Failed to load glx
Failed to load glx
Ciao a tutti,
ho uno strano problema che mi assilla.
Da quando ho aggiornato xorg con i nuovi security advisories, ricevo un problema all'avvio del server X. Questo mi dice: Failed to load glx. Così sono costretto a non caricare le glx per usare kde. Cosa può essere?
Xorg.0.log L'altra è una directory....
X Window System Version 6.8.2
Release Date: 9 February 2005
X Protocol Version 11, Revision 0, Release 6.8.2
Build Operating System: Linux 2.4.31 i686 [ELF]
Current Operating System: Linux bart 2.6.13.3-valnir #1 Wed Oct 5 17:10:16 CEST 2005 i686
Build Date: 25 September 2005
Before reporting problems, check http://wiki.X.Org
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Oct 5 19:25:30 2005
(==) ServerLayout "Simple Layout"
(**) |-->Screen "Screen 1" (0)
(**) | |-->Monitor "monitor"
(**) | |-->Device "Nvidia GeForce"
(**) |-->Input Device "USB-Mouse"
(**) |-->Input Device "Keyboard1"
(==) |-->Input Device "USB-Mouse"
(WW) The core pointer device wasn't specified explicitly in the layout.
Using the first mouse device.
(WW) `fonts.dir' not found (or not valid) in "/usr/lib/X11/fonts/Speedo".
Entry deleted from font path.
(Run 'mkfontdir' on "/usr/lib/X11/fonts/Speedo").
(**) FontPath set to "unix/:7100,/usr/lib/X11/fonts/misc,/usr/lib/X11/fonts/100dpi/:unscaled,
/usr/lib/X11/fonts/75dpi/:unscaled,/usr/lib/X11/fonts/Type1,/usr/lib/X11/fonts/100dpi,/usr/li
b/X11/fonts/75dpi"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(WW) Open APM failed (/dev/apm_bios) (No such device)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.7
X.Org XInput driver : 0.4
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 6.8.2, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 0.7
(--) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,2590 card 104d,81b7 rev 03 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2591 card 0000,0000 rev 03 class 06,04,00 hdr 01
(II) PCI: 00:1b:0: chip 8086,2668 card 104d,81bb rev 03 class 04,03,00 hdr 00
(II) PCI: 00:1d:0: chip 8086,2658 card 104d,81b9 rev 03 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,2659 card 104d,81b9 rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,265a card 104d,81b9 rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,265b card 104d,81b9 rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,265c card 104d,81b9 rev 03 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,2448 card 0000,0000 rev d3 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,2641 card 104d,81b9 rev 03 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,266f card 104d,81b9 rev 03 class 01,01,8a hdr 00
(II) PCI: 00:1f:3: chip 8086,266a card 104d,81b9 rev 03 class 0c,05,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0167 card 104d,81c2 rev a1 class 03,00,00 hdr 00
(II) PCI: 06:03:0: chip 104c,ac8e card 3000,0000 rev 00 class 06,07,00 hdr 82
(II) PCI: 06:03:2: chip 104c,802e card 104d,818f rev 00 class 0c,00,10 hdr 80
(II) PCI: 06:03:3: chip 104c,ac8f card 104d,8190 rev 00 class 01,80,00 hdr 80
(II) PCI: 06:04:0: chip 8086,4220 card 8086,2753 rev 05 class 02,80,00 hdr 00
(II) PCI: 06:08:0: chip 8086,1068 card 104d,81d0 rev 03 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,7), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0x90000000 - 0xafffffff (0x20000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 6: bridge is at (0:30:0), (0,6,10), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 6 I/O range:
[0] -1 0 0x00002000 - 0x000020ff (0x100) IX[B]
[1] -1 0 0x00002400 - 0x000024ff (0x100) IX[B]
[2] -1 0 0x00002800 - 0x000028ff (0x100) IX[B]
[3] -1 0 0x00002c00 - 0x00002cff (0x100) IX[B]
(II) Bus 6 non-prefetchable memory range:
[0] -1 0 0xb0000000 - 0xb00fffff (0x100000) MX[B]
(II) Bus 6 prefetchable memory range:
[0] -1 0 0x20000000 - 0x21ffffff (0x2000000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) PCI-to-CardBus bridge:
(II) Bus 7: bridge is at (6:3:0), (6,7,10), BCTRL: 0x05c0 (VGA_EN is cleared)
(II) Bus 7 prefetchable memory range:
(--) PCI:*(1:0:0) nVidia Corporation unknown chipset (0x0167) rev 161, Mem @ 0xa0000000/24, 0
xc0000000/28, 0x90000000/24
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xb0007000 - 0xb0007fff (0x1000) MX[B]
[1] -1 0 0xb0006000 - 0xb0006fff (0x1000) MX[B]
[2] -1 0 0xb0005000 - 0xb0005fff (0x1000) MX[B]
[3] -1 0 0xb0000000 - 0xb0003fff (0x4000) MX[B]
[4] -1 0 0xb0004000 - 0xb00047ff (0x800) MX[B]
[5] -1 0 0x80004000 - 0x800043ff (0x400) MX[B]
[6] -1 0 0x80000000 - 0x80003fff (0x4000) MX[B]
[7] -1 0 0x90000000 - 0x90ffffff (0x1000000) MX[B](B)
[8] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
[9] -1 0 0xa0000000 - 0xa0ffffff (0x1000000) MX[B](B)
[10] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[11] -1 0 0x000018a0 - 0x000018bf (0x20) IX[B]
[12] -1 0 0x00001880 - 0x0000188f (0x10) IX[B]
[13] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[14] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[15] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[16] -1 0 0x00001800 - 0x0000181f (0x20) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xb0007000 - 0xb0007fff (0x1000) MX[B]
[6] -1 0 0xb0006000 - 0xb0006fff (0x1000) MX[B]
[7] -1 0 0xb0005000 - 0xb0005fff (0x1000) MX[B]
[8] -1 0 0xb0000000 - 0xb0003fff (0x4000) MX[B]
[9] -1 0 0xb0004000 - 0xb00047ff (0x800) MX[B]
[10] -1 0 0x80004000 - 0x800043ff (0x400) MX[B]
[11] -1 0 0x80000000 - 0x80003fff (0x4000) MX[B]
[12] -1 0 0x90000000 - 0x90ffffff (0x1000000) MX[B](B)
[13] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
[14] -1 0 0xa0000000 - 0xa0ffffff (0x1000000) MX[B](B)
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[18] -1 0 0x000018a0 - 0x000018bf (0x20) IX[B]
[19] -1 0 0x00001880 - 0x0000188f (0x10) IX[B]
[20] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[21] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[22] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[23] -1 0 0x00001800 - 0x0000181f (0x20) IX[B]
(II) Reloading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
ABI class: X.Org Server Extension, version 0.2
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension XC-MISC
(II) Loading extension XFree86-Misc
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "dri"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="X.Org Foundation"
(II) Reloading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Loading extension XFree86-DGA
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 6.8.2, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: "record"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="X.Org Foundation"
compiled for 6.8.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="X.Org Foundation"
compiled for 6.8.2, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "vbe"
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="X.Org Foundation"
compiled for 6.8.2, module version = 1.1.0
(II) LoadModule: "nvidia"
(II) Loading /usr/X11R6/lib/modules/drivers/nvidia_drv.o
(II) Module nvidia: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.7676
Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.4
(II) LoadModule: "kbd"
(II) Loading /usr/X11R6/lib/modules/input/kbd_drv.o
(II) Module kbd: vendor="X.Org Foundation"
(II) NVIDIA X Driver 1.0-7676 Fri Jul 29 13:01:02 PDT 2005
(II) NVIDIA Unified Driver for all NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset NVIDIA GPU found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[15] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[16] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[17] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[20] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[21] -1 0 0x000018a0 - 0x000018bf (0x20) IX[B]
[22] -1 0 0x00001880 - 0x0000188f (0x10) IX[B]
[23] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[24] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[25] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[26] -1 0 0x00001800 - 0x0000181f (0x20) IX[B]
