non si compila skype-call-recorder
varjag
Messaggio da varjag »
Buona sera
cercavo di compilare skype-call-recorder su
slackware64-14.1 multilib aggiornata.
slackbuild pero solo per 13.37
http://slackbuilds.org/repository/13.37 ... -recorder/
comunque la compilazione si ferma perche non trova id3..
strano perche id3 è installato
skype-call-recorder-0.8/wavewriter.h
-- The C compiler identification is GNU 4.8.2
-- The CXX compiler identification is GNU 4.8.2
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Found lame: /usr/include/lame/lame.h /usr/lib64/libmp3lame.so
CMake Error at CMakeModules/Findid3.cmake:15 (MESSAGE):
  Could not find id3
Call Stack (most recent call first):
  CMakeLists.txt:70 (FIND_PACKAGE)
-- Configuring incomplete, errors occurred!
See also "/tmp/SBo/skype-call-recorder-0.8/CMakeFiles/CMakeOutput.log".
ls /var/log/packages | grep id3
id3-0.78-x86_64-1_SBo
qualche riga di log. /tmp/SBo/skype-call-recorder-0.8/CMakeFiles/CMakeOutput.log
cat /tmp/SBo/skype-call-recorder-0.8/CMakeFiles/CMakeOutput.log
The system is: Linux - 3.10.17 - x86_64
Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
Compiler: /usr/bin/cc
Build flags: -O2;-fPIC
Id flags:
The output was:
0
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "a.out"
The C compiler identification is GNU, found in "/tmp/SBo/skype-call-recorder-0.8/CMakeFiles/2.8.12/CompilerIdC/a.out"
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
Compiler: /usr/bin/c++
Id flags:
The output was:
0
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "a.out"
The CXX compiler identification is GNU, found in "/tmp/SBo/skype-call-recorder-0.8/CMakeFiles/2.8.12/CompilerIdCXX/a.out"
Determining if the C compiler works passed with the following output:
Change Dir: /tmp/SBo/skype-call-recorder-0.8/CMakeFiles/CMakeTmp
Run Build Command:/usr/bin/gmake "cmTryCompileExec4076767432/fast"
/usr/bin/gmake -f CMakeFiles/cmTryCompileExec4076767432.dir/build.make CMakeFiles/cmTryCompileExec4076767432.dir/build
gmake[1]: Entering directory `/tmp/SBo/skype-call-recorder-0.8/CMakeFiles/CMakeTmp'
/usr/bin/cmake -E cmake_progress_report /tmp/SBo/skype-call-recorder-0.8/CMakeFiles/CMakeTmp/CMakeFiles 1
Building C object CMakeFiles/cmTryCompileExec4076767432.dir/testCCompiler.c.o
/usr/bin/cc   -O2 -fPIC    -o CMakeFiles/cmTryCompileExec4076767432.dir/testCCompiler.c.o   -c /tmp/SBo/skype-call-recorder-0.8/CMakeFiles/CMakeTmp/testCCompiler.c
Linking C executable cmTryCompileExec4076767432
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec4076767432.dir/link.txt --verbose=1
/usr/bin/cc  -O2 -fPIC     CMakeFiles/cmTryCompileExec4076767432.dir/testCCompiler.c.o  -o cmTryCompileExec4076767432 -rdynamic
gmake[1]: Leaving directory `/tmp/SBo/skype-call-recorder-0.8/CMakeFiles/CMakeTmp'
Detecting C compiler ABI info compiled with the following output:
Run Build Command:/usr/bin/gmake "cmTryCompileExec3591699624/fast"
/usr/bin/gmake -f CMakeFiles/cmTryCompileExec3591699624.dir/build.make CMakeFiles/cmTryCompileExec3591699624.dir/build
Building C object CMakeFiles/cmTryCompileExec3591699624.dir/CMakeCCompilerABI.c.o
/usr/bin/cc   -O2 -fPIC    -o CMakeFiles/cmTryCompileExec3591699624.dir/CMakeCCompilerABI.c.o   -c /usr/share/cmake-2.8/Modules/CMakeCCompilerABI.c
Linking C executable cmTryCompileExec3591699624
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec3591699624.dir/link.txt --verbose=1
/usr/bin/cc  -O2 -fPIC   -v CMakeFiles/cmTryCompileExec3591699624.dir/CMakeCCompilerABI.c.o  -o cmTryCompileExec3591699624 -rdynamic
Reading specs from /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/specs
COLLECT_GCC=/usr/bin/cc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-slackware-linux/4.8.2/lto-wrapper
