zyair g-100 non funziona
hal9000
Nome Cognome: Alessandro Zamori
Slackware: 64 15.0
Kernel: huge-5.15.19
Messaggio da hal9000 »
Salve a tutti, ho acquistato una zayxel zyair g-100 pr il mio vechio laptop che è garantita compatibile con linux. Dopo varie peripezie ho trovato il firmaware giusto ed adesso è riconosciuta ma non si connette, o meglio, si connette se la rete non è protetta. Ecco l' output di ifconfig
root@zago:~# ifconfig
eth0 Link encap:Ethernet HWaddr 00:a0:c5:94:1e:9b
inet addr:192.168.1.3 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::2a0:c5ff:fe94:1e9b/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:33 errors:0 dropped:0 overruns:0 frame:0
TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2640 (2.5 KiB) TX bytes:238 (238.0 B)
Interrupt:11
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
l' output di iwconfig
root@zago:~# iwconfig
lo no wireless extensions.
eth0 IEEE 802.11b/g Nickname:"zago"
Mode:Managed Frequency:2.452 GHz Access Point: Not-Associated
Bit Rate:0 kb/s Tx-Power=31 dBm Sensitivity=20/200
Retry short limit:8 RTS thr=2347 B Fragment thr=2346 B
Encryption key:off
Link Quality:80 Signal level:0 Noise level:96
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
il mio rc.inet1.conf
# /etc/rc.d/rc.inet1.conf
# This file contains the configuration settings for network interfaces.
# If USE_DHCP[interface] is set to "yes", this overrides any other settings.
# If you don't have an interface, leave the settings null ("").
# You can configure network interfaces other than eth0,eth1... by setting
# IFNAME[interface] to the interface's name. If IFNAME[interface] is unset
# or empty, it is assumed you're configuring eth<interface>.
# Several other parameters are available, the end of this file contains a
# comprehensive set of examples.
# Config information for eth0:
IPADDR[0]="192.168.1.3"
NETMASK[0]="255.255.255.0"
USE_DHCP[0]=""
DHCP_HOSTNAME[0]=""
# Config information for eth1:
IPADDR[1]=""
NETMASK[1]=""
USE_DHCP[1]=""
DHCP_HOSTNAME[1]=""
# Config information for eth2:
IPADDR[2]=""
NETMASK[2]=""
USE_DHCP[2]=""
DHCP_HOSTNAME[2]=""
# Config information for eth3:
IPADDR[3]=""
NETMASK[3]=""
USE_DHCP[3]=""
DHCP_HOSTNAME[3]=""
# Default gateway IP address:
GATEWAY="192.168.1.1"
# Change this to "yes" for debugging output to stdout. Unfortunately,
# /sbin/hotplug seems to disable stdout so you'll only see debugging output
# when rc.inet1 is called directly.
DEBUG_ETH_UP="no"
## Example config information for wlan0. Uncomment the lines you need and fill
## in your info. (You may not need all of these for your wireless network)
#IFNAME[4]="wlan0"
#IPADDR[4]=""
#NETMASK[4]=""
#USE_DHCP[4]="yes"
#DHCP_HOSTNAME[4]="icculus-wireless"
#DHCP_KEEPRESOLV[4]="yes"
#DHCP_KEEPNTP[4]="yes"
#DHCP_KEEPGW[4]="yes"
#DHCP_IPADDR[4]=""
#WLAN_ESSID[4]=BARRIER05
#WLAN_MODE[4]=Managed
##WLAN_RATE[4]="54M auto"
##WLAN_CHANNEL[4]="auto"
##WLAN_KEY[4]="D5AD1F04ACF048EC2D0B1C80C7"
##WLAN_IWPRIV[4]="set AuthMode=WPAPSK | set EncrypType=TKIP | set WPAPSK=96389dc66eaf7e6efd5b5523ae43c7925ff4df2f8b7099495192d44a774fda16"
WLAN_WPA[4]="wpa_supplicant"
#WLAN_WPADRIVER[4]="ndiswrapper"
## Some examples of additional network parameters that you can use.
## Config information for wlan0:
#IFNAME[4]="wlan0" # Use a different interface name nstead of
# the default 'eth4'
#HWADDR[4]="00:01:23:45:67:89" # Overrule the card's hardware MAC address
#MTU[4]="" # The default MTU is 1500, but you might need
# 1360 when you use NAT'ed IPSec traffic.
#DHCP_KEEPRESOLV[4]="yes" # If you dont want /etc/resolv.conf overwritten
#DHCP_KEEPNTP[4]="yes" # If you don't want ntp.conf overwritten
#DHCP_KEEPGW[4]="yes" # If you don't want the DHCP server to change
# your default gateway
#DHCP_IPADDR[4]="" # Request a specific IP address from the DHCP
# server
#WLAN_ESSID[4]=DARKSTAR # Here, you can override _any_ parameter
# defined in rc.wireless.conf, by prepending
# 'WLAN_' to the parameter's name. Useful for
# those with multiple wireless interfaces.
#WLAN_IWPRIV[4]="set AuthMode=WPAPSK | set EncrypType=TKIP | set WPAPSK=thekey"
# Some drivers require a private ioctl to be
# set through the iwpriv command. If more than
# one is required, you can place them in the
# IWPRIV parameter (separated with the pipe (|)
# character, see the example).
# See /usr/doc/wpa_supplicant-0.5.10/wpa_supplicant.conf.sample
# for many more options that you can use in this file.
e wpa_supplicant.conf
# This line enables the use of wpa_cli which is used by rc.wireless
# if possible (to check for successful association)
ctrl_interface=/var/run/wpa_supplicant
# By default, only root (group 0) may use wpa_cli
ctrl_interface_group=0
eapol_version=1
ap_scan=1
fast_reauth=1
# WPA protected network, supply your own ESSID and WPAPSK here:
network={
scan_ssid=1
ssid="mio_essid"
# proto=WPA
key_mgmt=WPA-PSK
# pairwise=CCMP TKIP
# group=CCMP TKIP WEP104 WEP40
psk="pippo"
# Plaintext connection (no WPA, no IEEE 802.1X),
# nice for hotel/airport types of WiFi network.
network={
key_mgmt=NONE
priority=0
Uso Slackware 12.2. kernel 2.6.27.7.-smp . Dove sbaglio?
