kernel 5.10 e vecchio notebook che non parte
Ho aggiornato la current, ma con il 5.10.1 il notebook non parte, si ferma a un certo punto (metto foto fatta con il telefono che non sapevo come fare).
Provato sia huge sia generic. Ho letto questo https://www.linuxquestions.org/question ... 175687199/
ma non mi sembra simile al mio problema.
Conoscete qualche problema del nuovo kernel e/o avete idee e/o soluzioni?
Il mio notebook è un vecchio 6710s con queto lspci
00:00.0 Host bridge: Intel Corporation Mobile PM965/GM965/GL960 Memory Controller Hub (rev 0c)
00:02.0 VGA compatible controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (primary) (rev 0c)
00:02.1 Display controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (secondary) (rev 0c)
00:1a.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 03)
00:1a.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 03)
00:1c.2 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 3 (rev 03)
00:1c.4 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 5 (rev 03)
00:1d.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 03)
00:1d.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f3)
00:1f.0 ISA bridge: Intel Corporation 82801HM (ICH8M) LPC Interface Controller (rev 03)
00:1f.1 IDE interface: Intel Corporation 82801HM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation 82801HM/HEM (ICH8M/ICH8M-E) SATA Controller [AHCI mode] (rev 03)
02:04.0 CardBus bridge: Ricoh Co Ltd RL5c476 II (rev b6)
10:00.0 Network controller: Intel Corporation PRO/Wireless 3945ABG [Golan] Network Connection (rev 02)
18:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetLink BCM5906M Fast Ethernet PCI Express (rev 02)
p.s.
su un minipc più recente che uso come server e per fare pacchetti tutto ok.
Re: kernel 5.10 e vecchio notebook che non parte
Se può essere utile la configurazione di GRUB è questa
# If you change this file, run grub-mkconfig -o /boot/grub/grub.cfg
# afterwards to update /boot/grub/grub.cfg.
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT=true
#GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=false
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=$( sed 's/Slackware /Slackware-/' /etc/slackware-version )
GRUB_CMDLINE_LINUX_DEFAULT="video=SVIDEO-1:d ipv6.disable=1"
GRUB_CMDLINE_LINUX="vt.default_uf8=1 raid=noautodetect"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
#GRUB_GFXMODE=1024x768x32
# Font used on the graphical terminal:
#GRUB_FONT=/usr/share/grub/dejavusansmono.pf2
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entrys
GRUB_DISABLE_LINUX_RECOVERY="true"
GRUB_DISABLE_RECOVERY="true"
GRUB_DISABLE_SUBMENU="y"
GRUB_DISABLE_OS_PROBER="true"
Uhm....
Metti in blacklist il modulo i915, prova a far partire il kernel generic col suo ramdisk avviando in runlevel 3.
Prova anche a togliere momentaneamente il parametro 'video=SVIDEO-1:d'
No, niente. Si blocca al solito punto. anche senza passare alcun parametro. E con quelle opzioni nemmeno il 5.4 va. Parte ma poi naturalmente è senza supporto grafico.
Ma cosa fa: si ferma, o prosegue ma non vedi nulla a schermo?
Provato a passare i parametri di boot 'nomodeset i915.modeset=0' ?
Potrebbe anche essere un problema di config del kernel, tipo un driver essenziale compilato "erroneamente" come modulo e che quindi va inserito nell'initrd.
Un 'lspci -v' potrebbe aiutare a capire.
rik70 ha scritto: ↑
mar 22 dic 2020, 7:09
Si ferma, vedere vedo tutto. Si blocca a quella schermato che ho messo. Anche con il 5.4 si ferma nello stesso punto, ma tipo un secondo, poi riprende. Qui rimane fermo, ho anche provato a lasciarlo lì mentre sono andato in altra stanza a fare cose, ma non è nemmeno questione di qualche pausa. N
rik70 ha scritto: ↑
Provo, ma la sensazione è che sia prima del caricamento della grafica.
rik70 ha scritto: ↑
Ma con huge dovrebbe andare in teoria.
