Ricordo che con la slack 10.0 ho avuto lo stesso problema(i divx si vedono a scatti in fullscreen), e dando il comando di configuazione di Xorg si era sistemato tutto.
Ho prvato amche con la 10.2, ma ho avuto problemi con non so cosa..
Dopo aver messo tutto come nella 10.0(stesso file di configurazinoe copiato nella mia home) non mi si visualizzava + X, solo testuale..
Ho pensato a frequenze, ma mettendo le STESSE frequenze di xorg.conf-vesa(che copiato in xorg.conf funziona), ma non cambia nulla, sempre schermo nero...
Cosa potrebbe causarmi questo problema?
Xorgconfig e DivX
homer84
- Slackware: Current
1c1
< # File generated by xorgconfig.
> # File generated by xf86config.
4c4
< # Copyright 2004 The X.Org Foundation
> # Copyright (c) 1999 by The XFree86 Project, Inc.
19c19
< # The X.Org Foundation BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
> # THE XFREE86 PROJECT BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
24c24
< # Except as contained in this notice, the name of The X.Org Foundation shall
> # Except as contained in this notice, the name of the XFree86 Project shall
26,27c26,27
< # dealings in this Software without prior written authorization from
< # The X.Org Foundation.
> # dealings in this Software without prior written authorization from the
> # XFree86 Project.
31c31
< # Refer to the xorg.conf(5x) man page for details about the format of
> # Refer to the XF86Config(4/5) man page for details about the format of
34a35,49
> # NOTE: This is a NEW IMPROVED version of XF86Config-fbdev that uses the vesa
> # driver instead of the fbdev driver. Thanks to Kenneth Fanyo who pointed
> # this out to me.
> # This XF86Config file is designed for use with the VESA framebuffer.
> # This generic interface should work with nearly all video cards
> # (although not every card will support every resolution).
> # With the new driver, it should no longer be required to have frame buffer
> # support in the kernel, or to run it on the console.
> # Enjoy!
> # -- volkerdi@slackware.com
54d68
< # Load "speedo"
56c70
< # Load "xtt"
> #Load "speedo"
60,61d73
< # This loads the DRI module
< # Load "dri"
80a93,95
> # If you don't have a floating point coprocessor and emacs, Mosaic or other
> # programs take long to start up, try moving the Type1 and Speedo directory
> # to the end of this list (or comment them out).
82a98
> FontPath "/usr/X11R6/lib/X11/fonts/local/"
84c100,101
< FontPath "/usr/X11R6/lib/X11/fonts/TTF/"
> FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
> FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
86a104
> FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
89,90d106
< FontPath "/usr/X11R6/lib/X11/fonts/local/"
< FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
93c109,110
< # The module search path. The default path is shown here.
> # ModulePath can be used to set a search path for the X server modules.
> # The default path is shown here.
105c122
< # Uncomment this to cause a core dump at the spot where a signal is
109c126
< # Option "NoTrapSignals"
115c132
< # Option "DontVTSwitch"
120c137
< # Option "DontZap"
> # Option "DontZap"
125c142
< # Option "Dont Zoom"
> # Option "DontZoom"
132c149
< # Option "DisableVidModeExtension"
134c151
< # Uncomment this to enable the use of a non-local xvidtune client.
136c153
< # Option "AllowNonLocalXvidtune"
139c156
< # (mouse and keyboard) settings.
141c158
< # Option "DisableModInDev"
146c163,184
< # Option "AllowNonLocalModInDev"
> # Set the basic blanking screen saver timeout.
> # Option "blank time" "10" # 10 minutes
> # Set the DPMS timeouts. These are set here because they are global
> # rather than screen-specific. These settings alone don't enable DPMS.
> # It is enabled per-screen (or per-monitor), and even then only when
> # the driver supports it.
> # Option "standby time" "20"
> # Option "suspend time" "30"
> # Option "off time" "60"
> # On some platform the server needs to estimate the sizes of PCI
> # memory and pio ranges. This is done by assuming that PCI ranges
> # don't overlap. Some broken BIOSes tend to set ranges of inactive
> # devices wrong. Here one can adjust how aggressive the assumptions
> # should be. Default is 0.
> # Option "EstimateSizesAggresively" "0"
162d199
169c206,207
< Option "AutoRepeat" "500 30"
> # Set the keyboard auto repeat parameters. Not all platforms implement
> # this.
171,172c209
< # Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
< # Option "Xleds" "1 2 3"
> # Option "AutoRepeat" "500 5"
174,175c211,217
< # Option "LeftAlt" "Meta"
< # Option "RightAlt" "ModeShift"
> # Specifiy which keyboard LEDs can be user-controlled (eg, with xset(1)).
> # To disable the XKEYBOARD extension, uncomment XkbDisable.
> # Option "XkbDisable"
178,182c220,232
< # lines below (which are the defaults). For example, for a non-U.S.
