[RISOLTO] Problemi con slackpkg e slackpkg+
nyquist
Nome Cognome: Cristiano Urban
Slackware: 14.2 multilib
Kernel: 4.4.240
Messaggio da nyquist »
Ciao a tutti,
da qualche giorno lanciando slackpkg update, nella parte finale dell'output, ottengo un errore relativo al checksum del repository di Slackware.
Credo tutto sia iniziato con l'aggiornamento di tcpdump del 24 luglio.
Oggi ho dato uno slackpkg update gpg e quello che ottengo è questo:
bash-4.3# slackpkg update gpg
gpg: processing message failed: eof
                   !!! F A T A L !!!
    Slackware repository does NOT contain the Official GPG-KEY
    You SHOULD disable GPG Strict check 'STRICTGPG=off'
    in /etc/slackpkg/slackpkgplus.conf
2017-07-27 10:09:50 URL:http://slakfinder.org/slackpkg+/GPG-KEY [1823/1823] -> "/tmp/slackpkg.13zlrp/gpgkey-tmp-slackpkgplus" [1]
pub  2048R/ED123FBC 2011-01-01 Matteo Rossini <zerouno@slacky.it>
sub  2048R/2B41569A 2011-01-01
gpg: key ED123FBC: "Matteo Rossini <zerouno@slacky.it>" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1
2017-07-27 10:09:51 URL:http://bear.alienbase.nl/mirrors/people/alien/multilib/14.2/GPG-KEY [11137/11137] -> "/tmp/slackpkg.13zlrp/gpgkey-tmp-multilib" [1]
pub  1024D/A75CBDA0 2003-01-17 Eric Hameleers (IBM Linux) <alien@linux.vnet.ibm.com>
uid                            Eric Hameleers (Thuis) <e.hameleers@chello.nl>
uid                            Eric Hameleers (IBM Linux) <alien@nl.ibm.com>
uid                            Eric Hameleers <eric.hameleers@int.greenpeace.org>
uid                            Eric Hameleers <alien@sox.homeip.net>
uid                            Eric Hameleers <alien@slackware.com>
uid                            [jpeg image of size 3054]
uid                            Eric Hameleers (SBo) <alien@slackbuilds.org>
sub  1792g/7CBDC819 2003-01-17
gpg: key A75CBDA0: "Eric Hameleers <alien@slackware.com>" not changed
gpg:              unchanged: 1
2017-07-27 10:09:51 URL:http://bear.alienbase.nl/mirrors/people/alien/sbrepos/14.2/x86_64/GPG-KEY [17332/17332] -> "/tmp/slackpkg.13zlrp/gpgkey-tmp-alienbob" [1]
pub  1024D/A75CBDA0 2003-01-17 Eric Hameleers <alien@slackware.com>
uid                            Eric Hameleers (IBM Linux) <alien@linux.vnet.ibm.com>
uid                            Eric Hameleers <eric.hameleers@alienbase.nl>
gpg:              unchanged: 1
  WARNING! One or more errors occurred while slackpkg was running
Fatal: Slackware repository does not contains the official gpg-key!!
bash-4.3# clear
                   !!! F A T A L !!!
2017-07-27 10:15:40 URL:http://slakfinder.org/slackpkg+/GPG-KEY [1823/1823] -> "/tmp/slackpkg.wYcmCp/gpgkey-tmp-slackpkgplus" [1]
gpg:              unchanged: 1
2017-07-27 10:15:40 URL:http://bear.alienbase.nl/mirrors/people/alien/multilib/14.2/GPG-KEY [11137/11137] -> "/tmp/slackpkg.wYcmCp/gpgkey-tmp-multilib" [1]
gpg:              unchanged: 1
2017-07-27 10:15:41 URL:http://bear.alienbase.nl/mirrors/people/alien/sbrepos/14.2/x86_64/GPG-KEY [17332/17332] -> "/tmp/slackpkg.wYcmCp/gpgkey-tmp-alienbob" [1]
gpg:              unchanged: 1
bash-4.3#
Ho provato a disabilitare l'opzione STRICTGPG=off:
gpg: no valid OpenPGP data found.