# lspci -v
        Subsystem: Hewlett-Packard Company Compaq 6710b
        Flags: bus master, fast devsel, latency 0
        Capabilities: [e0] Vendor Specific Information: Len=0a <?>
        Kernel modules: intel_agp
00:02.0 VGA compatible controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (primary) (rev 0c) (prog-if 00 [VGA controller])
        Flags: bus master, fast devsel, latency 0, IRQ 16
        Memory at e4300000 (64-bit, non-prefetchable) [size=1M]
        Memory at d0000000 (64-bit, prefetchable) [size=256M]
        I/O ports at 4000 [size=8]
        Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
        Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
        Capabilities: [d0] Power Management version 3
        Kernel driver in use: i915
        Kernel modules: i915
        Memory at e4400000 (64-bit, non-prefetchable) [size=1M]
00:1a.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 03) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 16
        I/O ports at 4020 [size=32]
        Kernel driver in use: uhci_hcd
        Kernel modules: uhci_hcd
00:1a.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 03) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 17
        I/O ports at 4040 [size=32]
00:1a.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 03) (prog-if 20 [EHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 18
        Memory at e4500000 (32-bit, non-prefetchable) [size=1K]
        Capabilities: [50] Power Management version 2
        Capabilities: [58] Debug port: BAR=1 offset=00a0
        Kernel driver in use: ehci-pci
        Kernel modules: ehci_pci
        Flags: bus master, fast devsel, latency 0, IRQ 29
        Memory at e4504000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
        Capabilities: [100] Virtual Channel
        Capabilities: [130] Root Complex Link
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 03) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 24
        Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
        I/O behind bridge: [disabled]
        Memory behind bridge: [disabled]
        Prefetchable memory behind bridge: [disabled]
        Capabilities: [40] Express Root Port (Slot-), MSI 00
        Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [90] Subsystem: Hewlett-Packard Company 82801H (ICH8 Family) PCI Express Port 1
        Capabilities: [a0] Power Management version 2
        Capabilities: [180] Root Complex Link
        Kernel driver in use: pcieport
00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 03) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 25
        Bus: primary=00, secondary=10, subordinate=10, sec-latency=0
        I/O behind bridge: 00005000-00005fff [size=4K]
        Memory behind bridge: e4100000-e41fffff [size=1M]
        Prefetchable memory behind bridge: 00000000c0000000-00000000c01fffff [size=2M]
        Capabilities: [40] Express Root Port (Slot+), MSI 00
        Capabilities: [90] Subsystem: Hewlett-Packard Company 82801H (ICH8 Family) PCI Express Port 2
00:1c.2 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 3 (rev 03) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 26
        Bus: primary=00, secondary=18, subordinate=18, sec-latency=0
        I/O behind bridge: 00006000-00006fff [size=4K]
        Memory behind bridge: e4000000-e40fffff [size=1M]
        Prefetchable memory behind bridge: 00000000c0200000-00000000c03fffff [size=2M]
        Capabilities: [90] Subsystem: Hewlett-Packard Company 82801H (ICH8 Family) PCI Express Port 3
00:1c.4 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 5 (rev 03) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 27
        Bus: primary=00, secondary=28, subordinate=28, sec-latency=0
        I/O behind bridge: 00002000-00003fff [size=8K]
        Memory behind bridge: e0000000-e3ffffff [size=64M]
        Prefetchable memory behind bridge: 00000000c0400000-00000000c05fffff [size=2M]
        Capabilities: [90] Subsystem: Hewlett-Packard Company 82801H (ICH8 Family) PCI Express Port 5
00:1d.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 03) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 20
