THM] (61 C)
[    8.595155] input: HID 413c:8157 as /devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2.1/8-2.1:1.0/input/input8
[    8.595436] generic-usb 0003:413C:8157.0001: input,hidraw0: USB HID v1.11 Keyboard [HID 413c:8157] on usb-0000:00:1d.2-2.1/input0
[    8.599593] input: HID 413c:8158 as /devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2.2/8-2.2:1.0/input/input9
[    8.599916] generic-usb 0003:413C:8158.0002: input,hidraw1: USB HID v1.11 Mouse [HID 413c:8158] on usb-0000:00:1d.2-2.2/input0
[    8.600299] usbcore: registered new interface driver usbhid
[    8.600394] usbhid: USB HID core driver
[    8.603224] ACPI: acpi_idle registered with cpuidle
[    8.603728] yenta_cardbus 0000:02:01.0: CardBus bridge found [1028:0263]
[    8.605310] Monitor-Mwait will be used to enter C-1 state
[    8.605658] Monitor-Mwait will be used to enter C-2 state
[    8.606962] Monitor-Mwait will be used to enter C-3 state
[    8.606989] Marking TSC unstable due to TSC halts in idle
[    8.607517] Switching to clocksource hpet
[    8.727091] yenta_cardbus 0000:02:01.0: ISA IRQ mask 0x0cb8, PCI irq 19
[    8.727181] yenta_cardbus 0000:02:01.0: Socket status: 30000006
[    8.727266] pci_bus 0000:02: Raising subordinate bus# of parent bus (#02) from #03 to #06
[    8.727390] yenta_cardbus 0000:02:01.0: pcmcia: parent PCI bridge window: [io  0x5000-0x5fff]
[    8.727508] yenta_cardbus 0000:02:01.0: pcmcia: parent PCI bridge window: [mem 0xf6800000-0xf68fffff]
[    8.727626] pcmcia_socket pcmcia_socket0: cs: memory probe 0xf6800000-0xf68fffff: excluding 0xf6800000-0xf680ffff 0xf68f0000-0xf68fffff
[    8.727933] yenta_cardbus 0000:02:01.0: pcmcia: parent PCI bridge window: [mem 0x80000000-0x83ffffff pref]
[    8.728063] pcmcia_socket pcmcia_socket0: cs: memory probe 0x80000000-0x83ffffff: excluding 0x80000000-0x83ffffff
[    8.736485] Bluetooth: Core ver 2.15
[    8.738794] NET: Registered protocol family 31
[    8.738879] Bluetooth: HCI device and connection manager initialized
[    8.738964] Bluetooth: HCI socket layer initialized
[    8.739768] sdhci-pci 0000:02:01.2: SDHCI controller found [1180:0822] (rev 21)
[    8.739910] sdhci-pci 0000:02:01.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[    8.742850] Registered led device: mmc0::
[    8.744001] mmc0: SDHCI controller on PCI [0000:02:01.2] using DMA
[    8.785325] i801_smbus 0000:00:1f.3: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    8.798664] firewire_core: created device fw0: GUID 364fc00026b5a490, S400
[    8.839036] Bluetooth: Generic Bluetooth USB driver ver 0.6
[    8.843321] usbcore: registered new interface driver btusb
[    8.991971] agpgart-intel 0000:00:00.0: Intel GM45 Chipset
[    8.992194] agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[    8.992865] agpgart-intel 0000:00:00.0: detected 32768K stolen memory
[    9.000224] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[    9.032861] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[    9.033072] HDA Intel 0000:00:1b.0: irq 41 for MSI/MSI-X
[    9.033103] HDA Intel 0000:00:1b.0: setting latency timer to 64
[    9.356819] pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff: excluding 0xc0000-0xcffff 0xe0000-0xfffff
[    9.357195] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff: excluding 0x60000000-0x60ffffff
[    9.357507] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff: clean.
[    9.390409] input: HDA Intel Mic at Sep Left Jack as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[    9.390629] input: HDA Intel Mic at Ext Right Jack as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    9.390819] input: HDA Intel Line Out at Sep Left Jack as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[    9.391017] input: HDA Intel HP Out at Ext Right Jack as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[    9.445042] [drm] Initialized drm 1.1.0 20060810
[    9.686454] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    9.686546] i915 0000:00:02.0: setting latency timer to 64
[    9.734409] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[    9.734531] [drm] MTRR allocation failed.  Graphics performance may suffer.
[    9.734972] i915 0000:00:02.0: irq 42 for MSI/MSI-X
[    9.795561] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   10.162409] Console: switching to colour frame buffer device 106x30
[   10.163637] fb0: inteldrmfb frame buffer device
[   10.163661] drm: registered panic notifier
[   10.188136] acpi device:37: registered as cooling_device2
[   10.188751] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/LNXVIDEO:00/input/input14
[   10.188896] ACPI: Video Device [VID] (multi-head: yes  rom: no  post: no)
[   10.190182] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[   10.192815] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[   10.308125] Adding 2050044k swap on /dev/sda5.  Priority:-1 extents:1 across:2050044k
[   10.437902] fuse init (API version 7.15)
[   10.690043] EXT4-fs (sda1): re-mounted. Opts: (null)
[   10.783120] EXT4-fs (sda1): re-mounted. Opts: (null)
[   11.146394] ppdev: user-space parallel port driver
[   11.151660] lp: driver loaded but no devices found
[   17.151201] tg3 0000:09:00.0: irq 43 for MSI/MSI-X
[   18.808494] tg3 0000:09:00.0: eth0: Link is up at 100 Mbps, full duplex
[   18.808505] tg3 0000:09:00.0: eth0: Flow control is on for TX and on for RX
[   28.836232] NET: Registered protocol family 10
[   28.836415] lo: Disabled Privacy Extensions
[   38.938037] eth0: no IPv6 routers present
[  176.131326] start_kdeinit (2356): /proc/2356/oom_adj is deprecated, please use /proc/2356/oom_score_adj instead.
