[RISOLTO] Xfce4 sensors plugin
guybrush.d
Nome Cognome: Diego
Kernel: 6.1.31
Desktop: Xfce 4.18
Messaggio da guybrush.d »
Buongiorno,
sto provando ad installare il pacchetto xfce4-sensors-plugin sulla current ma durante l'installazione ricevo questo messaggio :
cc1plus: warning: command-line option ‘-Wold-style-definition’ is valid for C/ObjC but not for C++
cc1plus: warning: command-line option ‘-Wdeclaration-after-statement’ is valid for C/ObjC but not for C++
cc1plus: warning: command-line option ‘-Wnested-externs’ is valid for C/ObjC but not for C++
In file included from ../../xfce4++/util/fixes.h:36,
                 from rc.cc:22:
/usr/include/xfce4/libxfce4util/libxfce4util-config.h:23:2: error: #error "Only <libxfce4util/libxfce4util.h> can be included directly, this file may disappear or change contents"
   23 | #error "Only <libxfce4util/libxfce4util.h> can be included directly, this file may disappear or change contents"
In file included from ../../xfce4++/util/fixes.h:38:
/usr/include/xfce4/libxfce4util/xfce-gio-extensions.h:21:2: error: #error "Only <libxfce4util/libxfce4util.h> can be included directly, this file may disappear or change contents"
   21 | #error "Only <libxfce4util/libxfce4util.h> can be included directly, this file may disappear or change contents"
In file included from ../../xfce4++/util/fixes.h:54:
/usr/include/xfce4/libxfce4util/xfce-i18n.h:24:2: error: #error "Only <libxfce4util/libxfce4util.h> can be included directly, this file may disappear or change contents"
   24 | #error "Only <libxfce4util/libxfce4util.h> can be included directly, this file may disappear or change contents"
make[2]: *** [Makefile:527: libxfce4util_pp_la-rc.lo] Error 1
make[2]: Leaving directory '/tmp/SBo/xfce4-sensors-plugin-1.4.3/xfce4++/util'
make[1]: *** [Makefile:501: all-recursive] Error 1
make[1]: Leaving directory '/tmp/SBo/xfce4-sensors-plugin-1.4.3'
make: *** [Makefile:431: all] Error 2
ho controllato il file libxfce4util/libxfce4util.h ed alla riga 22 corrisponde all'originale, ho cercato in vari forum senza successo.
Ho provato anche a convertire un rpm di Fedora ma non corrisponde la versione delle glib. Qualcuno sa come risolvere?
Vorrei usarlo per monitorare la temperatura, grazie
PS libsensors + già installato alla versione 5 ed xfce è il 4.18 ed ho anche provato ad installare il pacchetto scaricando direttamente lo slackbuild con i sorgenti da slackbuild.org
Ultima modifica di guybrush.d il sab 26 ago 2023, 13:06, modificato 1 volta in totale.
Kernel: 6.5.3
Re: Xfce4 sensors plugin
installa la versione 1.4.4 di xfce4-sensors-plugin, quella compila su current...
grazie della segnalazione, lo aggiorno nel repository non ufficiale per current.
guybrush.d
Nome Cognome: Diego
Kernel: 6.1.31
Desktop: Xfce 4.18
ponce ha scritto:
sab 26 ago 2023, 11:32
Grazie, modifico lo slackbuild e ci riprovo...
guybrush.d
Nome Cognome: Diego
Kernel: 6.1.31
Desktop: Xfce 4.18
Confermo il funzionamento,
ho modificato la versione del pacchetto nello slackbuild scaricato, ed ha compilato e creato il pacchetto senza problemi, direi che è risolto.
Grazie ancora.
guybrush.d
Nome Cognome: Diego
Kernel: 6.1.31
Desktop: Xfce 4.18
guybrush.d ha scritto:
sab 26 ago 2023, 13:05
Grazie ancora.
figurati grazie a te!