2017-07-27 10:25:57 URL:http://slakfinder.org/slackpkg+/GPG-KEY [1823/1823] -> "/tmp/slackpkg.Qoy79q/gpgkey-tmp-slackpkgplus" [1]
gpg:              unchanged: 1
2017-07-27 10:25:57 URL:http://bear.alienbase.nl/mirrors/people/alien/multilib/14.2/GPG-KEY [11137/11137] -> "/tmp/slackpkg.Qoy79q/gpgkey-tmp-multilib" [1]
gpg:              unchanged: 1
2017-07-27 10:25:57 URL:http://bear.alienbase.nl/mirrors/people/alien/sbrepos/14.2/x86_64/GPG-KEY [17332/17332] -> "/tmp/slackpkg.Qoy79q/gpgkey-tmp-alienbob" [1]
gpg:              unchanged: 1
Updating the package lists...
        Downloading...
                Saving ChangeLog.txt from repository slackpkgplus ...
                Saving ChangeLog.txt from repository multilib ...
                Saving ChangeLog.txt from repository alienbob ...
2017-07-27 10:26:00 URL:http://slakfinder.org/slackpkg+/CHECKSUMS.md5 [2200/2200] -> "/tmp/slackpkg.Qoy79q/CHECKSUMS.md5-slackpkgplus" [1]
2017-07-27 10:26:00 URL:http://bear.alienbase.nl/mirrors/people/alien/multilib/14.2/CHECKSUMS.md5 [115756/115756] -> "/tmp/slackpkg.Qoy79q/CHECKSUMS.md5-multilib" [1]
2017-07-27 10:26:01 URL:http://bear.alienbase.nl/mirrors/people/alien/sbrepos/14.2/x86_64/CHECKSUMS.md5 [176952/176952] -> "/tmp/slackpkg.Qoy79q/CHECKSUMS.md5-alienbob" [1]
                No changes in ChangeLog.txt between your last update and now.
                Do you really want to download all other files (y/N)? y
                List of all files
2017-07-27 10:26:07 URL:http://slakfinder.org/slackpkg+/MANIFEST.bz2 [576/576] -> "/tmp/slackpkg.Qoy79q/SLACKPKGPLUS_slackpkgplus-MANIFEST.bz2" [1]
2017-07-27 10:26:07 URL:http://bear.alienbase.nl/mirrors/people/alien/multilib/14.2/MANIFEST.bz2 [206786/206786] -> "/tmp/slackpkg.Qoy79q/SLACKPKGPLUS_multilib-MANIFEST.bz2" [1]
2017-07-27 10:26:08 URL:http://bear.alienbase.nl/mirrors/people/alien/sbrepos/14.2/x86_64/MANIFEST.bz2 [824639/824639] -> "/tmp/slackpkg.Qoy79q/SLACKPKGPLUS_alienbob-MANIFEST.bz2" [1]
                Checksums
2017-07-27 10:26:10 URL:http://slakfinder.org/slackpkg+/CHECKSUMS.md5.asc [473/473] -> "/tmp/slackpkg.Qoy79q/CHECKSUMS.md5-slackpkgplus.asc" [1]
2017-07-27 10:26:10 URL:http://bear.alienbase.nl/mirrors/people/alien/multilib/14.2/CHECKSUMS.md5.asc [181/181] -> "/tmp/slackpkg.Qoy79q/CHECKSUMS.md5-multilib.asc" [1]
2017-07-27 10:26:11 URL:http://bear.alienbase.nl/mirrors/people/alien/sbrepos/14.2/x86_64/CHECKSUMS.md5.asc [181/181] -> "/tmp/slackpkg.Qoy79q/CHECKSUMS.md5-alienbob.asc" [1]
                ERROR: Verification of the  gpg signature on CHECKSUMS.md5
                       failed! This could mean that the file is out of date
                       or has been tampered with.
bash-4.3#
(e poi a riabilitarla), sia a lanciare slackpkg -checkgpg=off update, ma sembra non si riesca a risolvere.
Avete mica qualche dritta da darmi?
Grazie in anticipo per la disponibilità.
Ultima modifica di nyquist il ven 28 lug 2017, 9:53, modificato 1 volta in totale.
nyquist
Kernel: 4.4.240
Re: Problemi con slackpkg e slackpkg+
Ok, penso di aver risolto.
