Ciao ho di nuovo bisogno del vostro aiuto!!!
una volta dato startx vengono stampati a video una serie di errori, con startx &> nome_file ho racchiuso l'output in un file.
Gli errori sono i seguenti:
_XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
_XSERVTransOpen: transport open failed for inet6/slackware:0
_XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
X Window System Version 6.8.2
Release Date: 9 February 2005
X Protocol Version 11, Revision 0, Release 6.8.2
Build Operating System: Linux 2.4.31 i686 [ELF]
Current Operating System: Linux slackware 2.4.31 #6 Sun Jun 5 19:04:47 PDT 2005 i686
Build Date: 25 September 2005
Before reporting problems, check http://wiki.X.Org
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Oct 27 20:08:56 2005
Could not init font path element /usr/X11R6/lib/X11/fonts/CID, removing from list!
xset: bad font path element (#125), possible causes are:
Directory does not exist or has wrong permissions
Directory missing fonts.dir
Incorrect font server address or syntax
startkde: Starting up...
kbuildsycoca running...
kdecore (KLibLoader): WARNING: KLibrary: /opt/kde/lib/kde3/kcm_kdnssd.so: undefined symbol: init_kdnssd
SetClientVersion: 0 8
oooqs: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
(firefox-bin:3060): Gdk-WARNING **: gdk_property_get(): length value has wrapped in calculation (did you pass G_MAXLONG?)
(thunderbird-bin:3088): Gdk-WARNING **: gdk_property_get(): length value has wrapped in calculation (did you pass G_MAXLONG?)
libnvidia-tls.so.1: cannot handle TLS data
Ma che cosa significa??? Dove devo mettere mano??
Thanks 4 the help
Errori con STARTX
- darkside04
- touchstyle
- Slackware: 12.1
- Kernel: 2.6.27
- Desktop: KDE
- darkside04
Spero di non fare una c....ta postando quanto sotto (per la lunghezza)
Ecco i due file:
1) var/log/Xorg.0.log
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Oct 28 23:24:19 2005
(==) ServerLayout "Simple Layout"
(**) |-->Screen "Screen 1" (0)
(**) | |-->Monitor "My Monitor"
(**) | |-->Device "VESA Framebuffer"
(**) |-->Input Device "Mouse1"
(**) |-->Input Device "Keyboard1"
(WW) `fonts.dir' not found (or not valid) in "/usr/X11R6/lib/X11/fonts/local".
Entry deleted from font path.
(Run 'mkfontdir' on "/usr/X11R6/lib/X11/fonts/local").
(WW) `fonts.dir' not found (or not valid) in "/usr/X11R6/lib/X11/fonts/Speedo".
(Run 'mkfontdir' on "/usr/X11R6/lib/X11/fonts/Speedo").
(WW) The directory "/usr/local/share/fonts" does not exist.
(WW) The directory "/usr/share/fonts" does not exist.
(WW) `fonts.dir' not found (or not valid) in "/usr/X11R6/lib/X11/fonts".
(Run 'mkfontdir' on "/usr/X11R6/lib/X11/fonts").
(WW) The directory "/usr/share/fonts/default" does not exist.
