Italianizzare Xfce e Blackbox
dexter
- Slackware: 12.2
- Kernel: 2.6.33.1-smp
- Desktop: GnomeSlacky 2.26.3
Come faccio ad italianizzare xfce e blackbox? e come faccio ad impostare la tastiera italiana in entrambi ????
grazie
Dexter
grazie
Dexter
- gallows
- Desktop: cwm
- Distribuzione: OpenBSD
Intanto, se non l'hai ancora fatto, setta in /etc/profile.d/lang.sh
Per la tastiera in xorg.conf devi impostare:
export LANG=it_IT
export LC_ALL=it_IT
export CHARSET="iso8859-15"Codice: Seleziona tutto
Option "XkbLayout" "it"- gallows
- Desktop: cwm
Per la tastiera posta xorg.conf.dexter ha scritto:non è successo niente.... la tastiera non è in italiano, approposito perchè sulla pendrive i nomi dei file si vedono a 8 bit????
ciao
Per la pendrive posta:
$ cat /boot/config-`uname -r` | grep IOCHARSET-
dexter
- Slackware: 12.2
la pendrive è ok
questo è il mio xorg.conf:
# File generated by xf86config.
# Copyright (c) 1999 by The XFree86 Project, Inc.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE XFREE86 PROJECT BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
# WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
# OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
# Except as contained in this notice, the name of the XFree86 Project shall
# not be used in advertising or otherwise to promote the sale, use or other
# dealings in this Software without prior written authorization from the
# XFree86 Project.
# Refer to the XF86Config(4/5) man page for details about the format of
# this file.
# NOTE: This is a NEW IMPROVED version of XF86Config-fbdev that uses the vesa
# driver instead of the fbdev driver. Thanks to Kenneth Fanyo who pointed
# this out to me.
# This XF86Config file is designed for use with the VESA framebuffer.
# This generic interface should work with nearly all video cards
# (although not every card will support every resolution).
# With the new driver, it should no longer be required to have frame buffer
# support in the kernel, or to run it on the console.
# Enjoy!
# -- volkerdi@slackware.com
# Module section -- this section is used to specify
# which dynamically loadable modules to load.
Section "Module"
# This loads the DBE extension module.
Load "dbe" # Double buffer extension
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
SubSection "extmod"
Option "omit xfree86-dga" # don't initialise the DGA extension
EndSubSection
# This loads the font modules
Load "type1"
Load "freetype"
#Load "speedo"
# This loads the GLX module
Load "glx"
EndSection
# Files section. This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
RgbPath "/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (which are concatenated together),
# as well as specifying multiple comma-separated entries in one FontPath
# command (or a combination of both methods)
# If you don't have a floating point coprocessor and emacs, Mosaic or other
# programs take long to start up, try moving the Type1 and Speedo directory
# to the end of this list (or comment them out).
FontPath "/usr/X11R6/lib/X11/fonts/local/"
FontPath "/usr/X11R6/lib/X11/fonts/misc/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
FontPath "/usr/X11R6/lib/X11/fonts/CID/"
FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic/"
# ModulePath can be used to set a search path for the X server modules.
# The default path is shown here.
# ModulePath "/usr/X11R6/lib/modules"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received. This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
# Option "NoTrapSignals"
# Uncomment this to disable the <Crtl><Alt><Fn> VT switch sequence
# (where n is 1 through 12). This allows clients to receive these key
# events.
# Option "DontVTSwitch"
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
# Option "DontZap"
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences. This allows clients to receive these key events.
# Option "DontZoom"
# Uncomment this to disable tuning with the xvidtune client. With
# it the client can still run and fetch card and monitor attributes,
# but it will not be allowed to change them. If it tries it will
# receive a protocol error.
# Option "DisableVidModeExtension"
# Uncomment this to enable the use of a non-local xvidtune client.
# Option "AllowNonLocalXvidtune"
# Uncomment this to disable dynamically modifying the input device
# (mouse and keyboard) settings.
# Option "DisableModInDev"
# Uncomment this to enable the use of a non-local client to
# change the keyboard or mouse settings (currently only xset).
# Option "AllowNonLocalModInDev"
# Set the basic blanking screen saver timeout.
# Option "blank time" "10" # 10 minutes
# Set the DPMS timeouts. These are set here because they are global
# rather than screen-specific. These settings alone don't enable DPMS.
# It is enabled per-screen (or per-monitor), and even then only when
# the driver supports it.
# Option "standby time" "20"
# Option "suspend time" "30"
# Option "off time" "60"
# On some platform the server needs to estimate the sizes of PCI
# memory and pio ranges. This is done by assuming that PCI ranges
# don't overlap. Some broken BIOSes tend to set ranges of inactive
# devices wrong. Here one can adjust how aggressive the assumptions
# should be. Default is 0.
# Option "EstimateSizesAggresively" "0"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
Identifier "Keyboard1"
Driver "kbd"
