Firefox -- ho capito perchè Pat ci ha rinunciato
DaNiMoTh
Messaggio da DaNiMoTh »
Vi allego lo slackbuild; il mozconfig invece ve lo posto qua:
<BR><!-- BBCode Quote Start --><TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE> # options to build Firefox
<BR>mk_add_options MOZ_CO_PROJECT=browser
<BR>mk_add_options MOZ_MAKE_FLAGS=-j3
<BR># Options for ´configure´ (same as command-line options).
<BR>export MOZ_PHOENIX=1
<BR>mk_add_options MOZ_PHOENIX=1
<BR>ac_add_options --enable-application=browser
<BR>ac_add_options --prefix=/usr
<BR>ac_add_options --disable-ldap
<BR>ac_add_options --disable-mailnews
<BR>ac_add_options --enable-extensions=cookie,xml-rpc,xmlextras,pref,transformiix,universalchardet,webservices,inspector,gnomevfs,negotiateauth
<BR>ac_add_options --enable-crypto
<BR>ac_add_options --disable-composer
<BR>ac_add_options --enable-single-profile
<BR>ac_add_options --disable-profilesharing
<BR>ac_add_options --disable-accessibility
<BR>ac_add_options --disable-debug
<BR>ac_add_options --disable-freetype2
<BR>ac_add_options --enable-installer
<BR>ac_add_options --disable-jsd
<BR>ac_add_options --disable-pedantic
<BR>ac_add_options --disable-shared
<BR>ac_add_options --disable-tests
<BR>ac_add_options --enable-default-toolkit=gtk2
<BR>ac_add_options --enable-plaintext-editor-only
<BR>ac_add_options --enable-static
<BR>ac_add_options --enable-xft
<BR>## processor optimization options
<BR>ac_add_options --enable-optimize="-march=athlon-xp -O2 -pipe -fomit-frame-pointer -ffast-math -mmmx -m3dnow -msse -mfpmath=sse"
<BR>## aggiunte:
<BR>ac_add_options --enable-strip
<BR>ac_add_options --enable-ui-locale=it-IT </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE><!-- BBCode Quote End -->
<BR>Ora, vorrei capire come mai non si salvano le impostazioni ( nemmeno da root, quindi permessi esclusi ), e come mai i binari che fornisce mozilla non abbiano problemi mentre i nostri sì. Che sia un´ opensource pacco?
<BR>Incomincio a stancarmi di questo firefox... sarà anche bello ma...
<BR>-->Io sono prima di tutto anti-imperialista, anti-dittatura, anti-totalitarismo, anti-liberista, cristiano, democratico, dalla parte dell´ultimo.
<BR><!-- BBCode Start --><IMG SRC="http://www.slackware.org/~msimons/slack ... Wchord.jpg"><!-- BBCode End -->
<BR><BR><BR>[ Questo Messaggio è stato Modificato da: DaNiMoTh il 08-05-2005 17:11 ]<br>
Trotto@81
Nome Cognome: Andrea
Kernel: default
Desktop: KDE 4.14.14
Messaggio da Trotto@81 »
Ma qual´è il problemi a cui ti riferisci??<br>
DaNiMoTh
Sono tanti.... e uno di questi è che non si possono salvare le impostazioni, e di default è disabilitato Java, Javascript, il blocco pop-up.....
<BR>Credevo che FIrefox fosse un buon progetto ma devo ricredermi... W KONQUEROR!<br>