        I/O ports at 4060 [size=32]
00:1d.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 03) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 21
        I/O ports at 4080 [size=32]
00:1d.2 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 03) (prog-if 00 [UHCI])
        I/O ports at 40a0 [size=32]
00:1d.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 03) (prog-if 20 [EHCI])
        Memory at e4508000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f3) (prog-if 01 [Subtractive decode])
        Bus: primary=00, secondary=02, subordinate=03, sec-latency=64
        I/O behind bridge: 00007000-00007fff [size=4K]
        Memory behind bridge: e4200000-e42fffff [size=1M]
        Capabilities: [50] Subsystem: Hewlett-Packard Company 82801 Mobile PCI Bridge
        Capabilities: [e0] Vendor Specific Information: Len=0c <?>
        Kernel driver in use: lpc_ich
        Kernel modules: lpc_ich
00:1f.1 IDE interface: Intel Corporation 82801HM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 03) (prog-if 8a [ISA Compatibility mode controller, supports both channels switched to PCI native mode, supports bus mastering])
        Memory at 000001f0 (32-bit, non-prefetchable) [virtual] [size=8]
        Memory at 000003f0 (type 3, non-prefetchable) [virtual]
        Memory at 00000170 (32-bit, non-prefetchable) [virtual] [size=8]
        Memory at 00000370 (type 3, non-prefetchable) [virtual]
        I/O ports at 40c0 [virtual] [size=16]
        Kernel driver in use: ata_piix
00:1f.2 SATA controller: Intel Corporation 82801HM/HEM (ICH8M/ICH8M-E) SATA Controller [AHCI mode] (rev 03) (prog-if 01 [AHCI 1.0])
        Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 28
        I/O ports at 13f0 [size=8]
        I/O ports at 15f4 [size=4]
        I/O ports at 1370 [size=8]
        I/O ports at 1574 [size=4]
        I/O ports at 4100 [size=32]
        Memory at e4509000 (32-bit, non-prefetchable) [size=2K]
        Capabilities: [80] MSI: Enable+ Count=1/4 Maskable- 64bit-
        Capabilities: [70] Power Management version 3
        Capabilities: [a8] SATA HBA v1.0
        Kernel driver in use: ahci
        Flags: bus master, medium devsel, latency 168, IRQ 16
        Memory at e4200000 (32-bit, non-prefetchable) [size=4K]
        Bus: primary=02, secondary=03, subordinate=03, sec-latency=176
        Memory window 0: c4000000-c7ffffff (prefetchable)
        Memory window 1: c8000000-cbffffff
        I/O window 0: 00007000-000070ff
        I/O window 1: 00007400-000074ff
        16-bit legacy interface ports at 0001
        Capabilities: [dc] Power Management version 2
        Kernel driver in use: yenta_cardbus
        Kernel modules: yenta_socket
        Subsystem: Hewlett-Packard Company PRO/Wireless 3945ABG [Golan] Network Connection
        Physical Slot: 2
        Flags: bus master, fast devsel, latency 0, IRQ 30
        Memory at e4100000 (32-bit, non-prefetchable) [size=4K]
        Capabilities: [c8] Power Management version 2
        Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [e0] Express Legacy Endpoint, MSI 00
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [140] Device Serial Number 00-1b-77-ff-ff-24-c8-ee
        Kernel driver in use: iwl3945
        Kernel modules: iwl3945
        Physical Slot: 3
        Flags: bus master, fast devsel, latency 0, IRQ 31
        Memory at e4000000 (64-bit, non-prefetchable) [size=64K]
        Expansion ROM at <ignored> [disabled]
        Capabilities: [48] Power Management version 3
        Capabilities: [50] Vital Product Data
        Capabilities: [58] Vendor Specific Information: Len=78 <?>
        Capabilities: [e8] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [d0] Express Endpoint, MSI 00
        Capabilities: [13c] Virtual Channel
        Capabilities: [160] Device Serial Number 00-17-a4-ff-fe-e4-0d-f4
        Kernel driver in use: tg3
        Kernel modules: tg3
Ho provato vari parametri ma niente. Leggo di problemi simili con gpu amd, ma si risolve disabilitando il modesetting, nel mio caso no. E non trovo bug report simili per intel.