Target: x86_64-slackware-linux
Configured with: ../gcc-4.8.2/configure --prefix=/usr --libdir=/usr/lib64 --mandir=/usr/man --infodir=/usr/info --enable-shared --enable-bootstrap --enable-languages=ada,c,c++,fortran,go,java,lto,objc --enable-threads=posix --enable-checking=release --enable-objc-gc --with-system-zlib --with-python-dir=/lib64/python2.7/site-packages --disable-libunwind-exceptions --enable-__cxa_atexit --enable-libssp --enable-lto --with-gnu-ld --verbose --enable-java-home --with-java-home=/usr/lib64/jvm/jre --with-jvm-root-dir=/usr/lib64/jvm --with-jvm-jar-dir=/usr/lib64/jvm/jvm-exports --with-arch-directory=amd64 --with-antlr-jar=/home/slackware/slackbuilds/gcc/antlr-runtime-3.4.jar --enable-multilib --target=x86_64-slackware-linux --build=x86_64-slackware-linux --host=x86_64-slackware-linux
Thread model: posix
gcc version 4.8.2 (GCC)
COMPILER_PATH=/usr/libexec/gcc/x86_64-slackware-linux/4.8.2/:/usr/libexec/gcc/x86_64-slackware-linux/4.8.2/:/usr/libexec/gcc/x86_64-slackware-linux/:/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/:/usr/lib64/gcc/x86_64-slackware-linux/:/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../x86_64-slackware-linux/bin/
LIBRARY_PATH=/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/:/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../x86_64-slackware-linux/lib/:/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../:/lib/:/usr/lib/
COLLECT_GCC_OPTIONS='-O2' '-fPIC' '-v' '-o' 'cmTryCompileExec3591699624' '-rdynamic' '-mtune=generic' '-march=x86-64'
 /usr/libexec/gcc/x86_64-slackware-linux/4.8.2/collect2 --eh-frame-hdr -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTryCompileExec3591699624 /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crt1.o /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crti.o /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/crtbegin.o -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2 -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../x86_64-slackware-linux/lib -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../.. CMakeFiles/cmTryCompileExec3591699624.dir/CMakeCCompilerABI.c.o -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/crtend.o /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crtn.o
Parsed C implicit link information from above output:
  link line regex: [^( *|.*[/\])(ld|([^/\]+-)?ld|collect2)[^/\]*( |$)]
  ignore line: [Change Dir: /tmp/SBo/skype-call-recorder-0.8/CMakeFiles/CMakeTmp]
  ignore line: []
  ignore line: [Run Build Command:/usr/bin/gmake "cmTryCompileExec3591699624/fast"]
  ignore line: [/usr/bin/gmake -f CMakeFiles/cmTryCompileExec3591699624.dir/build.make CMakeFiles/cmTryCompileExec3591699624.dir/build]
  ignore line: [gmake[1]: Entering directory `/tmp/SBo/skype-call-recorder-0.8/CMakeFiles/CMakeTmp']
  ignore line: [/usr/bin/cmake -E cmake_progress_report /tmp/SBo/skype-call-recorder-0.8/CMakeFiles/CMakeTmp/CMakeFiles 1]
  ignore line: [Building C object CMakeFiles/cmTryCompileExec3591699624.dir/CMakeCCompilerABI.c.o]
  ignore line: [/usr/bin/cc   -O2 -fPIC    -o CMakeFiles/cmTryCompileExec3591699624.dir/CMakeCCompilerABI.c.o   -c /usr/share/cmake-2.8/Modules/CMakeCCompilerABI.c]
  ignore line: [Linking C executable cmTryCompileExec3591699624]
  ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec3591699624.dir/link.txt --verbose=1]
  ignore line: [/usr/bin/cc  -O2 -fPIC   -v CMakeFiles/cmTryCompileExec3591699624.dir/CMakeCCompilerABI.c.o  -o cmTryCompileExec3591699624 -rdynamic  ]
  ignore line: [Reading specs from /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/specs]
  ignore line: [COLLECT_GCC=/usr/bin/cc]
  ignore line: [COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-slackware-linux/4.8.2/lto-wrapper]
