--riassunto vecchio topic--
Sto compilando su slackware64-current il kernel linux-next (l'ultimissimo scaricabile da git per capirci)
Ho preso il config-huge del 3.2.21 e copiato come .config e poi ho dato make oldconfig
Ho dovuto disabilitare DLM e GFS2 per compilarlo
--fine riassunto--
Dopo aver fatto il boot la prima cosa anomala che riscontro è questa
# dmesg
[ 1.438561] tsc: Refined TSC clocksource calibration: 2195.013 MHz
[ 1.438871] Switching to clocksource tsc
[ 20.477961] floppy0: no floppy controllers found
Poi ho tentato di compilare il modulo proprietario nvidia ma mi da errore:
# make module
NVIDIA: calling KBUILD...
make -C /lib/modules/3.5.0-rc4-next-20120628+/build \
KBUILD_SRC=/usr/src/linux-next-20120628 \
KBUILD_EXTMOD="/usr/share/nvidia-linux/kernel" -f /usr/src/linux-next-20120628/Makefile \
modules
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo; \
echo " ERROR: Kernel configuration is invalid."; \
echo " include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo; \
/bin/false)
mkdir -p /usr/share/nvidia-linux/kernel/.tmp_versions ; rm -f /usr/share/nvidia-linux/kernel/.tmp_versions/*
make -f /usr/src/linux-next-20120628/scripts/Makefile.build obj=/usr/share/nvidia-linux/kernel
cc -Wp,-MD,/usr/share/nvidia-linux/kernel/.nv.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-slackware-linux/4.7.1/include -I/usr/src/linux-next-20120628/arch/x86/include -Iarch/x86/include/generated -Iinclude -I/usr/src/linux-next-20120628/include -include /usr/src/linux-next-20120628/include/linux/kconfig.h -I/usr/share/nvidia-linux/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/usr/share/nvidia-linux/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"295.59\" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /usr/share/nvidia-linux/kernel/nv.o /usr/share/nvidia-linux/kernel/nv.c
In file included from include/linux/kernel.h:19:0,
from include/linux/sched.h:55,
from include/linux/utsname.h:35,
from /usr/share/nvidia-linux/kernel/nv-linux.h:38,
from /usr/share/nvidia-linux/kernel/nv.c:13:
include/linux/bitops.h: In function 'hweight_long':
include/linux/bitops.h:66:41: warning: signed and unsigned type in conditional expression [-Wsign-compare]
In file included from /usr/src/linux-next-20120628/arch/x86/include/asm/uaccess.h:586:0,
from include/linux/poll.h:14,
from /usr/share/nvidia-linux/kernel/nv-linux.h:97,
/usr/src/linux-next-20120628/arch/x86/include/asm/uaccess_64.h: In function 'copy_from_user':
/usr/src/linux-next-20120628/arch/x86/include/asm/uaccess_64.h:53:6: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if [ "-pg" = "-pg" ]; then if [ /usr/share/nvidia-linux/kernel/nv.o != "scripts/mod/empty.o" ]; then /usr/src/linux-next-20120628/scripts/recordmcount "/usr/share/nvidia-linux/kernel/nv.o"; fi; fi;
cc -Wp,-MD,/usr/share/nvidia-linux/kernel/.nv-acpi.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-slackware-linux/4.7.1/include -I/usr/src/linux-next-20120628/arch/x86/include -Iarch/x86/include/generated -Iinclude -I/usr/src/linux-next-20120628/include -include /usr/src/linux-next-20120628/include/linux/kconfig.h -I/usr/share/nvidia-linux/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/usr/share/nvidia-linux/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"295.59\" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_acpi)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /usr/share/nvidia-linux/kernel/nv-acpi.o /usr/share/nvidia-linux/kernel/nv-acpi.c
from /usr/share/nvidia-linux/kernel/nv-acpi.c:15:
/usr/share/nvidia-linux/kernel/nv-acpi.c: In function 'nv_acpi_remove':
/usr/share/nvidia-linux/kernel/nv-acpi.c:303:9: error: too many arguments to function 'acpi_os_wait_events_complete'
In file included from include/acpi/acpi.h:63:0,
from /usr/share/nvidia-linux/kernel/nv-linux.h:269,
include/acpi/acpiosxf.h:208:6: note: declared here
make[4]: *** [/usr/share/nvidia-linux/kernel/nv-acpi.o] Error 1
make[3]: *** [_module_/usr/share/nvidia-linux/kernel] Error 2
make[2]: *** [sub-make] Error 2
NVIDIA: left KBUILD.
nvidia.ko failed to build!
make[1]: *** [module] Error 1
make: *** [module] Error 2