Grazie per l' aiuto
Hal9000
Ultima modifica di hal9000 il mar 23 dic 2008, 16:46, modificato 2 volte in totale.
scorpion77
Nome Cognome: Andrea
Slackware: Slackware64 14.1
Desktop: KDE 4.10.5
Re: ancora problemi wireless
Messaggio da scorpion77 »
hal9000 ha scritto:Salve a tutti, ho acquistato una zayxel zyair g-100 pr il mio vechio laptop che è garantita compatibile con linux. Dopo varie peripezie ho trovato il firmaware giusto ed adesso è riconosciuta ma non si connette, o meglio, si connette se la rete non è protetta.
Grazie per l' aiuto
Hal9000
Devi aggiungere queste righe nel file rc.inet1.conf:
WLAN_WPADRIVER[4]="wext"
WLAN_WPACONF[4]="/etc/wpa_supplicant.conf"
Questo è il mio wpa_supplicant.conf:
# See /usr/doc/wpa_supplicant-0.5.7/wpa_supplicant.conf.sample
ctrl_interface_group=wheel
# rete domestica protetta con metodo WPA-Personal (WPA_PSK)
network={
ssid="*** mio ssid***"
scan_ssid=0
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
psk="*** mia psk ***"
Inoltre, in rc.wireless.conf devi aggiungere questa riga (io l'ho aggiunto dopo VERBOSE=1):
WPA="y"
Infine, al fondo del file rc.wireless, aggiungi questo:
if [ "$WPA" = "y" -a -x /usr/local/sbin/wpa_supplicant ]; then
/usr/sbin/wpa_supplicant -Bw -c/etc/wpa_supplicant.conf -i${INTERFACE}
fi
Ora dovrebbe funzionare.
Scorpion77
scorpion77 ha scritto: Inoltre, in rc.wireless.conf devi aggiungere questa riga (io l'ho aggiunto dopo VERBOSE=1):
WPA="y"
fi
A che servirebbe?
tieni presente che WPA è una variabile usata nello script rc.wireless che assume il valore di WLAN_WPA presente in rc.inet1.conf
Infatti basta solamente mettere
WLAN_WPA="wpa_supplicant"
in /etc/rc.d/rc.inet1.conf
anche questi valori che consigli
sono presi di default
scorpion77
Desktop: KDE 4.10.5
WPA="y"
fi
A che servirebbe?
Ok, quindi la riga if [ "$WPA" = "y" -a -x /usr/local/sbin/wpa_supplicant ]; then è inutile, però non bisognerebbe lasciare questa riga: /usr/sbin/wpa_supplicant -Bw -c/etc/wpa_supplicant.conf -i${INTERFACE} che serve per passare i giusti parametri al comando wpa_supplicant?
conraid ha scritto:anche questi valori che consigli
Ottimo, quindi li posso togliere, visto che sono già specificati di default. Non si smette mai di imparare. :thumbright:
Scorpion77
scorpion77 ha scritto: Ok, quindi la riga if [ "$WPA" = "y" -a -x /usr/local/sbin/wpa_supplicant ]; then è inutile, però non bisognerebbe lasciare questa riga: /usr/sbin/wpa_supplicant -Bw -c/etc/wpa_supplicant.conf -i${INTERFACE} che serve per passare i giusti parametri al comando wpa_supplicant?
Guarda lo script rc.wireless e scoprirai che c'è già. Se usi la Slackware 12.2
Le tua sembrano istruzioni di vecchi file quando ancora non era supportato wpa_supplicant, ma ne è passato di tempo da allora
Sì, a patto che utilizzi in rc.inet1.conf
che tu non avevi indicato e che invece è proprio la variabile che "attiva" il WPA
slucky
Desktop: xfce4
Distribuzione: FreeBSD
Messaggio da slucky »
secondo me questi problemi con il wi-fi possono anche derivare dal fatto che queste schede wireless vengono rilevate dal sistema come eth0 e non wlan0, non è un caso che alcuni hanno avuto questo problema, poi mettendo mano alle regole di udev hanno risolto :-k
non so, però se non riesci a risolvere, prova a editare il file /etc/udev/rules.d/70-persistent-net.rules e a modificare le voci eth0 in wlan0 e poi rifai i settaggi in /etc/rc.inet1.conf, infine riavvi o ristarti la rete
hal9000
Slackware: 64 15.0
Re: zyair g-100 non funziona
Grazie atuuti per le risposte, ma purtroppo non funziona, anche cambiando in udev da eth0 a wlan0 viene sempre vista come eth0. Inoltre senza il wpa abilitato sul router si connette e naviga normalmente; quindi credo che il problema sia il wpa_supplicant. Ho anche cambiato il titolo perchè così è più specifico. Nel forum ho trovato qusto: viewtopic.php?f=7&t=21848&p=170044#p170044 ma non ho capito come ci è riuscito. Maupau, saresti così gentile da spiegarmi quali passaggi hai usato. Grazie a tutti per l' interessamento. Hal9000
