ho montato una scheda wifi con ndiswrapper
per configurare la scheda (da root) do:
iwlist wlan0 scan
wlan0 Scan completed :
Cell 01 - Address: 00:0F:B5:67:62:04
ESSID:"NETGEAR"
Protocol:IEEE 802.11g
Mode:Managed
Frequency:2.462GHz
Quality:0/100 Signal level:-64 dBm Noise level:-256 dBm
Encryption key:off
Bit Rate:1Mb/s
Bit Rate:2Mb/s
Bit Rate:5.5Mb/s
Bit Rate:11Mb/s
Bit Rate:6Mb/s
Bit Rate:12Mb/s
Bit Rate:24Mb/s
Bit Rate:36Mb/s
Bit Rate:9Mb/s
Bit Rate:18Mb/s
Bit Rate:48Mb/s
Bit Rate:54Mb/s
Extra:bcn_int=100
Extra:atim=0
questo è l'output di iwconfig
iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11g ESSID:"NETGEAR"
Mode:Managed Frequency:2.462GHz Access Point: 00:0F:B5:67:62:04
Bit Rate:54Mb/s Tx-Power:25 dBm
RTS thr:2347 B Fragment thr:2346 B
Encryption key:off
Power Management:off
Link Quality:100/100 Signal level:-71 dBm Noise level:-256 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
collisions:0 txqueuelen:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
wlan0 Link encap:Ethernet HWaddr 00:C0:49:F7:42:89
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
Interrupt:11 Memory:ee800000-ee801fff
ifconfig wlan0 127.0.0.1
ifconfig
inet addr:127.0.0.1 Bcast:127.255.255.255 Mask:255.0.0.0
dhclient wlan0
Listening on Socket/wlan0
Sending on Socket/wlan0
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 16
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 17
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 5
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
uso kernel 2.4.29 su slack 10.1