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/misc,/usr/X11R6/lib/X11/fonts/75dpi:unscaled,/usr/X11R6/lib/X11/fonts/100dpi:unscaled,/usr/X11R6/lib/X11/fonts/Type1,/usr/X11R6/lib/X11/fonts/CID,/usr/X11R6/lib/X11/fonts/cyrillic"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(II) Open APM successful
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.7
X.Org XInput driver : 0.4
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 6.8.2, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 0.7
(--) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,0691 card 0000,0000 rev c4 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,8598 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:07:0: chip 1106,0686 card 1106,0686 rev 22 class 06,01,00 hdr 80
(II) PCI: 00:07:1: chip 1106,0571 card 0000,0000 rev 10 class 01,01,8a hdr 00
(II) PCI: 00:07:2: chip 1106,3038 card 0925,1234 rev 10 class 0c,03,00 hdr 00
(II) PCI: 00:07:3: chip 1106,3038 card 0925,1234 rev 10 class 0c,03,00 hdr 00
(II) PCI: 00:07:4: chip 1106,3057 card 0000,0000 rev 30 class 0c,05,00 hdr 00
(II) PCI: 00:07:5: chip 1106,3058 card 1631,2001 rev 20 class 04,01,00 hdr 00
(II) PCI: 00:0f:0: chip 10b7,9055 card 10b7,9055 rev 30 class 02,00,00 hdr 00
(II) PCI: 00:10:0: chip 1106,3038 card 0925,1234 rev 50 class 0c,03,00 hdr 80
(II) PCI: 00:10:1: chip 1106,3038 card 0925,1234 rev 50 class 0c,03,00 hdr 80
(II) PCI: 00:10:2: chip 1106,3104 card 0925,1234 rev 51 class 0c,03,20 hdr 80
(II) PCI: 01:00:0: chip 10de,002d card 107d,b242 rev 15 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x00008000 - 0x00008fff (0x1000) IX
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xdde00000 - 0xdfefffff (0x2100000) MX
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd9c00000 - 0xddcfffff (0x4100000) MX
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:7:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) nVidia Corporation NV5M64 [RIVA TNT2 Model 64/Model 64 Pro] rev 21, Mem @ 0xde000000/24, 0xda000000/25, BIOS @ 0xdfef0000/16
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX(B)
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xe3ffffff to 0xdfffffff
(II) Active PCI resource ranges:
[0] -1 0 0xdffffe00 - 0xdffffeff (0x100) MX[B]
[1] -1 0 0xdfffff80 - 0xdfffffff (0x80) MX[B]
[2] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[3] -1 0 0xdfef0000 - 0xdfefffff (0x10000) MX[B](B)
[4] -1 0 0xda000000 - 0xdbffffff (0x2000000) MX[B](B)
[5] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B)
[6] -1 0 0x0000c400 - 0x0000c41f (0x20) IX[B]
[7] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
[8] -1 0 0x0000c800 - 0x0000c87f (0x80) IX[B]
[9] -1 0 0x0000d400 - 0x0000d403 (0x4) IX[B]
[10] -1 0 0x0000d800 - 0x0000d803 (0x4) IX[B]
[11] -1 0 0x0000dc00 - 0x0000dcff (0x100) IX[B]
[12] -1 0 0x0000d000 - 0x0000d01f (0x20) IX[B]
[13] -1 0 0x0000cc00 - 0x0000cc1f (0x20) IX[B]
[14] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
(II) All system resource ranges:
[5] -1 0 0xdffffe00 - 0xdffffeff (0x100) MX[B]
[6] -1 0 0xdfffff80 - 0xdfffffff (0x80) MX[B]
[7] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[8] -1 0 0xdfef0000 - 0xdfefffff (0x10000) MX[B](B)
[9] -1 0 0xda000000 - 0xdbffffff (0x2000000) MX[B](B)
[10] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B)
[11] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[12] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[13] -1 0 0x0000c400 - 0x0000c41f (0x20) IX[B]
[14] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
[15] -1 0 0x0000c800 - 0x0000c87f (0x80) IX[B]
[16] -1 0 0x0000d400 - 0x0000d403 (0x4) IX[B]
[17] -1 0 0x0000d800 - 0x0000d803 (0x4) IX[B]
[18] -1 0 0x0000dc00 - 0x0000dcff (0x100) IX[B]
[19] -1 0 0x0000d000 - 0x0000d01f (0x20) IX[B]
[20] -1 0 0x0000cc00 - 0x0000cc1f (0x20) IX[B]
[21] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
ABI class: X.Org Server Extension, version 0.2
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension XC-MISC
(II) Loading extension XFree86-Misc
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="X.Org Foundation"
