FFmpeg Libvdpau e slack-required.
gohanz
Messaggio da gohanz »
Ragazzi qualcuno mi sa dare una spiegazione sul perchè FFmpeg prende libvdpau al configure, compila senza problemi ma non riporta la libreria nello slack-required.
alsa-lib >= 1.0.26-i486-1
bzip2 >= 1.0.6-i486-1
celt >= 0.11.1-i486-3sl
cxxlibs >= 6.0.17-i486-1 | gcc-g++ >= 4.7.1-i486-1
enca >= 1.14-i486-1sl
expat >= 2.0.1-i486-2
faac >= 1.28-i486-9sl
fftw >= 3.2.2-i486-1
fontconfig >= 2.9.0-i486-1
freeglut >= 2.8.0-i486-1
freetype >= 2.4.10-i486-1
frei0r >= 20121008-i686-1sl
fribidi >= 0.19.2-i486-3
gcc >= 4.7.1-i486-1
glibc-solibs >= 2.15-i486-7
gmp >= 5.0.5-i486-1
gnutls >= 3.0.23-i486-1
jack-audio-connection-kit >= 0.121.3-i486-3sl
lame >= 3.99.5-i486-1sl
libX11 >= 1.5.0-i486-1
libXau >= 1.0.7-i486-1
libXdmcp >= 1.1.1-i486-1
libXext >= 1.3.1-i486-1
libXfixes >= 5.0-i486-1
libXi >= 1.6.1-i486-1
libXrandr >= 1.3.2-i486-1
libXrender >= 0.9.7-i486-1
libXxf86vm >= 1.1.2-i486-1
libaacplus >= 2.0.2-i486-3sl
libass >= 0.10.0-i486-1sl
libbluray >= 0.2.3-i486-1sl
libcaca >= 0.99.beta18-i486-2
libcdio >= 0.83-i486-1
libdc1394 >= 2.2.0-i486-3sl
libgsm >= 1.0.13-i686-7sl
libjpeg >= v8a-i486-1
libmodplug >= 0.8.8.4-i486-1sl
libogg >= 1.3.0-i486-1
libraw1394 >= 2.0.7-i486-1
libtheora >= 1.1.1-i486-1
libusb >= 1.0.9-i486-1
libva >= 1.1.0-i486-1sl
libvorbis >= 1.3.3-i486-1
libvpx >= 1.1.0-i486-1sl
libxcb >= 1.8.1-i486-1
libxml2 >= 2.8.0-i486-1
mesa >= 8.0.4-i486-1
ncurses >= 5.9-i486-1
nettle >= 2.5-i486-1
openal-soft >= 1.14-i486-1sl
opencore-amr >= 0.1.3-i486-7sl
openssl >= 1.0.1c-i486-3 | openssl-solibs >= 1.0.1c-i486-3
opus >= 1.0.1-i486-1sl
orc >= 0.4.16-i486-3sl
p11-kit >= 0.12-i486-1
rtmpdump >= 2.3-i686-3sl
schroedinger >= 1.0.11-i486-3sl
sdl >= 1.2.14-i486-5
slang >= 2.2.3-i486-1
speex >= 1.2rc1-i486-8sl
svgalib >= 1.9.25-i486-2
twolame >= 0.3.13-i486-3sl
v4l-utils >= 0.8.8-i486-2
vo-aacenc >= 0.1.2-i486-3sl
vo-amrwbenc >= 0.1.2-i486-3sl
x264 >= 20121004-i486-1sl
xvidcore >= 1.3.2-i486-4sl
xz >= 5.0.4-i486-1
zlib >= 1.2.6-i486-1
414N
Kernel: 5.15.19
Re: FFmpeg Libvdpau e slack-required.
Messaggio da 414N »
Forse perché la usa a caricamento dinamico e se non la trova il programma funziona lo stesso.
Hai provato ad usare ffmpeg compilato con vdpau dopo aver rimosso vdpau stessa? Si rifiuta di partire perché la libreria è assente o funziona lo stesso?
gohanz
414N ha scritto:Forse perché la usa a caricamento dinamico e se non la trova il programma funziona lo stesso.
Funziona lo stesso. Ho pensato che ci fosse un conflitto tra i driver NVidia origianli e le librerie libvdapu. Ma anche reinstallando il pacchetto lo slack-required non le riporta il configure si.
