Slackware current nuova di pacca e digikam
dafrasaga
Messaggio da dafrasaga »
Ciao a tutti,
dopo https://slacky.eu/forum/viewtopic.php?f=51&t=41546 vorrei installare digikam ma ho ancora problemi con la current.
Questa volta voglio fare a manina nel senso che ho scaricato l'intero git di slackbuild per current e a una a una compilo le dipendenze tramite lo **.Slackbuild
Arrivato a opencv-legacy ho subito problemi:
[  8%] Building CXX object modules/imgcodecs/CMakeFiles/opencv_imgcodecs.dir/src/grfmt_jpeg2000.cpp.o
cd /tmp/SBo/opencv-3.1.0/build/modules/imgcodecs && /usr/bin/c++ -DCVAPI_EXPORTS -DHAVE_WEBP -DIMGCODECS_EXPORTS -D__OPENCV_BUILD=1 -I/tmp/SBo/opencv-3.1.0/build -I/tmp/SBo/opencv-3.1.0/modules/imgcodecs/include -I/tmp/SBo/opencv-3.1.0/modules/imgcodecs/src -I/tmp/SBo/opencv-3.1.0/build/modules/imgcodecs -I/tmp/SBo/opencv-3.1.0/modules/core/include -I/tmp/SBo/opencv-3.1.0/modules/imgproc/include -isystem /usr/include/eigen3 -isystem /usr/include/OpenEXR -O2 -fPIC   -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wno-narrowing -Wno-delete-non-virtual-dtor -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -msse -msse2 -mno-avx -msse3 -mno-ssse3 -mno-sse4.1 -mno-sse4.2 -ffunction-sections -fvisibility=hidden -fvisibility-inlines-hidden -fopenmp -Wno-deprecated-declarations -O3 -DNDEBUG  -DNDEBUG -fPIC -o CMakeFiles/opencv_imgcodecs.dir/src/grfmt_jpeg2000.cpp.o -c /tmp/SBo/opencv-3.1.0/modules/imgcodecs/src/grfmt_jpeg2000.cpp
In file included from /tmp/SBo/opencv-3.1.0/modules/core/include/opencv2/core/core_c.h:48,
                 from /tmp/SBo/opencv-3.1.0/modules/imgproc/include/opencv2/imgproc/types_c.h:46,
                 from /tmp/SBo/opencv-3.1.0/modules/imgproc/include/opencv2/imgproc/imgproc_c.h:46,
                 from /tmp/SBo/opencv-3.1.0/modules/imgcodecs/src/precomp.hpp:51,
                 from /tmp/SBo/opencv-3.1.0/modules/imgcodecs/src/grfmt_jpeg2000.cpp:43:
/tmp/SBo/opencv-3.1.0/modules/core/include/opencv2/core/types_c.h: In copy constructor ‘CvMat::CvMat(const CvMat&)’:
/tmp/SBo/opencv-3.1.0/modules/core/include/opencv2/core/types_c.h:461:59: warning: ‘void* memcpy(void*, const void*, size_t)’ writing to an object of non-trivially copyable type ‘struct CvMat’; use copy-assignment or copy-initialization instead [-Wclass-memaccess]
  461 |     CvMat(const CvMat& m) { memcpy(this, &m, sizeof(CvMat));}
/tmp/SBo/opencv-3.1.0/modules/core/include/opencv2/core/types_c.h:423:16: note: ‘struct CvMat’ declared here
  423 | typedef struct CvMat
/tmp/SBo/opencv-3.1.0/modules/core/include/opencv2/core/types_c.h: In constructor ‘CvMat::CvMat(const cv::Mat&)’:
/tmp/SBo/opencv-3.1.0/modules/core/include/opencv2/core/types_c.h:530:69: warning: implicitly-declared ‘constexpr CvMat& CvMat::operator=(const CvMat&)’ is deprecated [-Wdeprecated-copy]
  530 |     *this = cvMat(m.rows, m.dims == 1 ? 1 : m.cols, m.type(), m.data);
/tmp/SBo/opencv-3.1.0/modules/core/include/opencv2/core/types_c.h:461:5: note: because ‘CvMat’ has user-provided ‘CvMat::CvMat(const CvMat&)’
/tmp/SBo/opencv-3.1.0/modules/imgcodecs/src/grfmt_jpeg2000.cpp: In member function ‘bool cv::Jpeg2KDecoder::readComponent8u(uchar*, void*, int, int, int, int, int)’:
/tmp/SBo/opencv-3.1.0/modules/imgcodecs/src/grfmt_jpeg2000.cpp:308:71: error: lvalue required as unary ‘&’ operand
  308 |         jas_seqent_t* pix_row = &jas_matrix_get( buffer, y / ystep, 0 );
/tmp/SBo/opencv-3.1.0/modules/imgcodecs/src/grfmt_jpeg2000.cpp: In member function ‘bool cv::Jpeg2KDecoder::readComponent16u(short unsigned int*, void*, int, int, int, int, int)’:
/tmp/SBo/opencv-3.1.0/modules/imgcodecs/src/grfmt_jpeg2000.cpp:372:71: error: lvalue required as unary ‘&’ operand
  372 |         jas_seqent_t* pix_row = &jas_matrix_get( buffer, y / ystep, 0 );
make[2]: *** [modules/imgcodecs/CMakeFiles/opencv_imgcodecs.dir/build.make:186: modules/imgcodecs/CMakeFiles/opencv_imgcodecs.dir/src/grfmt_jpeg2000.cpp.o] Error 1
make[2]: uscita dalla directory "/tmp/SBo/opencv-3.1.0/build"
make[1]: *** [CMakeFiles/Makefile2:4070: modules/imgcodecs/CMakeFiles/opencv_imgcodecs.dir/all] Error 2
make[1]: uscita dalla directory "/tmp/SBo/opencv-3.1.0/build"
make: *** [Makefile:182: all] Error 2
Qualche idea??
PS. Mi sembra che quando avevo la stable gli slackbuilds non facevano una piega.. adesso con la current spesso spesso c'è sempre qualcosa che non va ; e a voi ?? :?
Kernel: 7.0.12
Re: Slackware current nuova di pacca e digikam
dafrasaga ha scritto: ↑
mer 18 nov 2020, 17:53
beh, si, le cose spesso si "rompono", ma e' normale se usi current, che e' la versione di sviluppo di Slackware: dovresti essere pronto ad affrontare autonomamente tutto quello che si "rompe" perche' se usi current si suppone che tu sia un utente esperto.
e' bene essere chiari: non c'e' nessuno che testi tutti gli script di SBo tutti i giorni che sono rilasciati nuovi aggiornamenti per current.
se qualcuno incontra un errore compilando qualcosa dal fork di SBo non ufficiale per current su un'installazione completa di current senza nessun pacchetto aggiuntivo c'e' un topic dedicato su linuxquestions dove questi errori mi vengono segnalati e io provo a trovare una soluzione: non sempre e' possibile, faccio quello che posso compatibilmente anche col tempo libero che ho.
nello specifico di digikam la versione su SBo e' fatta per essere usata con kde4 e per compilare sulla 14.2 ma per current ormai e' superata dalla nuova versione contenuta nel kde in /testing: se usi current e tieni particolarmente a digikam ti conviene passare al kde in /testing ed usare quella.
occhio pero' che io non ho ancora testato nulla col kde5 in /testing installato, quindi puo' darsi che molte cose del fork di SBo non ufficiale per current poi non ti compilino...
dafrasaga
Grazie per le info ;)