compiled for 6.8.2, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 6.8.2, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.7174
Module class: XFree86 Server Extension
ABI class: XFree86 Server Extension, version 0.1
(II) Loading extension GLX
(II) LoadModule: "nvidia"
(II) Loading /usr/X11R6/lib/modules/drivers/nvidia_drv.o
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.4
(II) LoadModule: "kbd"
(II) Loading /usr/X11R6/lib/modules/input/kbd_drv.o
(II) Module kbd: vendor="X.Org Foundation"
(II) NVIDIA X Driver 1.0-7174 Tue Mar 22 06:48:37 PST 2005
(II) NVIDIA Unified Driver for all NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset NVIDIA GPU found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[11] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[12] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[13] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[14] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[15] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[16] -1 0 0x0000c400 - 0x0000c41f (0x20) IX[B]
[17] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
[18] -1 0 0x0000c800 - 0x0000c87f (0x80) IX[B]
[19] -1 0 0x0000d400 - 0x0000d403 (0x4) IX[B]
[20] -1 0 0x0000d800 - 0x0000d803 (0x4) IX[B]
[21] -1 0 0x0000dc00 - 0x0000dcff (0x100) IX[B]
[22] -1 0 0x0000d000 - 0x0000d01f (0x20) IX[B]
[23] -1 0 0x0000cc00 - 0x0000cc1f (0x20) IX[B]
[24] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[25] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[26] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Option "NoLogo" "true"
(**) NVIDIA(0): Option "RenderAccel" "true"
(**) NVIDIA(0): Option "UseEdidFreqs" "true"
(**) NVIDIA(0): Enabling experimental RENDER acceleration
(--) NVIDIA(0): Linear framebuffer at 0xDA000000
(--) NVIDIA(0): MMIO registers at 0xDE000000
(II) NVIDIA(0): NVIDIA GPU detected as: RIVA TNT2 Model 64/Model 64 Pro
(--) NVIDIA(0): VideoBIOS: 02.05.20.02.17
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(II) NVIDIA(0): Detected AGP rate: 2X
(--) NVIDIA(0): VideoRAM: 16384 kBytes
(II) NVIDIA(0): Connected display device(s): CRT-0
(--) NVIDIA(0): Display device CRT-0: maximum pixel clock at 8 bpp: 250 MHz
(--) NVIDIA(0): Display device CRT-0: maximum pixel clock at 16 bpp: 250 MHz
(--) NVIDIA(0): Display device CRT-0: maximum pixel clock at 32 bpp: 215 MHz
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="X.Org Foundation"
(II) NVIDIA(0): My Monitor: Using hsync range of 30.00-70.00 kHz
(II) NVIDIA(0): My Monitor: Using vrefresh range of 50.00-120.00 Hz
(II) NVIDIA(0): Clock range: 12.00 to 215.00 MHz
(II) NVIDIA(0): Not using default mode "1280x960" (hsync out of range)
(II) NVIDIA(0): Not using default mode "640x480" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1280x1024" (hsync out of range)
(II) NVIDIA(0): Not using default mode "640x512" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1600x1200" (hsync out of range)
(II) NVIDIA(0): Not using default mode "800x600" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1600x1200" (bad mode clock/interlace/doublescan)
(II) NVIDIA(0): Not using default mode "1792x1344" (hsync out of range)
(II) NVIDIA(0): Not using default mode "896x672" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1792x1344" (bad mode clock/interlace/doublescan)
(II) NVIDIA(0): Not using default mode "1856x1392" (bad mode clock/interlace/doublescan)
(II) NVIDIA(0): Not using default mode "928x696" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1920x1440" (bad mode clock/interlace/doublescan)
(II) NVIDIA(0): Not using default mode "960x720" (hsync out of range)
(WW) (1400x1050,My Monitor) mode clock 122MHz exceeds DDC maximum 110MHz
(II) NVIDIA(0): Not using default mode "1400x1050" (hsync out of range)
(II) NVIDIA(0): Not using default mode "700x525" (hsync out of range)
(II) NVIDIA(0): Not using default mode "2048x1536" (width requires unsupported line pitch)
(II) NVIDIA(0): Not using default mode "1024x768" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1400x1050" (width too large for virtual size)
