rhythmbox errore c compiler
gigiobagiano
Nome Cognome: Filippo
Kernel: vanilla-4.4.38
Distribuzione: SalixOS
Messaggio da gigiobagiano »
Ciao a tutti,
ho da poco installato slackware64 14.1 full, mi sto compilando alcuni programmi finora senza alcun problema. Arrivato a rhythmbox (slackbuild da SBo), mi spunta sto problema:
configure: WARNING: unrecognized options: --with-gnome-keyring, --with-mdns, --disable-scrollkeeper
checking for a BSD-compatible install... /bin/ginstall -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... yes
checking whether make supports nested variables... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for gobject-introspection... yes
checking whether NLS is requested... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... no
configure: error: in `/tmp/SBo/rhythmbox-2.99.1':
configure: error: C compiler cannot create executables
See `config.log' for more details
(ho omesso la parte relativa alla decompressione dei sorgenti. E il file config.log:
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by rhythmbox configure 2.99.1, which was
generated by GNU Autoconf 2.69.  Invocation command line was
  $ ./configure --prefix=/usr --libdir=/usr/lib64 --sysconfdir=/etc --localstatedir=/var --mandir=/usr/man --infodir=/usr/info --docdir=/usr/doc/rhythmbox-2.99.1 --with-gnome-keyring --with-ipod --with-mtp --with-gudev --without-hal --without-brasero --enable-browser-plugin --enable-vala=auto --with-mdns=auto --disable-scrollkeeper --with-x --build=x86_64-slackware-linux
## Platform. ##
hostname = darkstar
uname -m = x86_64
uname -r = 3.10.17
uname -s = Linux
uname -v = #2 SMP Wed Oct 23 16:34:38 CDT 2013
/usr/bin/uname -p = Quad-Core Processor (up to 1.4GHz)
/bin/uname -X     = unknown
/bin/arch              = x86_64
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /sbin
PATH: /usr/sbin
PATH: /bin
PATH: /usr/bin
## Core tests. ##
configure:2879: checking for a BSD-compatible install
configure:2947: result: /bin/ginstall -c
configure:2958: checking whether build environment is sane
configure:3013: result: yes
configure:3164: checking for a thread-safe mkdir -p
configure:3203: result: /bin/mkdir -p
configure:3210: checking for gawk
configure:3226: found /bin/gawk
configure:3237: result: gawk
configure:3248: checking whether make sets $(MAKE)
configure:3270: result: yes
configure:3361: checking whether to enable maintainer-specific portions of Makefiles
configure:3370: result: yes
configure:3420: checking whether make supports nested variables
configure:3437: result: yes
configure:3506: checking for pkg-config
configure:3524: found /usr/bin/pkg-config
configure:3536: result: /usr/bin/pkg-config
configure:3561: checking pkg-config is at least version 0.9.0
configure:3564: result: yes
configure:3577: checking for gobject-introspection
configure:3586: $PKG_CONFIG --exists --print-errors "gobject-introspection-1.0"
configure:3589: $? = 0
configure:3596: $PKG_CONFIG --exists --print-errors "gobject-introspection-1.0 >= $GOBJECT_INTROSPECTION_REQS"
configure:3599: $? = 0
configure:3623: result: yes
configure:3662: checking whether NLS is requested
configure:3671: result: yes
configure:3687: checking for style of include used by make
configure:3715: result: GNU
configure:3786: checking for gcc
configure:3802: found /usr/bin/gcc
configure:3813: result: gcc
configure:4042: checking for C compiler version
configure:4051: gcc --version >&5
gcc (GCC) 4.8.2
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:4062: $? = 0
configure:4051: gcc -v >&5
Reading specs from /usr/lib64/gcc/x86_64-slackware-linux/4.8.2/specs
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-slackware-linux/4.8.2/lto-wrapper
Target: x86_64-slackware-linux
Configured with: ../gcc-4.8.2/configure --prefix=/usr --libdir=/usr/lib64 --mandir=/usr/man --infodir=/usr/info --enable-shared --enable-bootstrap --enable-languages=ada,c,c++,fortran,go,java,lto,objc --enable-threads=posix --enable-checking=release --enable-objc-gc --with-system-zlib --with-python-dir=/lib64/python2.7/site-packages --disable-libunwind-exceptions --enable-__cxa_atexit --enable-libssp --enable-lto --with-gnu-ld --verbose --enable-java-home --with-java-home=/usr/lib64/jvm/jre --with-jvm-root-dir=/usr/lib64/jvm --with-jvm-jar-dir=/usr/lib64/jvm/jvm-exports --with-arch-directory=amd64 --with-antlr-jar=/tmp/gcc/antlr-runtime-3.4.jar --enable-java-awt=gtk --disable-gtktest --disable-multilib --target=x86_64-slackware-linux --build=x86_64-slackware-linux --host=x86_64-slackware-linux
Thread model: posix
gcc version 4.8.2 (GCC)
configure:4051: gcc -V >&5
gcc: error: unrecognized command line option '-V'
gcc: fatal error: no input files
compilation terminated.