  ignore line: [Target: x86_64-slackware-linux]
  ignore line: [Configured with: ../gcc-4.8.2/configure --prefix=/usr --libdir=/usr/lib64 --mandir=/usr/man --infodir=/usr/info --enable-shared --enable-bootstrap --enable-languages=ada,c,c++,fortran,go,java,lto,objc --enable-threads=posix --enable-checking=release --enable-objc-gc --with-system-zlib --with-python-dir=/lib64/python2.7/site-packages --disable-libunwind-exceptions --enable-__cxa_atexit --enable-libssp --enable-lto --with-gnu-ld --verbose --enable-java-home --with-java-home=/usr/lib64/jvm/jre --with-jvm-root-dir=/usr/lib64/jvm --with-jvm-jar-dir=/usr/lib64/jvm/jvm-exports --with-arch-directory=amd64 --with-antlr-jar=/home/slackware/slackbuilds/gcc/antlr-runtime-3.4.jar --enable-multilib --target=x86_64-slackware-linux --build=x86_64-slackware-linux --host=x86_64-slackware-linux]
  ignore line: [Thread model: posix]
  ignore line: [gcc version 4.8.2 (GCC) ]
  ignore line: [COMPILER_PATH=/usr/libexec/gcc/x86_64-slackware-linux/4.8.2/:/usr/libexec/gcc/x86_64-slackware-linux/4.8.2/:/usr/libexec/gcc/x86_64-slackware-linux/:/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/:/usr/lib64/gcc/x86_64-slackware-linux/:/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../x86_64-slackware-linux/bin/]
  ignore line: [LIBRARY_PATH=/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/:/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../x86_64-slackware-linux/lib/:/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../:/lib/:/usr/lib/]
  ignore line: [COLLECT_GCC_OPTIONS='-O2' '-fPIC' '-v' '-o' 'cmTryCompileExec3591699624' '-rdynamic' '-mtune=generic' '-march=x86-64']
  link line: [ /usr/libexec/gcc/x86_64-slackware-linux/4.8.2/collect2 --eh-frame-hdr -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTryCompileExec3591699624 /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crt1.o /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crti.o /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/crtbegin.o -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2 -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../x86_64-slackware-linux/lib -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../.. CMakeFiles/cmTryCompileExec3591699624.dir/CMakeCCompilerABI.c.o -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/crtend.o /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crtn.o]
    arg [/usr/libexec/gcc/x86_64-slackware-linux/4.8.2/collect2] ==> ignore
    arg [--eh-frame-hdr] ==> ignore
    arg [-m] ==> ignore
    arg [elf_x86_64] ==> ignore
    arg [-export-dynamic] ==> ignore
    arg [-dynamic-linker] ==> ignore
    arg [/lib64/ld-linux-x86-64.so.2] ==> ignore
    arg [-o] ==> ignore
    arg [cmTryCompileExec3591699624] ==> ignore
    arg [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crt1.o] ==> ignore
    arg [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crti.o] ==> ignore
    arg [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/crtbegin.o] ==> ignore
    arg [-L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2] ==> dir [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2]
    arg [-L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64] ==> dir [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64]
    arg [-L/lib/../lib64] ==> dir [/lib/../lib64]
    arg [-L/usr/lib/../lib64] ==> dir [/usr/lib/../lib64]
    arg [-L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../x86_64-slackware-linux/lib] ==> dir [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../x86_64-slackware-linux/lib]
    arg [-L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../..] ==> dir [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../..]