[  181.001292] ata1.00: configured for UDMA/133
[  181.001302] ata1: EH complete
[  182.428184] EXT4-fs (sda1): re-mounted. Opts: commit=0
[  182.546053] CE: hpet increased min_delta_ns to 20113 nsec
[  200.397059] usb 6-1: new low speed USB device using uhci_hcd and address 2
[  200.559093] usb 6-1: New USB device found, idVendor=093a, idProduct=2500
[  200.559100] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  200.559105] usb 6-1: Product: USB OPTICAL MOUSE
[  200.559109] usb 6-1: Manufacturer: PIXART
[  200.587477] input: PIXART USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input15
[  200.587617] generic-usb 0003:093A:2500.0003: input,hidraw1: USB HID v1.10 Mouse [PIXART USB OPTICAL MOUSE] on usb-0000:00:1d.0-1/input0
e l'lsmod è questo
root@darkstar:/home/juliet# lsmod
Module                  Size  Used by
snd_seq_dummy           1479  0
snd_seq_oss            30116  0
snd_seq_midi_event      5708  1 snd_seq_oss
snd_seq                52486  5 snd_seq_dummy,snd_seq_oss,snd_seq_midi_event
snd_seq_device          5473  3 snd_seq_dummy,snd_seq_oss,snd_seq
snd_pcm_oss            40089  0
snd_mixer_oss          17282  1 snd_pcm_oss
ipv6                  275315  12
cpufreq_ondemand        9164  2
acpi_cpufreq            6079  1
freq_table              2435  2 cpufreq_ondemand,acpi_cpufreq
mperf                   1195  1 acpi_cpufreq
lp                      9781  0
ppdev                   6021  0
parport_pc             21214  0
parport                30087  3 lp,ppdev,parport_pc
fuse                   66651  1
i915                  400238  3
drm_kms_helper         27035  1 i915
drm                   177345  4 i915,drm_kms_helper
snd_hda_codec_hdmi     22985  1
snd_hda_codec_idt      56457  1
i2c_algo_bit            5055  1 i915
snd_hda_intel          21915  2
snd_hda_codec          71748  3 snd_hda_codec_hdmi,snd_hda_codec_idt,snd_hda_intel
intel_agp              10824  1 i915
intel_gtt              14862  3 i915,intel_agp
pcmcia                 37397  0
btusb                  11689  0
i2c_i801                8230  0
sdhci_pci               7550  0
bluetooth              53772  1 btusb
dell_laptop             7991  0
rfkill                 16442  3 bluetooth,dell_laptop
yenta_socket           21449  0
processor              25982  3 acpi_cpufreq
video                  11949  1 i915
usbhid                 36859  0
thermal                 8082  0
joydev                 10279  0
sdhci                  17079  1 sdhci_pci
agpgart                28874  3 drm,intel_agp,intel_gtt
evdev                   9813  19
i2c_core               19769  5 i915,drm_kms_helper,drm,i2c_algo_bit,i2c_i801
tg3                   126741  0
thermal_sys            13862  3 processor,video,thermal
hid                    77723  1 usbhid
sg                     26495  0
dcdbas                  5480  1 dell_laptop
libphy                 16992  1 tg3
rtc_cmos                9374  0
rtc_core               14471  1 rtc_cmos
shpchp                 26821  0
firewire_ohci          27301  0
firewire_core          51107  1 firewire_ohci
mmc_core               64800  1 sdhci
dell_wmi                1565  0
psmouse                47222  0
sparse_keymap           2984  1 dell_wmi
serio_raw               4534  0
output                  2020  1 video
rtc_lib                 1978  1 rtc_core
wmi                     8349  1 dell_wmi
hwmon                   1473  1 thermal_sys
pcmcia_rsrc             9418  1 yenta_socket
battery                10535  0
button                  5013  1 i915
ac                      3249  0
pcmcia_core            12125  3 pcmcia,yenta_socket,pcmcia_rsrc
snd_hwdep               6254  1 snd_hda_codec
snd_pcm                73762  4 snd_pcm_oss,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_timer              19671  2 snd_seq,snd_pcm
snd                    58334  16 snd_seq_oss,snd_seq,snd_seq_device,snd_pcm_oss,snd_mixer_oss,snd_hda_codec_hdmi,snd_hda_codec_idt,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_timer
soundcore               5681  1 snd
snd_page_alloc          7297  2 snd_hda_intel,snd_pcm
che faccio? aggiorno il kernel? poi se non va provo anche la soluzione suggerita da fAu
Meskalamdug
Devi aggiornare il kernel.
Che distribuzione usi?13.37 o current?