configure:4062: $? = 1
configure:4051: gcc -qversion >&5
gcc: error: unrecognized command line option '-qversion'
configure:4082: checking whether the C compiler works
configure:4104: gcc -O2 -fPIC  -ltdb conftest.c  >&5
/usr/lib64/gcc/x86_64-slackware-linux/4.8.2/../../../../x86_64-slackware-linux/bin/ld: cannot find -ltdb
collect2: error: ld returned 1 exit status
configure:4108: $? = 1
configure:4146: result: no
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "rhythmbox"
| #define PACKAGE_TARNAME "rhythmbox"
| #define PACKAGE_VERSION "2.99.1"
| #define PACKAGE_STRING "rhythmbox 2.99.1"
| #define PACKAGE_BUGREPORT "https://bugzilla.gnome.org/enter_bug.cgi?product=rhythmbox"
| #define PACKAGE_URL ""
| #define PACKAGE "rhythmbox"
| #define VERSION "2.99.1"
| /* end confdefs.h.  */
| int
| main ()
|   return 0;
configure:4151: error: in `/tmp/SBo/rhythmbox-2.99.1':
configure:4153: error: C compiler cannot create executables
## Cache variables. ##
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=set
ac_cv_env_CFLAGS_value='-O2 -fPIC'
ac_cv_env_CHECK_CFLAGS_set=
ac_cv_env_CHECK_CFLAGS_value=
ac_cv_env_CHECK_LIBS_set=
ac_cv_env_CHECK_LIBS_value=
ac_cv_env_CLUTTER_CFLAGS_set=
ac_cv_env_CLUTTER_CFLAGS_value=
ac_cv_env_CLUTTER_LIBS_set=
ac_cv_env_CLUTTER_LIBS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_DMAPSHARING_CFLAGS_set=
ac_cv_env_DMAPSHARING_CFLAGS_value=
ac_cv_env_DMAPSHARING_LIBS_set=
ac_cv_env_DMAPSHARING_LIBS_value=
ac_cv_env_GRILO_CFLAGS_set=
ac_cv_env_GRILO_CFLAGS_value=
ac_cv_env_GRILO_LIBS_set=
ac_cv_env_GRILO_LIBS_value=
ac_cv_env_GSTREAMER_CFLAGS_set=
ac_cv_env_GSTREAMER_CFLAGS_value=
ac_cv_env_GSTREAMER_LIBS_set=
ac_cv_env_GSTREAMER_LIBS_value=
ac_cv_env_GTKDOC_DEPS_CFLAGS_set=
ac_cv_env_GTKDOC_DEPS_CFLAGS_value=
ac_cv_env_GTKDOC_DEPS_LIBS_set=
ac_cv_env_GTKDOC_DEPS_LIBS_value=
ac_cv_env_GUDEV_CFLAGS_set=
ac_cv_env_GUDEV_CFLAGS_value=
ac_cv_env_GUDEV_LIBS_set=
ac_cv_env_GUDEV_LIBS_value=
ac_cv_env_HAL_CFLAGS_set=
ac_cv_env_HAL_CFLAGS_value=
ac_cv_env_HAL_LIBS_set=
ac_cv_env_HAL_LIBS_value=
ac_cv_env_IPOD_CFLAGS_set=
ac_cv_env_IPOD_CFLAGS_value=
ac_cv_env_IPOD_LIBS_set=
ac_cv_env_IPOD_LIBS_value=
ac_cv_env_ITSTOOL_set=
ac_cv_env_ITSTOOL_value=
ac_cv_env_LDFLAGS_set=set
ac_cv_env_LDFLAGS_value=-ltdb
ac_cv_env_LIBBRASERO_MEDIA_CFLAGS_set=
ac_cv_env_LIBBRASERO_MEDIA_CFLAGS_value=
ac_cv_env_LIBBRASERO_MEDIA_LIBS_set=