    arg [CMakeFiles/cmTryCompileExec3591699624.dir/CMakeCCompilerABI.c.o] ==> ignore
    arg [-lgcc] ==> lib [gcc]
    arg [--as-needed] ==> ignore
    arg [-lgcc_s] ==> lib [gcc_s]
    arg [--no-as-needed] ==> ignore
    arg [-lc] ==> lib [c]
    arg [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/crtend.o] ==> ignore
    arg [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crtn.o] ==> ignore
  remove lib [gcc]
  remove lib [gcc_s]
  remove lib [gcc]
  remove lib [gcc_s]
  collapse library dir [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2] ==> [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2]
  collapse library dir [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64] ==> [/usr/lib64]
  collapse library dir [/lib/../lib64] ==> [/lib64]
  collapse library dir [/usr/lib/../lib64] ==> [/usr/lib64]
  collapse library dir [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../x86_64-slackware-linux/lib] ==> [/usr/x86_64-slackware-linux/lib]
  collapse library dir [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../..] ==> [/usr/lib64]
  implicit libs: [c]
  implicit dirs: [/usr/lib64/gcc/x86_64-slackware-linux/4.8.2;/usr/lib64;/lib64;/usr/x86_64-slackware-linux/lib]
  implicit fwks: []
Determining if the CXX compiler works passed with the following output:
Run Build Command:/usr/bin/gmake "cmTryCompileExec3708409756/fast"
/usr/bin/gmake -f CMakeFiles/cmTryCompileExec3708409756.dir/build.make CMakeFiles/cmTryCompileExec3708409756.dir/build
Building CXX object CMakeFiles/cmTryCompileExec3708409756.dir/testCXXCompiler.cxx.o
/usr/bin/c++    -O2 -fPIC    -o CMakeFiles/cmTryCompileExec3708409756.dir/testCXXCompiler.cxx.o -c /tmp/SBo/skype-call-recorder-0.8/CMakeFiles/CMakeTmp/testCXXCompiler.cxx
Linking CXX executable cmTryCompileExec3708409756
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec3708409756.dir/link.txt --verbose=1
/usr/bin/c++   -O2 -fPIC     CMakeFiles/cmTryCompileExec3708409756.dir/testCXXCompiler.cxx.o  -o cmTryCompileExec3708409756 -rdynamic
Detecting CXX compiler ABI info compiled with the following output:
Run Build Command:/usr/bin/gmake "cmTryCompileExec599480181/fast"
/usr/bin/gmake -f CMakeFiles/cmTryCompileExec599480181.dir/build.make CMakeFiles/cmTryCompileExec599480181.dir/build
Building CXX object CMakeFiles/cmTryCompileExec599480181.dir/CMakeCXXCompilerABI.cpp.o
/usr/bin/c++    -O2 -fPIC    -o CMakeFiles/cmTryCompileExec599480181.dir/CMakeCXXCompilerABI.cpp.o -c /usr/share/cmake-2.8/Modules/CMakeCXXCompilerABI.cpp
Linking CXX executable cmTryCompileExec599480181
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec599480181.dir/link.txt --verbose=1
/usr/bin/c++   -O2 -fPIC   -v CMakeFiles/cmTryCompileExec599480181.dir/CMakeCXXCompilerABI.cpp.o  -o cmTryCompileExec599480181 -rdynamic
COLLECT_GCC=/usr/bin/c++
Thread model: posix
COLLECT_GCC_OPTIONS='-O2' '-fPIC' '-v' '-o' 'cmTryCompileExec599480181' '-rdynamic' '-shared-libgcc' '-mtune=generic' '-march=x86-64'
 /usr/libexec/gcc/x86_64-slackware-linux/4.8.2/collect2 --eh-frame-hdr -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTryCompileExec599480181 /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crt1.o /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crti.o /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/crtbegin.o -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2 -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../x86_64-slackware-linux/lib -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../.. CMakeFiles/cmTryCompileExec599480181.dir/CMakeCXXCompilerABI.cpp.o -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/crtend.o /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crtn.o