(II) NVIDIA(0): Not using default mode "1280x1024" (width too large for virtual size)
(II) NVIDIA(0): Not using default mode "1280x960" (width too large for virtual size)
(II) NVIDIA(0): Not using default mode "1152x864" (width too large for virtual size)
(II) NVIDIA(0): Not using default mode "1152x768" (width too large for virtual size)
(WW) NVIDIA(0): Not using mode "700x525" (height 1050 is larger than
(WW) NVIDIA(0): EDID-specified maximum 1024)
(WW) NVIDIA(0): Not using mode "576x384":
(WW) NVIDIA(0): horizontal sync start (589) not a multiple of 8
(WW) NVIDIA(0): Not using mode "360x200":
(WW) NVIDIA(0): horizontal sync start (378) not a multiple of 8
(**) NVIDIA(0): Validated modes for display device CRT-0:
(**) NVIDIA(0): Default mode "1024x768": 94.5 MHz, 68.7 kHz, 85.0 Hz
(**) NVIDIA(0): Default mode "800x600": 56.3 MHz, 53.7 kHz, 85.1 Hz
(**) NVIDIA(0): Default mode "640x480": 36.0 MHz, 43.3 kHz, 85.0 Hz
(**) NVIDIA(0): Default mode "1024x768": 78.8 MHz, 60.1 kHz, 75.1 Hz
(**) NVIDIA(0): Default mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(**) NVIDIA(0): Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(**) NVIDIA(0): Default mode "1024x768": 44.9 MHz, 35.5 kHz, 87.0 Hz (I)
(**) NVIDIA(0): Default mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
(**) NVIDIA(0): Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) NVIDIA(0): Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(**) NVIDIA(0): Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(**) NVIDIA(0): Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(**) NVIDIA(0): Default mode "640x512": 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
(**) NVIDIA(0): Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(**) NVIDIA(0): Default mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
(**) NVIDIA(0): Default mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
(**) NVIDIA(0): Default mode "640x480": 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
(**) NVIDIA(0): Default mode "720x400": 35.5 MHz, 37.9 kHz, 85.0 Hz
(**) NVIDIA(0): Default mode "640x400": 31.5 MHz, 37.9 kHz, 85.1 Hz
(**) NVIDIA(0): Default mode "576x432": 54.0 MHz, 67.5 kHz, 75.0 Hz (D)
(**) NVIDIA(0): Default mode "640x350": 31.5 MHz, 37.9 kHz, 85.1 Hz
(**) NVIDIA(0): Default mode "512x384": 47.2 MHz, 68.7 kHz, 85.0 Hz (D)
(**) NVIDIA(0): Default mode "512x384": 39.4 MHz, 60.1 kHz, 75.1 Hz (D)
(**) NVIDIA(0): Default mode "512x384": 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
(**) NVIDIA(0): Default mode "512x384": 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
(**) NVIDIA(0): Default mode "512x384": 22.4 MHz, 35.5 kHz, 86.9 Hz (D)
(**) NVIDIA(0): Default mode "416x312": 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 28.1 MHz, 53.7 kHz, 85.3 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(**) NVIDIA(0): Default mode "400x300": 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
(**) NVIDIA(0): Default mode "320x240": 18.0 MHz, 43.3 kHz, 85.2 Hz (D)
(**) NVIDIA(0): Default mode "320x240": 15.8 MHz, 37.5 kHz, 75.0 Hz (D)
(**) NVIDIA(0): Default mode "320x240": 15.8 MHz, 37.9 kHz, 72.8 Hz (D)
(**) NVIDIA(0): Default mode "320x240": 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
(**) NVIDIA(0): Default mode "320x200": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
(**) NVIDIA(0): Default mode "320x175": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
(II) NVIDIA(0): Virtual screen size determined to be 1024 x 768
(--) NVIDIA(0): Display dimensions: (310, 230) mm
(--) NVIDIA(0): DPI set to (83, 84)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
ABI class: X.Org ANSI C Emulation, version 0.2
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/X11R6/lib/modules/libramdac.a
(II) Module ramdac: vendor="X.Org Foundation"
compiled for 6.8.2, module version = 0.1.0
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xda000000 - 0xdbffffff (0x2000000) MX[B]
[1] 0 0 0xde000000 - 0xdeffffff (0x1000000) MX[B]