ac_cv_env_LIBBRASERO_MEDIA_LIBS_value=
ac_cv_env_LIBSECRET_CFLAGS_set=
ac_cv_env_LIBSECRET_CFLAGS_value=
ac_cv_env_LIBSECRET_LIBS_set=
ac_cv_env_LIBSECRET_LIBS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_MOZILLA_PLUGINDIR_set=
ac_cv_env_MOZILLA_PLUGINDIR_value=
ac_cv_env_MTP_CFLAGS_set=
ac_cv_env_MTP_CFLAGS_value=
ac_cv_env_MTP_LIBS_set=
ac_cv_env_MTP_LIBS_value=
ac_cv_env_NOTIFY_CFLAGS_set=
ac_cv_env_NOTIFY_CFLAGS_value=
ac_cv_env_NOTIFY_LIBS_set=
ac_cv_env_NOTIFY_LIBS_value=
ac_cv_env_PKG_CONFIG_LIBDIR_set=
ac_cv_env_PKG_CONFIG_LIBDIR_value=
ac_cv_env_PKG_CONFIG_PATH_set=
ac_cv_env_PKG_CONFIG_PATH_value=
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_PYTHON_CFLAGS_set=
ac_cv_env_PYTHON_CFLAGS_value=
ac_cv_env_PYTHON_LIBS_set=
ac_cv_env_PYTHON_LIBS_value=
ac_cv_env_PYTHON_set=
ac_cv_env_PYTHON_value=
ac_cv_env_RB_CLIENT_CFLAGS_set=
ac_cv_env_RB_CLIENT_CFLAGS_value=
ac_cv_env_RB_CLIENT_LIBS_set=
ac_cv_env_RB_CLIENT_LIBS_value=
ac_cv_env_RHYTHMBOX_CFLAGS_set=
ac_cv_env_RHYTHMBOX_CFLAGS_value=
ac_cv_env_RHYTHMBOX_LIBS_set=
ac_cv_env_RHYTHMBOX_LIBS_value=
ac_cv_env_TOTEM_PLPARSER_CFLAGS_set=
ac_cv_env_TOTEM_PLPARSER_CFLAGS_value=
ac_cv_env_TOTEM_PLPARSER_LIBS_set=
ac_cv_env_TOTEM_PLPARSER_LIBS_value=
ac_cv_env_WEBKIT_CFLAGS_set=
ac_cv_env_WEBKIT_CFLAGS_value=
ac_cv_env_WEBKIT_LIBS_set=
ac_cv_env_WEBKIT_LIBS_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_XMLLINT_set=
ac_cv_env_XMLLINT_value=
ac_cv_env_build_alias_set=set
ac_cv_env_build_alias_value=x86_64-slackware-linux
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_path_ac_pt_PKG_CONFIG=/usr/bin/pkg-config
ac_cv_path_install='/bin/ginstall -c'
ac_cv_path_mkdir=/bin/mkdir
ac_cv_prog_AWK=gawk
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_make_make_set=yes
am_cv_make_support_nested_variables=yes
## Output variables. ##
ACLOCAL='${SHELL} /tmp/SBo/rhythmbox-2.99.1/missing --run aclocal-1.12'
ACLOCAL_AMFLAGS='-I macros'
ALL_LINGUAS=''
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='$${TAR-tar}'
AM_BACKSLASH='\'
AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)'
AM_DEFAULT_VERBOSITY='0'
AM_V='$(V)'
AR=''
AUTOCONF='${SHELL} /tmp/SBo/rhythmbox-2.99.1/missing --run autoconf'
AUTOHEADER='${SHELL} /tmp/SBo/rhythmbox-2.99.1/missing --run autoheader'
AUTOMAKE='${SHELL} /tmp/SBo/rhythmbox-2.99.1/missing --run automake-1.12'
AWK='gawk'
CATALOGS=''
CATOBJEXT=''
CC='gcc'
CCDEPMODE=''
CFLAGS='-O2 -fPIC'
