HPLIP non riconosce PPD file della mia wireless
roberto67
Slackware: 15.0 multilib
Desktop: plasma 5
Messaggio da roberto67 »
Sono sulla current fresca di ieri (32b).
Dopo aver installato la mia Officejet_4500_G510n-z con il cavo USB attaccato, vado a fare il wireless setup, ma
$ hp-setup 192.168.1.85
HP Linux Imaging and Printing System (ver. 3.15.11)
Printer/Fax Setup Utility ver. 9.0
Copyright (c) 2001-15 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Searching for device...
Found device: hp:/net/Officejet_4500_G510n-z?ip=192.168.1.85
error: No PPD found for model officejet_4500_g510n-z using old algorithm.
error: No appropriate print PPD file found for model officejet_4500_g510n-z
error:  Printer queue setup failed.   Error : successful-ok-ignored-or-substituted-attributes
error:  Fax queue setup failed.  Error : successful-ok-ignored-or-substituted-attributes
Done.
Ovvero non accetta il file PPD di cups
/usr/share/cups/model/HP/hp-officejet_4500_g510n-z.ppd.gz
..e dopo due ore non ho trovato nulla di utile su google
Qualcuno avrebbe una dritta da darmi? ;)