Parsed CXX implicit link information from above output:
  ignore line: []
  ignore line: [Run Build Command:/usr/bin/gmake "cmTryCompileExec599480181/fast"]
  ignore line: [/usr/bin/gmake -f CMakeFiles/cmTryCompileExec599480181.dir/build.make CMakeFiles/cmTryCompileExec599480181.dir/build]
  ignore line: [Building CXX object CMakeFiles/cmTryCompileExec599480181.dir/CMakeCXXCompilerABI.cpp.o]
  ignore line: [/usr/bin/c++    -O2 -fPIC    -o CMakeFiles/cmTryCompileExec599480181.dir/CMakeCXXCompilerABI.cpp.o -c /usr/share/cmake-2.8/Modules/CMakeCXXCompilerABI.cpp]
  ignore line: [Linking CXX executable cmTryCompileExec599480181]
  ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec599480181.dir/link.txt --verbose=1]
  ignore line: [/usr/bin/c++   -O2 -fPIC   -v CMakeFiles/cmTryCompileExec599480181.dir/CMakeCXXCompilerABI.cpp.o  -o cmTryCompileExec599480181 -rdynamic  ]
  ignore line: [COLLECT_GCC=/usr/bin/c++]
  ignore line: [COLLECT_GCC_OPTIONS='-O2' '-fPIC' '-v' '-o' 'cmTryCompileExec599480181' '-rdynamic' '-shared-libgcc' '-mtune=generic' '-march=x86-64']
  link line: [ /usr/libexec/gcc/x86_64-slackware-linux/4.8.2/collect2 --eh-frame-hdr -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTryCompileExec599480181 /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crt1.o /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crti.o /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/crtbegin.o -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2 -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../x86_64-slackware-linux/lib -L/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../.. CMakeFiles/cmTryCompileExec599480181.dir/CMakeCXXCompilerABI.cpp.o -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/crtend.o /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../lib64/crtn.o]
    arg [-m] ==> ignore
    arg [-o] ==> ignore
    arg [cmTryCompileExec599480181] ==> ignore
    arg [CMakeFiles/cmTryCompileExec599480181.dir/CMakeCXXCompilerABI.cpp.o] ==> ignore
    arg [-lstdc++] ==> lib [stdc++]
    arg [-lm] ==> lib [m]
  remove lib [gcc_s]
  remove lib [gcc]
  remove lib [gcc_s]
  remove lib [gcc]
  implicit libs: [stdc++;m;c]
  implicit fwks: []
che si fa?
varjag
Re: non si compila skype-call-recorder
ho provato di compila re la versione 0.8..forse per questo non si compila
c'e una nuova 0.10.
pero sono file con estensione .deb
biosgna editare slackbuilds..
non riesco a cambiare queste righe relative a .deb
qualcuno mi puo aiutare editare slackbuilds...
Kernel: 7.0.12
skype-call-recorder deve essere usato insieme a skype, che e' un applicazione a 32bit, quindi devi compilarlo a 32bit.
se apri il file .info della versione che hai scaricato vedrai che x86_64 era gia' UNSUPPORTED per la 13.37.
puoi anche farlo girare su multilib, ma ti dovrai creare i pacchetti compat32 di lame e id3lib (con convertpkg-compat32 a partire da dei pacchetti compilati a 32bit dei due).
per le varie istruzioni su come compilare a 32bit su multilib e convertire i pacchetti in compat32 fai riferimento a quello che scrive AlienBOB (leggi tutto molto attentamente)
http://www.slackware.com/~alien/multilib/
devi anche usare una versione piu' recente dei sorgenti (ed e' il motivo per cui e' stato rimosso da SBo, quelli del tempo non compilavano), ma per quello ho preparato uno SlackBuild di test
http://ponce.cc/slackware/testing/skype-call-recorder/
in bocca al lupo.
Kernel: 7.0.12
beh, alla fine mi sono deciso a provarlo sulla mia macchina multilib al lavoro e funziona :) , quindi ci ho fatto dei pacchetti
http://ponce.cc/slackware/testing/packa ... -recorder/