CHECK_CFLAGS=''
CHECK_LIBS=''
CLUTTER_CFLAGS=''
CLUTTER_LIBS=''
CPP=''
CPPFLAGS=''
CYGPATH_W='echo'
DATADIRNAME=''
DEFS=''
DEPDIR='.deps'
DISABLE_DEPRECATED=' -DGCONF_DISABLE_DEPRECATED -DGCONF_DISABLE_SINGLE_INCLUDES -DBONOBO_DISABLE_DEPRECATED -DBONOBO_DISABLE_SINGLE_INCLUDES -DBONOBO_UI_DISABLE_DEPRECATED -DBONOBO_UI_DISABLE_SINGLE_INCLUDES -DGNOME_DISABLE_DEPRECATED -DGNOME_DISABLE_SINGLE_INCLUDES -DLIBGLADE_DISABLE_DEPRECATED -DLIBGLADE_DISABLE_SINGLE_INCLUDES -DGNOME_VFS_DISABLE_DEPRECATED -DGNOME_VFS_DISABLE_SINGLE_INCLUDES -DWNCK_DISABLE_DEPRECATED -DWNCK_DISABLE_SINGLE_INCLUDES -DLIBSOUP_DISABLE_DEPRECATED -DLIBSOUP_DISABLE_SINGLE_INCLUDES'
DLLTOOL=''
DMAPSHARING_CFLAGS=''
DMAPSHARING_LIBS=''
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
ENABLE_BROWSER_PLUGIN_FALSE=''
ENABLE_BROWSER_PLUGIN_TRUE=''
ENABLE_FM_RADIO_FALSE=''
ENABLE_FM_RADIO_TRUE=''
ENABLE_GRILO_FALSE=''
ENABLE_GRILO_TRUE=''
ENABLE_GTK_DOC_FALSE=''
ENABLE_GTK_DOC_TRUE=''
ENABLE_PYTHON_FALSE=''
ENABLE_PYTHON_TRUE=''
ENABLE_VALA_FALSE=''
ENABLE_VALA_TRUE=''
EXEEXT=''
FGREP=''
GDK_PIXBUF_CSOURCE=''
GETTEXT_PACKAGE=''
GLIB_COMPILE_SCHEMAS=''
GLIB_GENMARSHAL=''
GMOFILES=''
GMSGFMT=''
GREP=''
GRILO_CFLAGS=''
GRILO_LIBS=''
GSETTINGS_DISABLE_SCHEMAS_COMPILE=''
GSETTINGS_RULES=''
GSTREAMER_CFLAGS=''
GSTREAMER_LIBS=''
GTKDOC_CHECK=''
GTKDOC_DEPS_CFLAGS=''
GTKDOC_DEPS_LIBS=''
GTKDOC_MKPDF=''
GTKDOC_REBASE=''
GTK_DOC_BUILD_HTML_FALSE=''
GTK_DOC_BUILD_HTML_TRUE=''
GTK_DOC_BUILD_PDF_FALSE=''
GTK_DOC_BUILD_PDF_TRUE=''
GTK_DOC_USE_LIBTOOL_FALSE=''
GTK_DOC_USE_LIBTOOL_TRUE=''
GTK_DOC_USE_REBASE_FALSE=''
GTK_DOC_USE_REBASE_TRUE=''
GUDEV_CFLAGS=''
GUDEV_LIBS=''
HAL_CFLAGS=''
HAL_LIBS=''
HAVE_CHECK_FALSE=''
HAVE_CHECK_TRUE=''
HAVE_HAL_FALSE=''
HAVE_HAL_TRUE=''
HAVE_INTROSPECTION_FALSE='#'
HAVE_INTROSPECTION_TRUE=''
HAVE_LIBBRASERO_MEDIA=''
HAVE_LIBBRASERO_MEDIA_FALSE=''
HAVE_LIBBRASERO_MEDIA_TRUE=''
HELP_DIR=''
HTML_DIR=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
INSTOBJEXT=''
INTLLIBS=''
INTLTOOL_CAVES_RULE=''
INTLTOOL_DESKTOP_RULE=''
INTLTOOL_DIRECTORY_RULE=''
INTLTOOL_EXTRACT=''
INTLTOOL_KBD_RULE=''
INTLTOOL_KEYS_RULE=''
INTLTOOL_MERGE=''
INTLTOOL_OAF_RULE=''
INTLTOOL_PERL=''
INTLTOOL_POLICY_RULE=''
INTLTOOL_PONG_RULE=''
INTLTOOL_PROP_RULE=''
INTLTOOL_SCHEMAS_RULE=''
INTLTOOL_SERVER_RULE=''
INTLTOOL_SERVICE_RULE=''
INTLTOOL_SHEET_RULE=''
INTLTOOL_SOUNDLIST_RULE=''
INTLTOOL_THEME_RULE=''