[2] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[7] -1 0 0xdffffe00 - 0xdffffeff (0x100) MX[B]
[8] -1 0 0xdfffff80 - 0xdfffffff (0x80) MX[B]
[9] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[10] -1 0 0xdfef0000 - 0xdfefffff (0x10000) MX[B](B)
[11] -1 0 0xda000000 - 0xdbffffff (0x2000000) MX[B](B)
[12] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B)
[13] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
[14] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
[15] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
[16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[18] -1 0 0x0000c400 - 0x0000c41f (0x20) IX[B]
[19] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
[20] -1 0 0x0000c800 - 0x0000c87f (0x80) IX[B]
[21] -1 0 0x0000d400 - 0x0000d403 (0x4) IX[B]
[22] -1 0 0x0000d800 - 0x0000d803 (0x4) IX[B]
[23] -1 0 0x0000dc00 - 0x0000dcff (0x100) IX[B]
[24] -1 0 0x0000d000 - 0x0000d01f (0x20) IX[B]
[25] -1 0 0x0000cc00 - 0x0000cc1f (0x20) IX[B]
[26] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[27] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[28] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) NVIDIA(0): Setting mode "1024x768"
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
(**) Option "Protocol" "IMPS/2"
(**) Mouse1: Device: "/dev/mouse"
(**) Mouse1: Protocol: "IMPS/2"
(**) Option "CorePointer"
(**) Mouse1: Core Pointer
(**) Option "Device" "/dev/mouse"
(**) Option "Emulate3Buttons" "no"
(**) Option "ZAxisMapping" "4 5"
(**) Mouse1: ZAxisMapping: buttons 4 and 5
(**) Mouse1: Buttons: 5
(**) Option "CoreKeyboard"
(**) Keyboard1: Core Keyboard
(**) Option "Protocol" "standard"
(**) Keyboard1: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard1: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard1: XkbModel: "pc105"
(**) Option "XkbLayout" "us"
(**) Keyboard1: XkbLayout: "us"
(**) Option "CustomKeycodes" "off"
(**) Keyboard1: CustomKeycodes disabled
(II) XINPUT: Adding extended input device "Keyboard1" (type: KEYBOARD)
(II) XINPUT: Adding extended input device "Mouse1" (type: MOUSE)
(II) XINPUT: Adding extended input device "NVIDIA Event Handler" (type: Other)
(II) Mouse1: ps2EnableDataReporting: succeeded
SetClientVersion: 0 8[/]
/etc/X11/xorg.conf
# File generated by xf86config.
# Copyright (c) 1999 by The XFree86 Project, Inc.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE XFREE86 PROJECT BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
# WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
# OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
# Except as contained in this notice, the name of the XFree86 Project shall
# not be used in advertising or otherwise to promote the sale, use or other
# dealings in this Software without prior written authorization from the
# XFree86 Project.
# Refer to the XF86Config(4/5) man page for details about the format of
# this file.
# NOTE: This is a NEW IMPROVED version of XF86Config-fbdev that uses the vesa
# driver instead of the fbdev driver. Thanks to Kenneth Fanyo who pointed
# this out to me.
# This XF86Config file is designed for use with the VESA framebuffer.
# This generic interface should work with nearly all video cards
# (although not every card will support every resolution).
# With the new driver, it should no longer be required to have frame buffer
# support in the kernel, or to run it on the console.
# Enjoy!
# -- volkerdi@slackware.com
# Module section -- this section is used to specify
# which dynamically loadable modules to load.
Section "Module"
# This loads the DBE extension module.
Load "dbe" # Double buffer extension
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
SubSection "extmod"
Option "omit xfree86-dga" # don't initialise the DGA extension
EndSubSection
# This loads the font modules
Load "type1"
Load "freetype"
#Load "speedo"
# This loads the GLX module
Load "glx"
EndSection
# Files section. This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
RgbPath "/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (which are concatenated together),
