libmypaint in current
dafrasaga
Messaggio da dafrasaga »
Ciao a tutti,
dato che vorrei installare GIMP da git ho dovuto ( per il momento su VM) upgradare alla current dalla 14.2 per avere glib2-2.0 versione 2.54..
In verità ho installato la 2.54 e 2.55 da git sulla 14.2 ma avevo in continuazione errori nella fase di compilazione ...
Adesso in current dopo avere installato babl e gegl da git devo installare una dipendenza di GIMp e cioè https://github.com/mypaint/libmypaint.. La configurazione va a buon fine ma quando tento di conpilare ho:
    make[2]: Entering directory '/root/git/libmypaint’
    depbase=echo mypaint-brush.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||';
    /bin/sh ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/usr/local/include/json-c -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -D_POSIX_C_SOURCE=200809L -g -O2 -MT mypaint-brush.lo -MD -MP -MF $depbase.Tpo -c -o mypaint-brush.lo mypaint-brush.c &&
    mv -f $depbase.Tpo $depbase.Plo
    libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/usr/local/include/json-c -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -D_POSIX_C_SOURCE=200809L -g -O2 -MT mypaint-brush.lo -MD -MP -MF .deps/mypaint-brush.Tpo -c mypaint-brush.c -fPIC -DPIC -o .libs/mypaint-brush.o
    mypaint-brush.c: In function ‘mypaint_brush_new’:
    mypaint-brush.c:133:26: error: ‘FALSE’ undeclared (first use in this function); did you mean ‘FILE’?
    self->print_inputs = FALSE;
    FILE
    mypaint-brush.c:133:26: note: each undeclared identifier is reported only once for each function it appears in
    mypaint-brush.c:142:29: error: ‘TRUE’ undeclared (first use in this function)
    self->reset_requested = TRUE;
    mypaint-brush.c: In function ‘mypaint_brush_reset’:
    mypaint-brush.c:225:29: error: ‘TRUE’ undeclared (first use in this function)
    mypaint-brush.c: In function ‘mypaint_brush_stroke_to’:
    mypaint-brush.c:961:31: error: ‘FALSE’ undeclared (first use in this function); did you mean ‘FILE’?
    self->reset_requested = FALSE;
    FILE
    mypaint-brush.c:980:14: error: ‘TRUE’ undeclared (first use in this function)
    return TRUE;
    mypaint-brush.c: In function ‘obj_get’:
    mypaint-brush.c:1100:44: error: ‘TRUE’ undeclared (first use in this function)
    && (obj_out ? (*obj_out != NULL) : TRUE);
    mypaint-brush.c: In function ‘update_brush_setting_from_json_object’:
    mypaint-brush.c:1120:16: error: ‘FALSE’ undeclared (first use in this function); did you mean ‘FILE’?
    return FALSE;
    FILE
    mypaint-brush.c:1167:12: error: ‘TRUE’ undeclared (first use in this function)
    return TRUE;
    mypaint-brush.c: In function ‘update_brush_from_json_object’:
    mypaint-brush.c:1177:16: error: ‘FALSE’ undeclared (first use in this function); did you mean ‘FILE’?
    return FALSE;
    FILE
    mypaint-brush.c:1193:28: error: ‘TRUE’ undeclared (first use in this function)
    gboolean updated_all = TRUE;
    mypaint-brush.c: In function ‘mypaint_brush_from_string’:
    mypaint-brush.c:1227:16: error: ‘FALSE’ undeclared (first use in this function); did you mean ‘FILE’?
    return FALSE;
    FILE
    make[2]: *** [Makefile:730: mypaint-brush.lo] Error 1
    make[2]: Leaving directory '/root/git/libmypaint’
    make[1]: *** [Makefile:840: all-recursive] Error 1
    make[1]: Leaving directory '/root/git/libmypaint’
    make: *** [Makefile:598: all] Error 2
Sembra che manchino alcune definizioni, ma non so dove..
Avete idee??