< # keyboard, you will probably want to use:
< # Option "XkbModel" "pc105"
< # If you have a US Microsoft Natural keyboard, you can use:
< # Option "XkbModel" "microsoft"
> # lines below (which are the defaults). For example, for a European
> # keyboard, you will probably want to use one of:
> # Option "XkbModel" "pc102"
> # If you have a Microsoft Natural keyboard, you can use:
> # If you have a US "windows" keyboard you will want:
> # Option "XkbModel" "pc104"
186c236,238
< # Option "XkbLayout" "de"
188,189c240,242
< # Option "XkbVariant" "nodeadkeys"
193c246,247
< # Option "XkbOptions" "ctrl:swapcaps"
195,206c249,256
< # These are the default XKB settings for Xorg
< # Option "XkbRules" "xorg"
< # Option "XkbLayout" "us"
< # Option "XkbVariant" ""
< # Option "XkbOptions" ""
< # Option "XkbDisable"
< Option "XkbRules" "xorg"
< Option "XkbModel" "pc101"
< Option "XkbLayout" "us"
> # These are the default XKB settings for X.Org
> # Option "XkbModel" "pc101"
220a271,281
> # On platforms where PnP mouse detection is supported the following
> # protocol setting can be used when using a newer PnP mouse:
> # Option "Protocol" "Auto"
> # The available mouse protocols types that you can set below are:
> # Auto BusMouse GlidePoint GlidePointPS/2 IntelliMouse IMPS/2
> # Logitech Microsoft MMHitTab MMSeries Mouseman MouseManPlusPS/2
> # MouseSystems NetMousePS/2 NetScrollPS/2 OSMouse PS/2 SysMouse
> # ThinkingMouse ThinkingMousePS/2 Xqueue
222d282
< Option "Device" "/dev/mouse"
224c284,285
< # Mouse-speed setting for PS/2 mouse.
> # The mouse device. The device is normally set to /dev/mouse,
> # which is usually a symbolic link to the real device.
226c287,290
< # Option "Resolution" "256"
> # Option "Device" "/dev/psaux"
> # Option "Device" "/dev/ttyS0"
> # Option "Device" "/dev/ttyS1"
236c300
< # Option "BaudRate" "9600"
242c306
< Option "Emulate3Buttons"
> # Option "Emulate3Buttons"
250a315
> # Some examples of extended input devices
252,265d316
< # Other input device sections
< # this is optional and is required only if you
< # are using extended input devices. This is for example only. Refer
< # to the xorg.conf man page for a description of the options.
< # Section "InputDevice"
< # Identifier "Mouse2"
< # Driver "mouse"
< # Option "Protocol" "MouseMan"
< # Option "Device" "/dev/mouse2"
< # EndSection
315c366
< Identifier "MyMonitor"
> Identifier "My Monitor"
346,380d396
< # Standard VGA Device:
< Section "Device"
< Identifier "Standard VGA"
< VendorName "Unknown"
< BoardName "Unknown"
< # The chipset line is optional in most cases. It can be used to override
< # the driver's chipset detection, and should not normally be specified.
< # Chipset "generic"
< # The Driver line must be present. When using run-time loadable driver
< # modules, this line instructs the server to load the specified driver
< # module. Even when not using loadable driver modules, this line
< # indicates which driver should interpret the information in this section.
< Driver "vga"
< # The BusID line is used to specify which of possibly multiple devices
< # this section is intended for. When this line isn't present, a device
< # section can only match up with the primary video device. For PCI
< # devices a line like the following could be used. This line should not
< # normally be included unless there is more than one video device
< # intalled.
< # BusID "PCI:0:10:0"
< # VideoRam 256
< # Clocks 25.2 28.3
< EndSection
< # Device configured by xorgconfig:
382,384c398,400
< Identifier "MyIntelCard"
< Driver "i740"
< #VideoRam 65536
> Identifier "VESA Framebuffer"
> Driver "vesa"
> #VideoRam 4096
388d403
399,401c414,428
< Device "MyIntelCard"
< Monitor "MyMonitor"
< DefaultDepth 24
> Device "VESA Framebuffer"
> Monitor "My Monitor"
> # If your card can handle it, a higher default color depth (like 24 or 32)
> # is highly recommended.
> # DefaultDepth 8
> # DefaultDepth 16
> DefaultDepth 24
> # DefaultDepth 32
> # "1024x768" is also a conservative usable default resolution. If you
> # have a better monitor, feel free to try resolutions such as
> # "1152x864", "1280x1024", "1600x1200", and "1800x1400" (or whatever your
> # card/monitor can produce)
405,406c432
< Modes "1280x1024" "1024x768" "800x600" "640x480"
< ViewPort 0 0
> Modes "1024x768" "800x600" "640x480"
410,411c436
< ViewPort 0 0
415,416c440,444
< ViewPort 0 0
> EndSubsection
> Subsection "Display"
> Depth 32
417a446
454,457d482
< # Section "DRI"
< # Mode 0666
< # EndSection
4c4
19c19
24c24
26,27c26,27
> # XFree86 Project.
31c31
34a35,49
> # this out to me.
> # Enjoy!
54d68
< # Load "speedo"
56c70
< # Load "xtt"
> #Load "speedo"
60,61d73
< # Load "dri"
80a93,95
82a98
84c100,101
86a104
89,90d106
93c109,110
105c122
109c126
115c132
120c137
> # Option "DontZap"
125c142
> # Option "DontZoom"
132c149
134c151
136c153
139c156
141c158
146c163,184
162d199
169c206,207
> # this.
171,172c209
174,175c211,217
178,182c220,232
186c236,238
188,189c240,242
193c246,247
195,206c249,256
220a271,281
222d282
224c284,285
226c287,290
236c300
242c306
250a315
252,265d316
< # Driver "mouse"
< # EndSection
315c366
346,380d396
< Section "Device"
< Driver "vga"
< # intalled.
< # VideoRam 256
< EndSection
382,384c398,400
< Driver "i740"
< #VideoRam 65536
> Driver "vesa"
> #VideoRam 4096
388d403
399,401c414,428
< DefaultDepth 24
> # DefaultDepth 8
> # DefaultDepth 16
> DefaultDepth 24
> # DefaultDepth 32
405,406c432
< ViewPort 0 0
410,411c436
< ViewPort 0 0
415,416c440,444
< ViewPort 0 0
> EndSubsection
> Depth 32
417a446
454,457d482
< # Section "DRI"
< # Mode 0666
< # EndSection
