Ho notato che oltre a installpkg, removepkg, upgradepkg, la distro ha anche slackpkg e slackyd dove il secondo mi piace di più perchè gestisce le dipendenze, solo cheslackpkg installa il pacchetto che cerco e basta, ma non mi vede i mirrors non ufficiali.
Slackyd invece vede le dipendenze solo che non installa ma li scarica (mi può stare anche bene), solo che non riesco a capire come usarlo, cioè digitando
slackyd -hCodice: Seleziona tutto
Usage: slackyd <options> <package>
Options:
-5: Skip md5 verify.
-b: Try to download package build sources.
-B: Try to build package from sources.
-c: Use alternate config file.
-d: Search missing shared libraries of installed packages.
-D: Search missing required packages (packager-indicated).
-e: Use regex.
-f: Force update or packages download. Assume yes to all question.
-g: Download package.
-h: Show this help.
-I: Skip packages status check.
-l: List all packages installed.
-L: List all non-slackware packages installed.
-m: Case insensitive.
-n: Only notify broken dependencies.
-O: List all orphan packages.
-p: Clean slackyd directory (only packages and sources).
-P: Clean slackyd directory (all).
-q: Quiet, disable some warnings.
-r: Search not official replaceable packages.
-R: Show repositories statistics.
-s: Search package.
-S: Skip dependencies check.
-t: Specify a path to download packages
-u: Update packages list and md5 hash list.
-U: Search new packages.
-v: Verbose mode.
-V: Show slackyd info.
-w: View package info.
-x: Disable blacklist.
-X: Show packages available and blacklisted.