GRazi emille
Re: libmypaint in current
dafrasaga
conraid ha scritto:Prendi la patch da archlinux
https://aur.archlinux.org/cgit/aur.git/ ... libmypaint
Grazie Conraid,
ma non sono tanto ferrato nelle patches..
In definitiva cosa devo fare?? :(
Prendi il file https://github.com/mypaint/libmypaint/r ... 3.0.tar.xz lo decomprimi in una directory, poi copi la patch nella stessa directory e dai questo comando
patch -uNp2 -r- -i versioning.patch
Il problema è che ti darà errore perché pensa che hai preso da git, devi togliere qualche riga. Aspetta ti copio quella che ho usato io.
Scarichi quella che ti ho allegato, la copi dove hai il codice e dai
patch -p1 versioning.patch
dovrebbe andare.
poi dai
autoreconf -fi
prima del configure
Ho ricompilato poco fa libmypaint per la current (ma la versione 1.3.0 non l'ultima git, che altrimenti la patch non va bene)
versioning.patch
(20.19 KiB) Scaricato 94 volte
Quanto poi compili gimp devi modificare una cosa altrimenti non va
sed -i "s:\(libmypaint\)\( >= libmypaint_required_version\):\1-1.3\2:g" configure.ac
e poi dai
autoreconf -fi
prima del configure
Stessa cosa (autoreconf) devi fare in libmypaint mi raccomando
dafrasaga
quindi in libmypaint dopo avere applicato la patch, prima del configure?
PS. Sei riuscito ad installare gimp da git sulla current??
Non da git, la 2.9.8
Se vuoi ti metto da qualche parte i pacchetti.
dafrasaga
conraid ha scritto:Non da git, la 2.9.8
Ora voglio provare io per farmi esperienza, semmai mi faccio vivo.. ;)
Ma questi problemi ci sono per la nostra distro oppure altro??
Quale problemi? Considera che le patch e quelle modifiche le ho prese da archlinux, quindi ce l'hanno anche loro i problemi.
dafrasaga
Ok, stasera provo e ti faccio sapere ( è quasi un mese che mi ci stò sbattezzando )
dafrasaga
Ciao allora ho provato ma non ha funzionato...
ho sempre glki errori che non è definito FALSE e quantaltrro.
Ho controllato i file modificati con diff e le modifiche mi sembra siano state effettuate ( comunque ho dovuto dare patch -p1 < versioning.patch (con il <) e poi fatto il autoreconf.
Evidentemente mi manca qualcos'altro :|
Per la cronaca ho upgradato dalla 14.2 su una VM con slackpkg: prima con update-gpg, poi update, poi upgrade-all, poi install-new e poi clean system.. o ho sbagliato qualcosa oppure non so :?
Forse reinstallare una current di pacca e riprovare ? Domanda: siccome non mi ricordo.. per la current nuova di pacca posso utilizzare un cd di installazione qualunque e fagli puntare ai file della current su un'altra locazione oppure c'è una iso? Non la trovo sotto https://mirrors.slackware.com/slackware/slackware-iso/
Sì, mi son dimenticato un "-i" che è l'opzione per specificare il file
patch -p1 -i versioning.patch
Ricorda che io ho compilato la 1.3.0 di libmypaint, non la versione di sviluppo in git, magari han qualche bug non ancora risolto.
Riguardo le altre domande.
1) sì, la procedura slackpkg è corretta
2) L'ido puoi creartela da solo, come da spiegazioni nel README http://slackware.uk/slackware/slackware ... README.TXT
altrimenti prendi quella di Alien http://slackware.uk/people/alien-current-iso/
dafrasaga
conraid ha scritto: Ricorda che io ho compilato la 1.3.0 di libmypaint, non la versione di sviluppo in git, magari han qualche bug non ancora risolto.
Si ho preso la 1.3.0 sia con checkout in git sia il con https://github.com/mypaint/libmypaint/r ... 3.0.tar.xz
Mah, non so cosa pensare...
Vediamo se con una installazione vergine funziona...