Ho cambiato mirror da questo
ftp://ba.mirror.garr.it/mirrors/Slackware/slackware64-14.2/
a quello http ufficiale:
http://mirrors.slackware.com/slackware/slackware64-14.2/
Poi ho lanciato i seguenti comandi:
slackpkg update gpg,
slackpkg update,
e, infine, slackpkg upgrade-all per aggiornare i pacchetti che mi mancavano.
Re: [RISOLTO] Problemi con slackpkg e slackpkg+
Io uso na.mirror.garr.it/Slackware/ che ha anche rsync e non mi da errori, però non si aggiorna subito come altri, ma con linea telecom va molto più veloce.
nyquist
Kernel: 4.4.240
conraid ha scritto: Io uso na.mirror.garr.it/Slackware/ che ha anche rsync e non mi da errori, però non si aggiorna subito come altri, ma con linea telecom va molto più veloce.
Quindi l'hai aggiunto a mano in /etc/slackpkg/mirrors. Grazie mille, buono a sapersi!
No, uso rsync per sincronizzare, poi in slackpkg ho file:// e percorso nel filesystem.
nyquist
Kernel: 4.4.240
conraid ha scritto: No, uso rsync per sincronizzare, poi in slackpkg ho file:// e percorso nel filesystem.
Perfetto, grazie ancora!
kimotori
Desktop: MATE
Messaggio da kimotori »
Molto spesso mi son trovato in queste situazioni, e quasi sempre mi sono chiesto, a sto punto non converrebbe usare gentoo?
Alla fine non facciamo altro che come il sync in emerge nel portage che lo copia sul filesystem...
Saluti
kimotori ha scritto:Molto spesso mi son trovato in queste situazioni, e quasi sempre mi sono chiesto, a sto punto non converrebbe usare gentoo?
Saluti
Ma no, copiamo il repository in una risorsa locale (io su hd esterno) per non avere problemi di rete durante installazione/upgrade, magari su più macchine.
kimotori
Desktop: MATE
Saluti
Ah bè in questo caso è più comodo, però scusa se riapro l' argomento, ma attualmente slackpkg+ gestisce le dipendenze in automatico o mi devo leggere comunque gli slackbuild?
P.S.
Confesso che faccio altrettanto per alcune macchine su netbsd con pkgsrc :)
kimotori ha scritto: Ah bè in questo caso è più comodo, però scusa se riapro l' argomento, ma attualmente slackpkg+ gestisce le dipendenze in automatico o mi devo leggere comunque gli slackbuild?
non gestisce le dipendenze, e nemmeno aprendo lo slackbuild le vedi.
Alcuni (tra cui Sbo) indicano le dipendenze in file di testo allegati, ma non c'è uno standard e non tutti lo fanno. Per essere sicuro avvii e vedi cosa manca.
Però consiglio di leggere sempre i file allegati (README, .info, .dep, etc...) se ci sono.
kimotori
Desktop: MATE
Quindi, scusa se approfitto a far domande, immagino sia meglio riformulare le vecchie domande o riaprire vecchi post, ma cosa è cambiato, in tutti questi anni? Nulla?
Oltre che il compilarsi da solo il necessario, qualche automatismo si è integrato nel sistema?
Ultima domanda :) Ma i repo di slacky.eu si son svuotati?
kimotori ha scritto: Quindi, scusa se approfitto a far domande, immagino sia meglio riformulare le vecchie domande o riaprire vecchi post, ma cosa è cambiato, in tutti questi anni? Nulla?
Per fortuna nulla ;)
In realtà molto, ora c'è appunto slackpkg che è un gestore pacchetti ufficiale e funziona benissimo. Per esempio prima per aggiornare c'erano procedure da seguire, tanto che io stesso feci uno "slackware current for dummies". Ora bastano 3 comandi di slackpkg per far tutto. Ma la gestione dipendenze non è ancora automatica, per fortuna appunto.
kimotori ha scritto: Oltre che il compilarsi da solo il necessario, qualche automatismo si è integrato nel sistema?
Ma no, puoi compilarti il necessario, o prenderlo dai vari repository in giro.
kimotori ha scritto: Ultima domanda :) Ma i repo di slacky.eu si son svuotati?
Ci son meno persone, me compreso, e quindi non è molto aggiornato :(
Poi ora Slackbuilds.org è diventato quasi "ufficiale" per i pacchetti della "stable".