# as well as specifying multiple comma-separated entries in one FontPath
# command (or a combination of both methods)
# If you don't have a floating point coprocessor and emacs, Mosaic or other
# programs take long to start up, try moving the Type1 and Speedo directory
# to the end of this list (or comment them out).
# ModulePath can be used to set a search path for the X server modules.
# The default path is shown here.
# ModulePath "/usr/X11R6/lib/modules"
FontPath "/usr/X11R6/lib/X11/fonts/local"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/CID"
FontPath "/usr/X11R6/lib/X11/fonts/Speedo"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/local/share/fonts"
FontPath "/usr/share/fonts"
FontPath "/usr/X11R6/lib/X11/fonts"
FontPath "/usr/share/fonts/default"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received. This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
# Option "NoTrapSignals"
# Uncomment this to disable the <Crtl><Alt><Fn> VT switch sequence
# (where n is 1 through 12). This allows clients to receive these key
# events.
# Option "DontVTSwitch"
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
# Option "DontZap"
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences. This allows clients to receive these key events.
# Option "DontZoom"
# Uncomment this to disable tuning with the xvidtune client. With
# it the client can still run and fetch card and monitor attributes,
# but it will not be allowed to change them. If it tries it will
# receive a protocol error.
# Option "DisableVidModeExtension"
# Uncomment this to enable the use of a non-local xvidtune client.
# Option "AllowNonLocalXvidtune"
# Uncomment this to disable dynamically modifying the input device
# (mouse and keyboard) settings.
# Option "DisableModInDev"
# Uncomment this to enable the use of a non-local client to
# change the keyboard or mouse settings (currently only xset).
# Option "AllowNonLocalModInDev"
# Set the basic blanking screen saver timeout.
# Option "blank time" "10" # 10 minutes
# Set the DPMS timeouts. These are set here because they are global
# rather than screen-specific. These settings alone don't enable DPMS.
# It is enabled per-screen (or per-monitor), and even then only when
# the driver supports it.
# Option "standby time" "20"
# Option "suspend time" "30"
# Option "off time" "60"
# On some platform the server needs to estimate the sizes of PCI
# memory and pio ranges. This is done by assuming that PCI ranges
# don't overlap. Some broken BIOSes tend to set ranges of inactive
# devices wrong. Here one can adjust how aggressive the assumptions
# should be. Default is 0.
# Option "EstimateSizesAggresively" "0"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
Identifier "Keyboard1"
Driver "kbd"
# For most OSs the protocol can be omitted (it defaults to "Standard").
# When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
# uncomment the following line.
# Option "Protocol" "Xqueue"
# Set the keyboard auto repeat parameters. Not all platforms implement
# this.
# Option "AutoRepeat" "500 5"
# Specifiy which keyboard LEDs can be user-controlled (eg, with xset(1)).
# Option "Xleds" "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
# Option "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a European
# keyboard, you will probably want to use one of:
# Option "XkbModel" "pc102"
# If you have a Microsoft Natural keyboard, you can use:
# Option "XkbModel" "microsoft"
# If you have a US "windows" keyboard you will want:
# Option "XkbModel" "pc104"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# Option "XkbLayout" "de"
# or:
# Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# Option "XkbOptions" "ctrl:swapcaps"
# These are the default XKB settings for X.Org
# Option "XkbRules" "xorg"
# Option "XkbModel" "pc101"
# Option "XkbLayout" "us"
# Option "XkbVariant" ""
# Option "XkbOptions" ""
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
Identifier "Mouse1"
Driver "mouse"
# On platforms where PnP mouse detection is supported the following
# protocol setting can be used when using a newer PnP mouse:
# Option "Protocol" "Auto"
# The available mouse protocols types that you can set below are:
# Auto BusMouse GlidePoint GlidePointPS/2 IntelliMouse IMPS/2
# Logitech Microsoft MMHitTab MMSeries Mouseman MouseManPlusPS/2
# MouseSystems NetMousePS/2 NetScrollPS/2 OSMouse PS/2 SysMouse
# ThinkingMouse ThinkingMousePS/2 Xqueue
Option "Emulate 3Buttons" "no"
