Vtown kde5
Vtown kde5
Alleluja. Me lo aspettavo massimo per giugno.
ktown muore e nasce vtown, per ora in /testing
Tue Nov 3 22:32:22 UTC 2020
Welcome to vtown, volkerdi's friendly takeover of alienBOB's ktown Plasma 5
packages! Enormous thanks are due to alienBOB for maintaining and leading
testing of Plasma 5 on the side, even as I wore out his patience (and likely
others as well). But now this has made it into /testing and it won't be all
that long before it'll hit the main tree, so test it out and let me know if
anything broke. Several packages have been given back their upstream names
since there's no real reason to do otherwise unless we were going to support
installing KDE4 at the same time, and we aren't. Qt4 won't even be sticking
around, but probably slackbuilds.org will take it up. I dropped kaudiocreator
(won't build), ktuberling and klettres (rather bloated for the probably limited
appeal), user-manager (seems to have been dropped by upstream), kdelibs (KDE4
library, not going to support that), kwebkitpart, and kpat (not adding three
new dependences only used for a solitaire game). In addition, it's probable
that digikam and its dependencies will be dropped. It's a great program, but
in my opinion it's just a little too big (especially the source) to ship by
default. To install the vtown packages, first you'll want to remove any KDE4
packages (the KDE and KDEI series in the main tree), any previous ktown packages
from alienBOB, and then install all of the packages in vtown/deps and vtown/kde
using upgradepkg --install-new. The previous advice on ConsoleKit2 was to remove
it since we've switched to elogind, but if you've got the latest rc.M it
shouldn't matter since ConsoleKit2 will not be started if elogind is installed.
Speaking of elogind, you'll probably notice that once elogind is installed X
or Wayland sessions will launch in the current console rather than on console 7.
Regarding the build numbers, the one before _vtown_ is the build number that
will be used when the merge to the main tree happens, and the one after _vtown_
is used in case any rebuilds need to happen while vtown is in /testing. That's
about it for the notes on this one. Thanks again to alienBOB, and to my friends
in the US - don't forget to vote. :-)
roberto67
Slackware: 15.0 multilib
Desktop: plasma 5
Re: Vtown kde5
Messaggio da roberto67 »
Matteo, usando il tuo slackpkg+ ho difficoltà a filtrare i pacchetti vtown. Non mi sono stati aggiornati molti pacchetti come attica, akonadi etc. e quindi ho la macchina in panne. Se inoltre lancio un clean-system mi propone di cancellare i pacchetti vtown. In slackpkgplus.conf ho levato ktown e messo "testing" ma mi vengono proposti anche gli altri pacchetti in testing che non voglio.
Come posso fare l'aggiornamento di questi pacchetti con slackpkg+?
Re: Vtown kde5
slackpkg install vtown
roberto67
Desktop: plasma 5
Re: Vtown kde5
ZeroUno ha scritto:
mer 4 nov 2020, 16:44
E' quello che ho fatto, ma mi vengono installati solo un minimo di pacchetti...
Re: Vtown kde5
Non ho fatto la verifica esaustiva.
Più tardi magari verifico.
Re: Vtown kde5
PKGS_PRIORITY=( multilib testing )
# grep vtown /var/lib/slackpkg/pkglist|wc
391
# ls /var/log/packages/|grep vtown|wc
391
mi pare vada
cosa ti rimane fuori?
roberto67
Desktop: plasma 5
Re: Vtown kde5
Scusami Matteo, avevo "kde" in blacklist. Ora va
Ti chiedo però una cosa
# ls /var/log/packages|grep vtown|wc
    390
    782
e mi salta all'occhio che in pkglist ci sono poco più del doppio dei pacchetti, diversamente dal tuo esempio. Aprendo il file ho visto che per ogni pacchetto ci sono in effetti due righe, ad esempio
testing quazip 1.1 x86_64 1_vtown_1 quazip-1.1-x86_64-1_vtown_1 ./testing/packages/vtown/deps txz
SLACKPKGPLUS_testing quazip 1.1 x86_64 1_vtown_1 quazip-1.1-x86_64-1_vtown_1 ./SLACKPKGPLUS_testing/packages/vtown/deps txz
è normale?
Re: Vtown kde5
Manda la configurazione
roberto67
Desktop: plasma 5
Re: Vtown kde5
USEBL=on
GREYLIST=off
PKGS_PRIORITY=( multilib testing restricted alienbob )
TAG_PRIORITY=off
REPOPLUS=( slackpkgplus multilib testing restricted alienbob )
Re: Vtown kde5
Stasera la provo.
roberto67
Desktop: plasma 5
Re: Vtown kde5
immagino che un effetto conseguente sia ad esempio questo, ovvero che un dato pacchetto compaia sia come installato che come non installato (stessa versione). Questo mi succede solo con la directory testing
# slackpkg search dbus
Looking for dbus in package list. Please wait... DONE
The list below shows all packages with name matching "dbus".
[ Status              ] [ Repository  ] [ Package                                               ]
  installed               multilib        dbus-compat32-1.12.20-x86_64-1compat32
  installed               multilib        dbus-glib-compat32-0.110-x86_64-2compat32
  installed               slackware64     dbus-glib-0.110-x86_64-2
  installed               slackware64     dbus-python-1.2.16-x86_64-2
  installed               testing         dbus-1.12.20-x86_64-2_vtown_1
  installed               testing         kdbusaddons-5.75.0-x86_64-1_vtown_1
  installed               testing         libdbusmenu-16.04.0-x86_64-1_vtown_1
  installed               testing         libdbusmenu-qt-0.9.3+16.04.20160218-x86_64-1_vtown_1
  uninstalled(masked)     slackware64     dbus-1.12.20-x86_64-1
  uninstalled(masked)     slackware64     libdbusmenu-qt-0.9.2-x86_64-3
  uninstalled(masked)     testing         dbus-1.12.20-x86_64-2_vtown_1
  uninstalled(masked)     testing         kdbusaddons-5.75.0-x86_64-1_vtown_1
  uninstalled(masked)     testing         libdbusmenu-16.04.0-x86_64-1_vtown_1
  uninstalled(masked)     testing         libdbusmenu-qt-0.9.3+16.04.20160218-x86_64-1_vtown_1
slackpkg+-1.7.0d1-noarch-10mt
Re: Vtown kde5
togli testing da REPOPLUS
e se hai MIRRORPLUS['testing']=...
rimuovila.
se ancora non va dammi il file intero (magari in allegato)
roberto67
Desktop: plasma 5
Re: Vtown kde5
ZeroUno ha scritto:
mer 4 nov 2020, 22:53
rimuovila.
Fatto. Il problema rimane invariato, sia lasciando testing in PKG_PRIORITY che non, in quest'ultimo caso ovviamente vtown verrebbe sovrascritto da kde4
Re: Vtown kde5
da REPOPLUS non da PKG_PRIORITY
dammi il file intero.
roberto67
Desktop: plasma 5
Re: Vtown kde5
ZeroUno ha scritto:
gio 5 nov 2020, 10:13
si da REPOPLUS l'ho tolto
eccolo http://files.sagredo.eu/slackpkgplus.conf