Comunque ora con questo grub si blocca in altro modo
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_CMDLINE_LINUX_DEFAULT="video=SVIDEO-1:d ipv6.disable=1 intel_idle.max_cstate=1 i915.enable_dc=0"
Vedo che i problemi son vari con questo kernel
ma ognuno riguarda modeset, e a me non serve a nulla. Si blocca prima :/
Ma hai btrfs?
Che sia il tipo di filesystem il problema?
Nella prima schermata che hai messo si ferma dopo che sta configurando il disco ssd.
Quello che non mi spiego è il differente comportamento quando cambi i parametri del modulo i915. C'è qualcosa "di serio" che non va.
Poi: perché non parte quando dai 'nomodeset i915.modeset=0' ? Deve partire, con qualsiasi kernel. Ciò che vai a disattivare è il framebuffer e se non lanci il server grafico alla fine del boot devi arrivare.
Comunque sì, lasciare il longterm 5.4 non è stata una buona idea. E' dal ramo 5.8 che ci sono casini con la grafica intel. Io col 5.10 ho problemi di sospensione/ibernazione: ogni tanto blocco totale del sistema con led della tastiera tipo albero di Natale e riavvio automatico dopo tot secondi.
Questo l'errore catturato via netconsole da un raspberry:
[   75.923363] PM: hibernation: hibernation exit
[   83.638383] Kernel panic - not syncing: Timeout: Not all CPUs entered broadcast exception handler
[   83.638386] Kernel Offset: 0x20c00000 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff)
Ultima modifica di rik70 il gio 24 dic 2020, 11:21, modificato 1 volta in totale.
No, ho ext4.
Un ssd sata.
Comunque sembra qualcosa a livello controller, sì. Se non metto noacpi dopo jn paio di secondj ho messaggi acpi e poi fermo lì.
Non va nulla, quindi non so se è in segfault o semplicemente si ferma.
Ho messo anche il debug ma non vedo niente.
Non son nemmeno più che provare. Spero che il 5.4 duri molto come possibilità di avvio.
Il kernel di oggi (kernel-generic-5.10.2-x86_64-2) parte. Cosa sia cambiato non so. Nemmeno da dire che sia altro, se provo quello vecchio (kernel-generic-5.10.2-x86_64-1) non parte. Eppure Pat scrive di aver cambiato solo
HWMON m -> y
+NVME_HWMON y
+POWER_SUPPLY_HWMON y
+THERMAL_HWMON y
mi sembra strano.
Speriamo non siano capricci del mio hardwre che dopo "soli" 13 anni sta decidendo di abbandonarmi :)
rik70 ha scritto: ↑
In precedenza ha cambiato anche:
k/kernel-source-5.10.2-noarch-1.txz: Upgraded.
-USB_SISUSBVGA_CON y
PCIE_BW y -> n
Partiva la prima versione del kernel 5.10.2 che ha rilasciato? Se la risposta è sì, allora il problema era quella voce riguardante il bus pcie.
Altrimenti bhò..... :D
No, non parte. Ho provato anche questa mattina dopo aver provato la -2.
Tra l'altro questo pc il pcie non sa nemmeno cosa sia :)
conraid ha scritto: ↑
ven 25 dic 2020, 12:52
O sono io che non ne capisco niente, ma dal lspci che hai postato sopra mi sembra che qualche "linea" pcie il tuo sistema ce l'abbia.
Comunque, per la mia esperienza, con grafica intel il kernel 5.10 è un danno. E pieno di bug report che segnalano continui crash e blocchi di sistema.
Hai perfettamente ragione
Pardon. Quindi trovato il responsabile mi sa. E come mai non partiva con l'5.10.2-1 magari era per qualche casino con le varie prove che ho fatto provando mille opzioni :/
Per il resto facendo scongiuri per ora è ok.