[27] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[28] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Option "NoLogo" "on"
(**) NVIDIA(0): Option "SWcursor" "1"
(**) NVIDIA(0): Option "HWcursor" "0"
(**) NVIDIA(0): Option "NvAGP" "3"
(**) NVIDIA(0): Option "IgnoreEDID" "true"
(**) NVIDIA(0): Ignoring EDIDs
(--) NVIDIA(0): Linear framebuffer at 0xC0000000
(--) NVIDIA(0): MMIO registers at 0xA0000000
(II) NVIDIA(0): NVIDIA GPU detected as: GeForce Go 6200
(--) NVIDIA(0): VideoBIOS: 05.44.02.23.22
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(II) NVIDIA(0): Detected PCI Express Link width: 16X
(--) NVIDIA(0): VideoRAM: 65536 kBytes
(II) NVIDIA(0): Connected display device(s): DFP-0
(--) NVIDIA(0): DFP-0: maximum pixel clock: 284 MHz
(--) NVIDIA(0): DFP-0: Internal Single Link TMDS
(II) NVIDIA(0): Not probing EDIDs.
(II) NVIDIA(0): monitor: Using hsync range of 30.00-64.00 kHz
(II) NVIDIA(0): monitor: Using vrefresh range of 50.00-100.00 Hz
(II) NVIDIA(0): Clock range: 12.00 to 284.00 MHz
(II) NVIDIA(0): Not using default mode "1024x768" (hsync out of range)
(II) NVIDIA(0): Not using default mode "512x384" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1152x864" (hsync out of range)
(II) NVIDIA(0): Not using default mode "576x432" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1280x960" (hsync out of range)
(II) NVIDIA(0): Not using default mode "640x480" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1280x1024" (hsync out of range)
(II) NVIDIA(0): Not using default mode "640x512" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1600x1200" (hsync out of range)
(II) NVIDIA(0): Not using default mode "800x600" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1792x1344" (hsync out of range)
(II) NVIDIA(0): Not using default mode "896x672" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1856x1392" (hsync out of range)
(II) NVIDIA(0): Not using default mode "928x696" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1856x1392" (bad mode clock/interlace/doublescan)
(II) NVIDIA(0): Not using default mode "1920x1440" (hsync out of range)
(II) NVIDIA(0): Not using default mode "960x720" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1920x1440" (bad mode clock/interlace/doublescan)
(II) NVIDIA(0): Not using default mode "1400x1050" (hsync out of range)
(II) NVIDIA(0): Not using default mode "700x525" (hsync out of range)
(II) NVIDIA(0): Not using default mode "2048x1536" (hsync out of range)
(II) NVIDIA(0): Not using default mode "2048x1536" (bad mode clock/interlace/doublescan)
(II) NVIDIA(0): Not using default mode "1280x1024" (height too large for virtual size)
(II) NVIDIA(0): Not using default mode "1280x960" (height too large for virtual size)
(WW) NVIDIA(0): Not using mode "1152x768":
(WW) NVIDIA(0): horizontal sync start (1178) not a multiple of 8
(WW) NVIDIA(0): Not using mode "576x384":
(WW) NVIDIA(0): horizontal sync start (589) not a multiple of 8
(WW) NVIDIA(0): Not using mode "360x200":
(WW) NVIDIA(0): horizontal sync start (378) not a multiple of 8
(**) NVIDIA(0): Validated modes for display device DFP-0:
(**) NVIDIA(0): Mode "1280x800": 107.2 MHz, 62.6 kHz, 75.0 Hz
(**) NVIDIA(0): Default mode "1024x768": 78.8 MHz, 60.1 kHz, 75.1 Hz
(**) NVIDIA(0): Default mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(**) NVIDIA(0): Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(**) NVIDIA(0): Default mode "1024x768": 44.9 MHz, 35.5 kHz, 87.0 Hz (I)
(**) NVIDIA(0): Default mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
(**) NVIDIA(0): Default mode "800x600": 56.3 MHz, 53.7 kHz, 85.1 Hz
(**) NVIDIA(0): Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) NVIDIA(0): Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(**) NVIDIA(0): Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(**) NVIDIA(0): Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(**) NVIDIA(0): Default mode "640x512": 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