# For most OSs the protocol can be omitted (it defaults to "Standard").
# When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
# uncomment the following line.
# Option "Protocol" "Xqueue"
# Set the keyboard auto repeat parameters. Not all platforms implement
# this.
# Option "AutoRepeat" "500 5"
# Specifiy which keyboard LEDs can be user-controlled (eg, with xset(1)).
# Option "Xleds" "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
# Option "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a European
# keyboard, you will probably want to use one of:
# Option "XkbModel" "pc102"
# Option "XkbModel" "pc105"
# If you have a Microsoft Natural keyboard, you can use:
# Option "XkbModel" "microsoft"
# If you have a US "windows" keyboard you will want:
# Option "XkbModel" "pc104"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# Option "XkbLayout" "it"
# or:
# Option "XkbLayout" "de"
# Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# Option "XkbOptions" "ctrl:swapcaps"
# These are the default XKB settings for X.Org
# Option "XkbRules" "xorg"
# Option "XkbModel" "pc101"
# Option "XkbLayout" "us"
# Option "XkbVariant" ""
# Option "XkbOptions" ""
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
Identifier "Mouse1"
Driver "mouse"
# On platforms where PnP mouse detection is supported the following
# protocol setting can be used when using a newer PnP mouse:
# Option "Protocol" "Auto"
# The available mouse protocols types that you can set below are:
# Auto BusMouse GlidePoint GlidePointPS/2 IntelliMouse IMPS/2
# Logitech Microsoft MMHitTab MMSeries Mouseman MouseManPlusPS/2
# MouseSystems NetMousePS/2 NetScrollPS/2 OSMouse PS/2 SysMouse
# ThinkingMouse ThinkingMousePS/2 Xqueue
Option "Protocol" "PS/2"
# The mouse device. The device is normally set to /dev/mouse,
# which is usually a symbolic link to the real device.
Option "Device" "/dev/mouse"
# Option "Device" "/dev/psaux"
# Option "Device" "/dev/ttyS0"
# Option "Device" "/dev/ttyS1"
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
# Option "BaudRate" "9600"
# Option "SampleRate" "150"
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
# Option "Emulate3Buttons"
# Option "Emulate3Timeout" "50"
# ChordMiddle is an option for some 3-button Logitech mice
# Option "ChordMiddle"
EndSection
# Some examples of extended input devices
# Section "InputDevice"
# Identifier "spaceball"
# Driver "magellan"
# Option "Device" "/dev/cua0"
# EndSection
# Identifier "spaceball2"
# Driver "spaceorb"
# EndSection
# Identifier "touchscreen0"
# Driver "microtouch"
# Option "MinX" "1412"
# Option "MaxX" "15184"
# Option "MinY" "15372"
# Option "MaxY" "1230"
# Option "ScreenNumber" "0"
# Option "ReportingMode" "Scaled"
# Option "ButtonNumber" "1"
# Option "SendCoreEvents"
# EndSection
# Identifier "touchscreen1"
# Driver "elo2300"
# Option "MinX" "231"
# Option "MaxX" "3868"
# Option "MinY" "3858"
# Option "MaxY" "272"
# Option "ButtonThreshold" "17"
# EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
Identifier "My Monitor"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY. REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
HorizSync 31.5 - 50.0
# HorizSync 30-64 # multisync
# HorizSync 31.5, 35.2 # multiple fixed sync frequencies
# HorizSync 15-25, 30-50 # multiple ranges of sync frequencies
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
VertRefresh 40-90
EndSection
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
Identifier "VESA Framebuffer"
Driver "sis"
#VideoRam 4096
# Insert Clocks lines here if appropriate
EndSection
# Screen sections
# Any number of screen sections may be present. Each describes
# the configuration of a single screen. A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
Identifier "Screen 1"
Device "VESA Framebuffer"
Monitor "My Monitor"
# If your card can handle it, a higher default color depth (like 24 or 32)
# is highly recommended.
# DefaultDepth 8
# DefaultDepth 16
DefaultDepth 24
# DefaultDepth 32
# "1024x768" is also a conservative usable default resolution. If you
# have a better monitor, feel free to try resolutions such as
# "1152x864", "1280x1024", "1600x1200", and "1800x1400" (or whatever your
# card/monitor can produce)
Subsection "Display"
Depth 8
Modes "1024x768" "800x600" "640x480"
EndSubsection
Depth 16
EndSubsection
Depth 24
EndSubsection
Depth 32
EndSubsection
EndSection
# ServerLayout sections.
# Any number of ServerLayout sections may be present. Each describes
# the way multiple screens are organised. A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option. In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
Section "ServerLayout"
# The Identifier line must be present
Identifier "Simple Layout"
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens. The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen. In this example, screen 2 is located to the
# right of screen 1.
Screen "Screen 1"
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used. Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
InputDevice "Mouse1" "CorePointer"
InputDevice "Keyboard1" "CoreKeyboard"
EndSection
Section "DRI"
mode 0666
EndSection
Dexter
# SOFTWARE.
# XFree86 Project.
# this file.
# this out to me.
# Enjoy!
Section "Module"
SubSection "extmod"
EndSubSection
Load "type1"
Load "freetype"
#Load "speedo"
Load "glx"
EndSection
Section "Files"
EndSection
# events.
# Option "DontZap"
# Option "DontZoom"
EndSection
# Input devices
Driver "kbd"
# this.
# or:
EndSection
Identifier "Mouse1"
Driver "mouse"
EndSection
# Driver "magellan"
# EndSection
# Driver "spaceorb"
# EndSection
# EndSection
# Driver "elo2300"
# EndSection
# Monitor section
Section "Monitor"
VertRefresh 40-90
EndSection
Section "Device"
Driver "sis"
#VideoRam 4096
EndSection
# Screen sections
# option.
Section "Screen"
# DefaultDepth 8
# DefaultDepth 16
DefaultDepth 24
# DefaultDepth 32
Depth 8
EndSubsection
Depth 16
EndSubsection
Depth 24
EndSubsection
Depth 32
EndSubsection
EndSection
# is used alone.
Screen "Screen 1"
# "SendCoreEvents".
EndSection
Section "DRI"
mode 0666
EndSection
Dexter