# The mouse device. The device is normally set to /dev/mouse,
# which is usually a symbolic link to the real device.
# Option "Device" "/dev/psaux"
# Option "Device" "/dev/ttyS0"
# Option "Device" "/dev/ttyS1"
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
# Option "BaudRate" "9600"
# Option "SampleRate" "150"
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
# Option "Emulate3Buttons"
# Option "Emulate3Timeout" "50"
# ChordMiddle is an option for some 3-button Logitech mice
# Option "ChordMiddle"
EndSection
# Some examples of extended input devices
# Section "InputDevice"
# Identifier "spaceball"
# Driver "magellan"
# Option "Device" "/dev/cua0"
# EndSection
# Identifier "spaceball2"
# Driver "spaceorb"
# EndSection
# Identifier "touchscreen0"
# Driver "microtouch"
# Option "MinX" "1412"
# Option "MaxX" "15184"
# Option "MinY" "15372"
# Option "MaxY" "1230"
# Option "ScreenNumber" "0"
# Option "ReportingMode" "Scaled"
# Option "ButtonNumber" "1"
# Option "SendCoreEvents"
# EndSection
# Identifier "touchscreen1"
# Driver "elo2300"
# Option "MinX" "231"
# Option "MaxX" "3868"
# Option "MinY" "3858"
# Option "MaxY" "272"
# Option "ButtonThreshold" "17"
# EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
Identifier "My Monitor"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY. REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
HorizSync 30.0 - 70.0
# HorizSync 30-64 # multisync
# HorizSync 31.5, 35.2 # multiple fixed sync frequencies
# HorizSync 15-25, 30-50 # multiple ranges of sync frequencies
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
VertRefresh 50-120
EndSection
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
Identifier "VESA Framebuffer"
Driver "nvidia"
#VideoRam 4096
# Insert Clocks lines here if appropriate
EndSection
# Screen sections
# Any number of screen sections may be present. Each describes
# the configuration of a single screen. A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
Identifier "Screen 1"
# If your card can handle it, a higher default color depth (like 24 or 32)
# is highly recommended.
# DefaultDepth 8
# DefaultDepth 16
DefaultDepth 24
# DefaultDepth 32
# "1024x768" is also a conservative usable default resolution. If you
# have a better monitor, feel free to try resolutions such as
# "1152x864", "1280x1024", "1600x1200", and "1800x1400" (or whatever your
# card/monitor can produce)
Subsection "Display"
Depth 8
Modes "1024x768" "800x600" "640x480"
EndSubsection
Depth 16
EndSubsection
Depth 24
EndSubsection
Depth 32
EndSubsection
EndSection
# ServerLayout sections.
# Any number of ServerLayout sections may be present. Each describes
# the way multiple screens are organised. A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option. In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
Section "ServerLayout"
# The Identifier line must be present
Identifier "Simple Layout"
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens. The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen. In this example, screen 2 is located to the
# right of screen 1.
Screen "Screen 1"
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used. Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
InputDevice "Mouse1" "CorePointer"
InputDevice "Keyboard1" "CoreKeyboard"
EndSection
Ecco i due file:
(==) RandR enabled
/etc/X11/xorg.conf
# SOFTWARE.
# XFree86 Project.
# this file.
# this out to me.
# Enjoy!
Section "Module"
SubSection "extmod"
EndSubSection
Load "type1"
Load "freetype"
#Load "speedo"
Load "glx"
EndSection
Section "Files"
EndSection
# events.
# Option "DontZap"
# Option "DontZoom"
EndSection
# Input devices
Driver "kbd"
# this.
# or:
EndSection
Identifier "Mouse1"
Driver "mouse"
EndSection
# Driver "magellan"
# EndSection
# Driver "spaceorb"
# EndSection
# EndSection
# Driver "elo2300"
# EndSection
# Monitor section
Section "Monitor"
VertRefresh 50-120
EndSection
Section "Device"
Driver "nvidia"
#VideoRam 4096
EndSection
# Screen sections
# option.
Section "Screen"
# DefaultDepth 8
# DefaultDepth 16
DefaultDepth 24
# DefaultDepth 32
Depth 8
EndSubsection
Depth 16
EndSubsection
Depth 24
EndSubsection
Depth 32
EndSubsection
EndSection
# is used alone.
Screen "Screen 1"
# "SendCoreEvents".
EndSection