(**) NVIDIA(0): Default mode "640x480": 36.0 MHz, 43.3 kHz, 85.0 Hz
(**) NVIDIA(0): Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(**) NVIDIA(0): Default mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
(**) NVIDIA(0): Default mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
(**) NVIDIA(0): Default mode "640x480": 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
(**) NVIDIA(0): Default mode "720x400": 35.5 MHz, 37.9 kHz, 85.0 Hz
(**) NVIDIA(0): Default mode "640x400": 31.5 MHz, 37.9 kHz, 85.1 Hz
(**) NVIDIA(0): Default mode "640x350": 31.5 MHz, 37.9 kHz, 85.1 Hz
(**) NVIDIA(0): Default mode "512x384": 39.4 MHz, 60.1 kHz, 75.1 Hz (D)
(**) NVIDIA(0): Default mode "512x384": 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
(**) NVIDIA(0): Default mode "512x384": 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
(**) NVIDIA(0): Default mode "512x384": 22.4 MHz, 35.5 kHz, 86.9 Hz (D)
(**) NVIDIA(0): Default mode "416x312": 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 28.1 MHz, 53.7 kHz, 85.3 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
(**) NVIDIA(0): Default mode "320x240": 18.0 MHz, 43.3 kHz, 85.2 Hz (D)
(**) NVIDIA(0): Default mode "320x240": 15.8 MHz, 37.5 kHz, 75.0 Hz (D)
(**) NVIDIA(0): Default mode "320x240": 15.8 MHz, 37.9 kHz, 72.8 Hz (D)
(**) NVIDIA(0): Default mode "320x240": 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
(**) NVIDIA(0): Default mode "320x200": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
(**) NVIDIA(0): Default mode "320x175": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
(II) NVIDIA(0): Virtual screen size determined to be 1280 x 800
(==) NVIDIA(0): DPI set to (75, 75)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
ABI class: X.Org ANSI C Emulation, version 0.2
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0x90000000 - 0x90ffffff (0x1000000) MX[B]
[1] 0 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B]
[2] 0 0 0xa0000000 - 0xa0ffffff (0x1000000) MX[B]
[3] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[4] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[5] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[6] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[7] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[8] -1 0 0xb0007000 - 0xb0007fff (0x1000) MX[B]
[9] -1 0 0xb0006000 - 0xb0006fff (0x1000) MX[B]
[10] -1 0 0xb0005000 - 0xb0005fff (0x1000) MX[B]
[11] -1 0 0xb0000000 - 0xb0003fff (0x4000) MX[B]
[12] -1 0 0xb0004000 - 0xb00047ff (0x800) MX[B]
[13] -1 0 0x80004000 - 0x800043ff (0x400) MX[B]
[14] -1 0 0x80000000 - 0x80003fff (0x4000) MX[B]
[15] -1 0 0x90000000 - 0x90ffffff (0x1000000) MX[B](B)
[16] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
[17] -1 0 0xa0000000 - 0xa0ffffff (0x1000000) MX[B](B)
[18] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
[19] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
[20] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
[21] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[22] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[23] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[24] -1 0 0x000018a0 - 0x000018bf (0x20) IX[B]
[25] -1 0 0x00001880 - 0x0000188f (0x10) IX[B]
[26] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[27] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[28] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[29] -1 0 0x00001800 - 0x0000181f (0x20) IX[B]
[30] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[31] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) NVIDIA(0): Setting mode "1280x800"
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(II) Loading extension NV-CONTROL
(EE) NVIDIA(0): Failed to load GLX
(==) RandR enabled
Symbol __glXgetActiveScreen from module /usr/X11R6/lib/modules/extensions/libdri.a is unresol
ved!
ved!