INTLTOOL_UI_RULE=''
INTLTOOL_UPDATE=''
INTLTOOL_V_MERGE=''
INTLTOOL_V_MERGE_OPTIONS=''
INTLTOOL_XAM_RULE=''
INTLTOOL_XML_NOMERGE_RULE=''
INTLTOOL_XML_RULE=''
INTLTOOL__v_MERGE_0=''
INTLTOOL__v_MERGE_=''
INTROSPECTION_CFLAGS='-pthread -I/usr/include/gobject-introspection-1.0 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include  '
INTROSPECTION_COMPILER='/usr/bin/g-ir-compiler'
INTROSPECTION_GENERATE='/usr/bin/g-ir-generate'
INTROSPECTION_GIRDIR='/usr/share/gir-1.0'
INTROSPECTION_LIBS='-lgirepository-1.0 -lgobject-2.0 -lglib-2.0  '
INTROSPECTION_MAKEFILE='/usr/share/gobject-introspection-1.0/Makefile.introspection'
INTROSPECTION_SCANNER='/usr/bin/g-ir-scanner'
INTROSPECTION_TYPELIBDIR='/usr/lib64/girepository-1.0'
IPOD_CFLAGS=''
IPOD_LIBS=''
ITMS_HANDLER=''
ITSTOOL=''
LD=''
LDFLAGS='-ltdb'
LIBBRASERO_MEDIA_CFLAGS=''
LIBBRASERO_MEDIA_LIBS=''
LIBOBJS=''
LIBS=''
LIBSECRET_CFLAGS=''
LIBSECRET_LIBS=''
LIBTOOL=''
LIPO=''
LN_S=''
LTLIBOBJS=''
MAINT=''
MAINTAINER_MODE_FALSE='#'
MAINTAINER_MODE_TRUE=''
MAKEINFO='${SHELL} /tmp/SBo/rhythmbox-2.99.1/missing --run makeinfo'
MANIFEST_TOOL=''
MKDIR_P='/bin/mkdir -p'
MKINSTALLDIRS=''
MOZILLA_PLUGINDIR=''
MSGFMT=''
MSGFMT_OPTS=''
MSGMERGE=''
MTP_CFLAGS=''
MTP_LIBS=''
NM=''
NMEDIT=''
NOTIFY_CFLAGS=''
NOTIFY_LIBS=''
NO_STRICT_ALIASING_CFLAGS=''
OBJDUMP=''
OBJEXT=''
OTOOL64=''
OTOOL=''
PACKAGE='rhythmbox'
PACKAGE_BUGREPORT='https://bugzilla.gnome.org/enter_bug.cgi?product=rhythmbox'
PACKAGE_NAME='rhythmbox'
PACKAGE_STRING='rhythmbox 2.99.1'
PACKAGE_TARNAME='rhythmbox'
PACKAGE_URL=''
PACKAGE_VERSION='2.99.1'
PATH_SEPARATOR=':'
PKG_CONFIG='/usr/bin/pkg-config'
PKG_CONFIG_LIBDIR=''
PKG_CONFIG_PATH=''
PLUGINDATADIR=''
PLUGINDIR=''
PLUGIN_LIBTOOL_FLAGS=''
POFILES=''
POSUB=''
PO_IN_DATADIR_FALSE=''
PO_IN_DATADIR_TRUE=''
PYTHON=''
PYTHON_CFLAGS=''
PYTHON_EXEC_PREFIX=''
PYTHON_LIBS=''
PYTHON_PLATFORM=''
PYTHON_PREFIX=''
PYTHON_VERSION=''
PY_LIBSECRET_ENABLED=''
RANLIB=''
RB_CLIENT_CFLAGS=''
RB_CLIENT_LIBS=''
RHYTHMBOX_CFLAGS=''
RHYTHMBOX_CFLAGS_NOWARN=''
RHYTHMBOX_CORE_AGE='0'
RHYTHMBOX_CORE_CURRENT='7'
RHYTHMBOX_CORE_REVISION='0'
RHYTHMBOX_LIBS=''
ROOT_UNINSTALLED_DIR=''
SAMPLEPLUGINDIR=''
SED=''
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
TOTEM_PLPARSER_CFLAGS=''
TOTEM_PLPARSER_LIBS=''
USE_CLUTTER_FALSE=''
USE_CLUTTER_TRUE=''
USE_GUDEV_FALSE=''
USE_GUDEV_TRUE=''
USE_IPOD_FALSE=''
USE_IPOD_TRUE=''
