errori vari e warning in Plasma/X11
gian_d
Nome Cognome: Giancarlo Dessì
Slackware: 64 current
Kernel: 6.1.xx
Desktop: KDE 5.27
Messaggio da gian_d »
A causa di problemini vari saltati fuori, fra cui dei messaggi strani di kwin e una certa lentezza, ho cercato di individuare le possibili cause e sono saltati fuori una serie di incongruenze. Il log è lunghissimo, perciò mi limito a mettere i report più significativi.
Per chiarezza faccio presente che è installato il driver proprietario di Nvidia, l'ultima versione, e la sessione KDE è aperta con Plasma/X11 (quindi non wayland)
xauth:  file /home/gian/.serverauth.4311 does not exist
X.Org X Server 1.20.11
Build Operating System: Slackware 15.0 Slackware Linux Project
Current Operating System: Linux vava.it 5.10.41 #1 SMP Fri May 28 13:27:10 CDT 2021 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-generic root=/dev/sda5 ro
Build Date: 13 April 2021  12:31:51PM
Current version of pixman: 0.40.0
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning:          Could not resolve keysym XF86BrightnessAuto
> Warning:          Could not resolve keysym XF86DisplayOff
..... CUT .......
Errors from xkbcomp are not fatal to the X server
...... CUT ......
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
kdeinit5: opened connection to :0
kdeinit5: Got SETENV 'GTK_RC_FILES=/etc/gtk/gtkrc:/home/gian/.gtkrc:/home/gian/.config/gtkrc' from launcher.
kdeinit5: Got SETENV 'GTK2_RC_FILES=/etc/gtk-2.0/gtkrc:/home/gian/.gtkrc-2.0:/home/gian/.config/gtkrc-2.0' from launcher.
kdeinit5: Got SETENV 'XCURSOR_THEME=Oxygen_Yellow' from launcher.
kdeinit5: Got SETENV 'XCURSOR_SIZE=48' from launcher.
org.kde.plasma.session: process job  "kcminit_startup" finished with exit code  0
QObject::connect: No such signal QDBusAbstractInterface::StateChanged(uint)
..... CUT .....
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5089:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5091:48: this compose sequence is a duplicate of another; skipping line
.... CUT .....
Qt: Session management error: networkIdsList argument is NULL
.... CUT .....
QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.7'
org.kde.kmix: no mix devices and not dynamic
.... CUT (ripetitivo) .....
Delayed initialization.
.... CUT .....
org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
.... CUT .....
org.kde.powerdevil: The profile  "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
org.kde.powerdevil: Handle button events action could not check for screen configuration
percent 5 -> divisor 20
kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
.... CUT .....
org.kde.kmix: Cannot load profile "PulseAudio.Dispositivi_di_riproduzione.1.default"
org.kde.kmix: Cannot load profile "PulseAudio.Dispositivi_di_cattura.1.default"
org.kde.kmix: Cannot load profile "PulseAudio.Flussi_di_riproduzione.1.default"
org.kde.kmix: Cannot load profile "PulseAudio.Flussi_di_cattura.1.default"
kwin_core: XCB error: 10 (BadAccess), sequence: 881, resource id: 768, major code: 141 (Composite), minor code: 2 (RedirectSubwindows)
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 912, resource id: 29360134, major code: 18 (ChangeProperty), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 916, resource id: 29360135, major code: 18 (ChangeProperty), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 931, resource id: 50331652, major code: 18 (ChangeProperty), minor code: 0
kf.modemmanagerqt: Failed enumerating MM objects: "org.freedesktop.DBus.Error.Spawn.ChildExited"
 "Launch helper exited with unknown return code 127"
.... CUT ....
kdeinit5: Got EXEC_NEW '/usr/lib64/qt5/plugins/kf5/kio/desktop.so' from launcher.
kdeinit5: preparing to launch '/usr/lib64/qt5/plugins/kf5/kio/desktop.so'
Error: cannot change the containment to AppletsLayout
trying to show an empty dialog
.... CUT ....
kf.config.core: "KConfigIni: In file /usr/share/kservices5/searchproviders/rae.desktop, line 94: " "Invalid escape sequence \"\\{\"."
kf.coreaddons: Trying to attach UI delegate: KNotificationJobUiDelegate(0x3815210) to job KJob(0x37f2150) but this delegate is already attached to a different job KIO::OpenUrlJob(0x3f12c40)
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6312, resource id: 31457389, major code: 18 (ChangeProperty), minor code: 0
file:///usr/lib64/qt5/qml/org/kde/kwin/decoration/MenuButton.qml:11: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
file:///usr/share/kwin/decorations/kwin4_decoration_qml_plastik/contents/ui/main.qml:80: TypeError: Cannot read property 'borderSize' of null
.... CUT ....
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33838, resource id: 31457391, major code: 18 (ChangeProperty), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 35789, resource id: 77594632, major code: 18 (ChangeProperty), minor code: 0
... CUT  (molte righe simili alle precedenti) ....
Questo è quanto. Qualcuno ci capisce qualcosa?