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(**) Option "Protocol" "ImPS/2"
(**) USB-Mouse: Device: "/dev/input/mice"
(**) USB-Mouse: Protocol: "ImPS/2"
(**) Option "AlwaysCore"
(**) USB-Mouse: always reports core events
(**) Option "Device" "/dev/input/mice"
(**) Option "Buttons" "5"
(**) Option "Emulate3Buttons" "true"
(**) USB-Mouse: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5"
(**) USB-Mouse: ZAxisMapping: buttons 4 and 5
(**) USB-Mouse: Buttons: 5
(**) Option "CoreKeyboard"
(**) Keyboard1: Core Keyboard
(**) Option "Protocol" "standard"
(**) Keyboard1: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard1: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard1: XkbModel: "pc105"
(**) Option "XkbLayout" "us"
(**) Keyboard1: XkbLayout: "us"
(**) Option "CustomKeycodes" "off"
(**) Keyboard1: CustomKeycodes disabled
(**) Option "CorePointer"
(**) USB-Mouse: Core Pointer
(II) XINPUT: Adding extended input device "USB-Mouse" (type: MOUSE)
(II) XINPUT: Adding extended input device "Keyboard1" (type: KEYBOARD)
(II) XINPUT: Adding extended input device "NVIDIA Event Handler" (type: Other)
(II) XINPUT: Adding extended input device "NVIDIA Kernel Input Handler" (type: Other)
(II) USB-Mouse: ps2EnableDataReporting: succeeded
Warning: font renderer for ".pcf" already registered at priority 0
Warning: font renderer for ".pcf.Z" already registered at priority 0
Warning: font renderer for ".pcf.gz" already registered at priority 0
Warning: font renderer for ".snf" already registered at priority 0
Warning: font renderer for ".snf.Z" already registered at priority 0
Warning: font renderer for ".snf.gz" already registered at priority 0
Warning: font renderer for ".bdf" already registered at priority 0
Warning: font renderer for ".bdf.Z" already registered at priority 0
Warning: font renderer for ".bdf.gz" already registered at priority 0
Warning: font renderer for ".pmf" already registered at priority 0
Could not init font path element unix/:7100, removing from list!
SetClientVersion: 0 8
Non è che hai lasciato in xorg.conf "Load dri"?perchè vedo che sopra lo carica, ma come specificato da nvidia non deve
Vedi?
e carica di conseguenza il modulo drm...........
Vedi?
Si load dri c'è. Anche senza quello il problema rimaneva. Ho risolto reinstallando i driver nvidia dopo aver modificato xorg con gli update. Ora load dri è sempre caricato e funziona tutto. Perchè non dovrei caricarlo?clodo ha scritto:Non è che hai lasciato in xorg.conf "Load dri"?perchè vedo che sopra lo carica, ma come specificato da nvidia non deve
Vedi?
Perchè lo dice nvidia:
Chapter 3. Configuring X for the NVIDIA Driver
Remove the line:
Driver "nv"
(or Driver "vesa")
(or Driver "fbdev")
and replace it with the line:
Driver "nvidia"
Remove the following lines:
Load "dri"
Load "GLCore"
In the "Module" section of the file, add the line (if it does not already
exist):
Load "glx"
Remove the line:
Driver "nv"
(or Driver "vesa")
(or Driver "fbdev")
Driver "nvidia"
Load "dri"
Load "GLCore"
exist):
Load "glx"