USE_LIBDMAPSHARING_FALSE=''
USE_LIBDMAPSHARING_TRUE=''
USE_LIBSECRET_FALSE=''
USE_LIBSECRET_TRUE=''
USE_MTP_FALSE=''
USE_MTP_TRUE=''
USE_NLS='yes'
USE_NOTIFY_FALSE=''
USE_NOTIFY_TRUE=''
USE_TREEDB_FALSE=''
USE_TREEDB_TRUE=''
VALAC=''
VAPIDIR=''
VAPIGEN=''
VERSION='2.99.1'
WARN_CFLAGS=''
WEBKIT_CFLAGS=''
WEBKIT_LIBS=''
WITH_LIRC_FALSE=''
WITH_LIRC_TRUE=''
WITH_WEBKIT_FALSE=''
WITH_WEBKIT_TRUE=''
WNOERROR_CFLAGS=''
XGETTEXT=''
XMKMF=''
XMLLINT=''
X_CFLAGS=''
X_EXTRA_LIBS=''
X_LIBS=''
X_PRE_LIBS=''
YELP_HELP_RULES=''
ac_ct_AR=''
ac_ct_CC='gcc'
ac_ct_DUMPBIN=''
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__include='include'
am__isrc=''
am__leading_dot='.'
am__nodep='_no'
am__quote=''
am__tar='$${TAR-tar} chof - "$$tardir"'
am__untar='$${TAR-tar} xf -'
bindir='${exec_prefix}/bin'
build='x86_64-slackware-linux'
build_alias='x86_64-slackware-linux'
build_cpu=''
build_os=''
build_vendor=''
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='/usr/doc/rhythmbox-2.99.1'
dvidir='${docdir}'
exec_prefix='NONE'
gsettingsschemadir=''
host=''
host_alias=''
host_cpu=''
host_os=''
host_vendor=''
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='/usr/info'
install_sh='${SHELL} /tmp/SBo/rhythmbox-2.99.1/install-sh'
intltool__v_merge_options_0=''
intltool__v_merge_options_=''
libdir='/usr/lib64'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='/var'
mandir='/usr/man'
mkdir_p='$(MKDIR_P)'
oldincludedir='/usr/include'
pdfdir='${docdir}'
pkgpyexecdir=''
pkgpythondir=''
prefix='/usr'
program_transform_name='s,x,x,'
psdir='${docdir}'
pyexecdir=''
pyoverridesdir=''
pythondir=''
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='/etc'
target_alias=''
## confdefs.h. ##
/* confdefs.h */
configure: exit 77
per prima cosa ho reinstallato kernel headers gcc e glibc che non si sa mai ci sia qualcosa di corrotto, però il risultato si ripresenta identico. Nel file log, leggo che non riconosce l'opzione "-V" passata a gcc, ma non saprei cosa esattamente modificare...avete un'idea?
Ho cercato un po' con google ma le informazioni sono molto dispersive e nella mia ignoranza non trovo la soluzione illuminante a ciò.
Kernel: 7.0.12
Re: rhythmbox errore c compiler
hai fatto un'installazione completa? e' aggiornata?
perche' l'errore
mi sembra legato al fatto che ti manca l'ultima versione di samba (e' stato rilasciato un pacchetto aggiornato per la 14.1).
gigiobagiano
Beccato grazie mille!
